  1. Aug 8, 2020 at 2:08 PM
    tacokarl
    tacokarl Big Blue
    Karl
    Connecticut
    2008 Pre-Runner SR5 DCLB
    2nd grill re-fresh for my 08. Flat black with the splatter Toyota logo, I dig it. Ignore the dust from my neighbors 4 hour leaf blowing session this morning...
  2. Aug 8, 2020 at 2:33 PM
    jkauf
    jkauf Well-Known Member
    2013 Tacoma Supercharged - Stock
    ahh man, im slightly guessing based on if i got the 100ft rope to begin with. But i just measured the excess and if it was 100ft to start then for the section i did it was ~33ft. The rope wasnt any larger than 100ft to begin, so ~33ft max. Hope that helps. Also, i just youtubed paracord steering wheel cover, there are a couple different braids to choose from
    Acabsurf[QUOTED] likes this.
  3. Aug 8, 2020 at 2:55 PM
    Hemlock76
    Hemlock76 Member
    I've got the same one and had the same problems at first.
    The tailgate cable needs a bit of a break in time to adjust fitting around the assist. I also had to bend the mounting bracket about 2mm to let the cable fit on the outside.
    Now everything works great.
  4. Aug 8, 2020 at 3:41 PM
    Acabsurf
    Acabsurf Well-Known Member
    Alex
    San antonio, Tx
    2015 silver SR5 4x4
    Fabfour vengeance front bumper, XD series wheels. Leveling kit.
    For sure man,I appreciate it. I should ha e just YouTube haha. :anonymous:
    jkauf[QUOTED] likes this.
  5. Aug 8, 2020 at 3:51 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Installed my new to me decked system. I didn’t have all the parts for the install but ended up making two brackets to bolt to the bed and then made the shims out of a cutting board. Now I have to figure out how to bolt my second battery to it and then build my fridge slide. My dometic 75 barely barely fits up there but I have about 3/4” of room to mess with. I may have to take the cover off. I plan on building the slide as a drop slide and will start on that tomorrow. Due to the thickness I’m going to go 3/16 angle instead of my previous aluminum slide. That will also allow me to weld the locks on vs bolting them
    GonzoQuick, DECKEDUSA, dpele and 12 others like this.
  6. Aug 8, 2020 at 3:53 PM
    grdgz97
    grdgz97 Well-Known Member
    Georgetown, TX
    2015 TRD Sport DCSB
    New set of Falkens. :notsure:
    Kuntrykid likes this.
  7. Aug 8, 2020 at 5:38 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Replaced the clear wheel flare protector. Luckily the old film came off in one piece.
  8. Aug 8, 2020 at 6:00 PM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    I need to remove mine badly. 10 years old and looking dirty. Is this even worth it to replace?
  9. Aug 8, 2020 at 6:43 PM
    demogorgon217
    demogorgon217 Well-Known Member
    gordon
    Louisiana
    Gloria
    auto zone valve stem covers
    wait this is stock? i haven’t removed mine. they’re on the hood and behind each handle and they have dirty ass black lines going all the way down them. been contemplating removing them completely and cleaning the lines
  10. Aug 8, 2020 at 6:47 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Removed mine when I did the debadge before they could look like ass.
  11. Aug 8, 2020 at 6:52 PM
    The Wolves
    Los Angeles
    did you replace them as well or just take them off and never look back?
  12. Aug 8, 2020 at 9:12 PM
    dino41
    dino41 Well-Known Member
    San Diego, California
    2015 Sky Silver Crew Cab V6 SR5 Prerunner
    Pulled into Home Depot today and this happened.
  13. Aug 8, 2020 at 9:12 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Added some lockable rear cubbies, trimmed the weather stripping to fit the roof rack.. drove through a buncha flood waters a messed up my ac compressor :D
    My neighborhood is the worst flooding area of this entire part of Houston. Thankfully I am blessed to be able to really identify the leaking areas every other week!
    GonzoQuick, Rick_Taco, DocD and 6 others like this.
  14. Aug 8, 2020 at 9:17 PM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    I'm from Houston too. I can relate
    Beauxdon and will.i.was[QUOTED] like this.
  15. Aug 8, 2020 at 10:23 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    It's become way more common that I would prefer... I have to replace pulleys every year :bananadance::bananadead:
  16. Aug 8, 2020 at 10:26 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Link for the lockable cubbies you purchased?
  17. Aug 9, 2020 at 7:38 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Got one of the doors 75% done.
    Removed old parts, cleaned and waxed window opening, installed new window run weatherstrip, belt molding and power mirror, and cleaned the door glass.
    Found out I have a 6.5" speaker instead of the 6X9.
    I need to clay bar my door windows.
    GonzoQuick, DG92071, Sky and 14 others like this.
  18. Aug 9, 2020 at 7:46 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    "waxed window opening, installed new window run weatherstrip, belt molding"..... what did you Wax?and what material did you use? Thanks-
    I have been wanting to smooth out my window operations for a while now......
    I assume you sourced OEM parts from online...
  19. Aug 9, 2020 at 8:40 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Bought the new belt molding and weather strip from a local Toyota dealer. When I say wax, I meant the paint. I took a cleaner and wiped all the years of dirt away then waxed the paint before installing the new weatherstrip.
    dborrer[QUOTED] and Kuntrykid like this.
  20. Aug 9, 2020 at 10:02 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Got the other door 75% done. I say 75% because I still need to sound deaden the doors. I'm leaving the door panels off for now. Might put the Noico in tomorrow (if I don't have work) or next week.
    GonzoQuick and Cativelense like this.
