  1. Aug 12, 2020 at 3:26 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Although your use of large bold font is persuasive...
    Cheaper doesn’t mean better. It just means cheaper. Also noico being thicker doesn’t make it better either. I guarantee that the butyl rubber formula of dynamat is different. Feels denser, and is more malleable/workable. I suspect dynamat is more effective at vibration reduction because of it. Also the aluminum is thicker on the Dynamat. Which means when you are forcing into hard bends it doesn’t tear like the noico does using the little rubber roller.
    Noico being 1/3 cheaper means you get three times more of an inferior product. Is dynamat 3 times better? I guarantee it is not. But I am willing to bet money it is better.
    Working with both today, I will be buying more dynamat for my doors.
    GonzoQuick, DG92071, outxider and 2 others like this.
  2. Aug 12, 2020 at 4:12 PM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Tell me more about your extraction process.... i've hit mine with a 1050 HP electric torque gun and nothing..... its been soaked with PB Plaster multiple times... i'm about to just use a pump.....
    I did not make the mark in the drain plug.... not sure how that got there... but I didn't used to do my own maintenance either.....
  3. Aug 12, 2020 at 4:33 PM
    deekyn
    Dustin
    Yellowstone
    Word
  4. Aug 12, 2020 at 6:50 PM
    Coma_Overload
    Coma_Overload Active Member
    Pensacola, Florida
    2013 Tacoma TRD Off Road 4x4
    Fender Flares, Bumper Light Bar, Ditch Lights, Auxbeam 8 Control Switch, TRD Pro Grille, RetraxMax Tonneau Cover, 35s, RTT, Yakima HD rack, Road Shower, Fuel/Water containers, MaxTrax, Wet Okole Seat Covers
    Where did you buy it from?
  5. Aug 12, 2020 at 7:03 PM
    Coma_Overload
    Pensacola, Florida
    Nothing crazy. Just am apped on a new bike rack today. Fitment is tight. Between the LED light bar and the bed rack crossbars, I had to slide it under the rear rack crossbars but it works. Also slapped some locks in it.
    GonzoQuick, dpele, Rick_Taco and 2 others like this.
  6. Aug 12, 2020 at 7:05 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Swapped out the base Tokico rear shocks for 3rd gen OR Bilsteins. Rotated the tires while I was at it. Next is switching out the front suspension to the same.
  7. Aug 12, 2020 at 7:17 PM
    Coma 13
    Coma 13 Regular Guy
    Sambo
    Deep East Texas
    2013 Tacoma DCSB TRD OFF ROAD
    Rock chips and door dings
    I found it on ebay. I think the seller was Southland Toyota.
  8. Aug 12, 2020 at 7:41 PM
    DrMark
    DrMark Diet Mtn Dew & Guns
    Alabama
    2011 Tacoma PreRunner DoubleCab
    Please tell me you rescued them and abandoned the S-10 there...
  9. Aug 12, 2020 at 7:47 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    So excited to have installed my new topper this week. Wired up a 3rd brake light with a quick disconnect. Brake light is mounted to a small steel bar with rare earth magnets on the inside of the topper so, nothing permanent. Also wired and installed led lights underneath the bed rails. I didn't want to add the velcro to my tailgate so I added velcro to a magnetic strip and attached to the velcro on the inside of the back window. The magnet is not very strong, but holds it to the tailgate.
  10. Aug 12, 2020 at 8:00 PM
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    Changed out fluid in my rear diff, transfer case, and front diff. Used supertech full synthetic 75w-90.
    All plugs came out easily, except the front diff drain plug. Got it but it took some force. It's a little sloopy, so I'll definitely be replacing it next time.
    Old fluid looked pretty good. Truck is new to me as of May, so I didn't know how fresh the fluids were.
  11. Aug 12, 2020 at 8:05 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    What kind of magnets did you use? I did the Velcro and magnet strip too. I used this and it holds fantastically. Even at highway speeds.
  12. Aug 12, 2020 at 8:07 PM
    airmax233
    airmax233 Always ready for the next adventure
    Southern California
    12 PreRunnerTrd sport R.I.P 21 Tacoma Off road 4x4
    2.5 Kings w/resi Adj. Total Chaos Upper control arms. IG: Cement_runner23
    How do you clean the seatbelt?
  13. Aug 12, 2020 at 8:09 PM
    powder1134
  14. Aug 12, 2020 at 8:14 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Oh sorry I meant for the tailgate..
  15. Aug 12, 2020 at 8:21 PM
    powder1134
    Ah. It was something similar to what you used. Probably about 1/2" wide.
  16. Aug 12, 2020 at 9:12 PM
    TacoTuesday1
    SD CA
    is that a 2nd or 3rd gen topper?
    Looks like a 3rd gen due to the lower roof line
    I wonder if shortbed softoppers can be camped/slept in somehow
  17. Aug 12, 2020 at 9:16 PM
    stizo
    stizo Well-Known Member
    Roseville, CA
    15 DCSB TRD Sport 4x4
    Little maintenance today. New rubber should be arriving tomorrow and will be getting mounted Friday.
    BajaAsh, 13txtaco, Kuntrykid and 3 others like this.
  18. Aug 12, 2020 at 10:03 PM
    GMAN62465
    GMAN62465 Well-Known Member
    Gary
    Fairfield County, Connecticut
    2015 White DCSB Off-Road Plus
    There are a couple of options fro the DR750s @blackboxmycar.com... have a link to the one you purchased??
    Thank you in advance!
  19. Aug 13, 2020 at 12:17 AM
    BrashBrusier
    BrashBrusier Well-Known Member
    David
    Seattle, Wa
    '10 AC TRD OR
    Lots
    Just installed some amber Baja Designs rock lights.
    Engage spaceship mode? :thumbsup:
  20. Aug 13, 2020 at 1:43 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Made door harnesses for my power mirrors (still waiting on the pass. side mirror connector). I also made the harness that goes from the passenger door to the switch and driver door to the switch.
    Mapped out the wiring for the fuse boxes and going to start wiring those up later today.
    DG92071 and Cativelense like this.
