  1. Aug 4, 2020 at 7:41 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    That bucket needs more tape on it :boink:
  2. Aug 4, 2020 at 7:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I wanted to be damn sure that lid wasn’t coming off.
  3. Aug 4, 2020 at 7:47 PM
    TomTwo
    Bill
    I-85 Southbound
    Understood :fistbump:
  4. Aug 4, 2020 at 7:56 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    The rides great now, don’t know how much the bushings contributed to that because I basically replaced the entire front end...
    The white line bushings were a much better quality than the stock ones though. I know of one other guy who’s running the white line’s and he said it was much smoother off-road. I’ve put just under 100miles on them just going to work and back.
  5. Aug 4, 2020 at 8:03 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I forgot to add that I picked up my fender, charcoal canister, connectors (one is on back order) and steering wheel.
  6. Aug 4, 2020 at 8:16 PM
    King Bouyah
    King Bouyah Well-Known Member
    Ogden, UT
    05 RC Base 5-lug
    Came with MGM topper. Added FJammer stereo. LED Bed lights on AOB Flux Capacitor Switch. Added AOB Spy Mode switch for TBD lighting, stay tuned.
    Changed the oil in my R155 transmission. When I bought the truck a couple years ago it seemed like it was leaking a bit from the output shaft. But it actually hasn't done that for several months, so I worried I was ridiculously low. I bought a new seal a while ago, but never got around to using it, so I figured I'd drain, change the seal and refill with redline MT90 all in one shot.
    Well, my puny arms couldn't get the driveshaft bolts loose from the differential flange (even with a cheater bar), so no output seal replacement for me. I went ahead and just filled the transmission anyway. I had no pump, so I filled it through the shifter. (And cleaned my shift boot to boot).
    I was pretty surprised that even though it was level, gear oil started dripping out of the fill hole when I pulled the plug, with that in mind it got me thinking, maybe it wasnt leaking from the seal after all, and actually leaking from the breather from being overfilled, it seemed oily up on top of there, too. I originally thought maybe it had stopped leaking because it just got too low and I was going to mess up my tranny if I kept driving like that. So I don't know what was going on.
    Upon filling it, it took 2.7ish quarts like the manual said it would before it started dripping from the fill hole. But when I emptied my oil pan, it only drained about 2.2 quarts, so I'm not sure how it was dripping out the fill hole and only drained 2.2 quarts, but took 2.7 new quarts to fill. I did spill some, but definitely not a half quart.
    Either way, it shifts fantastic and I don't have as much shudder anymore when I ease the clutch out like it did before. I wish I had done this sooner, it would have been a much more fun truck to drive.
    srspicer, DG92071 and Rick_Taco like this.
  7. Aug 4, 2020 at 8:39 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    If you replace the washer, it will be a full drain and fill. Take the fill plug off first before the drain. Just in case the fill plug causes you problem.
    Rick_Taco likes this.
  8. Aug 4, 2020 at 8:41 PM
    irayfz6
    irayfz6 TTC #0249
    Joey
    McAlester, OK
    2014 Black SR5 4x4 Access Cab
    Almost broken in
  9. Aug 4, 2020 at 8:47 PM
    tazgohome
    congrats and have fun with it.
    Taco-Obsessed[QUOTED] likes this.
  10. Aug 4, 2020 at 10:06 PM
    2DaMtns
    2DaMtns Well-Known Member
    2011 TRD Sport DCLB in MGM
    Lift, tires, stuff
    Went around a curve on a forest road and this happened. Got out and found it just like this.
    Five of the six lug nuts were lying in a circle just a few feet behind the truck. One lug stud was broken and I assume its nut is still on it. I got lucky. Just put sliders on a few weeks ago and had a hi-lift with me. Was just a matter of jacking it up and slapping the wheel back on and hauling ass home. Was on my way to check trail cams but abandoned the mission after this happened. Didn't want to tempt fate anymore by pushing my luck.
  11. Aug 4, 2020 at 10:25 PM
    magneticwhite88
    magneticwhite88 Well-Known Member
    Brandon
    OC, CA
    15' MGM Trd Off-Road
    Go buy a lottery ticket asap
  12. Aug 4, 2020 at 11:01 PM
    2DaMtns
    Lift, tires, stuff
    I didn't make a single stop on the way home! I was worried it was way worse before I got out. Heard a clunk and then it wouldn't move whether in drive or reverse. I thought the transmission had gone out. It was a rough patch of road and the truck stopped when the wheel fell off because I have an open differential. It felt like I got snagged on a rock or log. I panicked for a second when it wouldn't move. I still panicked a little when I saw it cause I figured I was gonna be walking.
    Weird thing was, all the lugs on the other rear wheel were loose too. Haven't had the wheels off since like Jan or Feb. Not sure if I shook the shit out of them (drove like 150 or 200 miles on unmaintained forest roads in the last two days) or someone sabotaged me. Odd situation all the way around.
    GonzoQuick and DG92071 like this.
  13. Aug 4, 2020 at 11:18 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    That is a trip. Hope it wasn't a sabotage. Be safe out there.
  14. Aug 4, 2020 at 11:39 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Someone tried to steal your wheels
    whatstcp, srspicer, Trikster and 3 others like this.
  15. Aug 5, 2020 at 1:49 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Now that the storm blew through (nice that I didn't lose power), I can really try and get some stuff done. Today it will be steering wheel install and hopefully replace my window weatherstrips on my doors, figure out the length I need to make the harness for my power mirrors, sound deaden both doors, install the power mirrors (not plugged in yet), and then maybe test fit my Buschwackers.
    I'm not doing anything Saturday except working on my truck so don't ask ;)
    Joker56ace and Cativelense like this.
  16. Aug 5, 2020 at 4:20 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    On a 2015? How often do you wheel? This scares me a little since I have a 2013.
  17. Aug 5, 2020 at 4:50 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    I'm about to go the pump out route myself.... I have not hit this with a torch yet, and another suggested hitting it with the torque gun TIGHTENING first then Loosening....
    But now i'm mostly just saving up to re-gear through ECGS and let them have the shell.....
  18. Aug 5, 2020 at 5:18 AM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I like to refer to the seen in Tommy Boy where he talks about taking a crap in the box and guaranteeing it. :rofl::rofl:
    Seriously though, if it helps you sleep at night. Then by all means go for it. I personally believe a warranty is a racket based on fear and I am probably 30-40k ahead because I have never bought one. I do most everything myself and what I do not feel up for, I know a guy or two.
    dborrer and Kuntrykid like this.
  19. Aug 5, 2020 at 5:34 AM
    Joker56ace
    Joker56ace Well-Known Member
    Florida
    2010 Trd or , dcsb pyrite mica
    Well i quess ill go check my lugs :fingerscrossed:, glad it worked out hopefully someone wasn't seeting you up for a quick grab and go
  20. Aug 5, 2020 at 6:20 AM
    DG92071
    DG92071 Well-Known Member
    I smoked my subs 6 days after installing them, lol.
