  1. Aug 23, 2020 at 7:49 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Added a Prinsu Access Rack today.
    Drilling 12 holes into your roof is quite terrifying, especially when they have to each be perfectly spaced.
    Next up is putting the cab strips back in and then a wash.
    7AEE40DA-FCD3-4E0B-AAE6-24307E3BDEB2.jpg FFA293D1-1426-469D-8B2E-CB47A2DE85E2.jpg
  2. Aug 23, 2020 at 7:51 PM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Grats!
  3. Aug 23, 2020 at 8:29 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Picked up a set of FJC steelies and mounted my 37s on them :cool:
  4. Aug 23, 2020 at 8:33 PM
    Mitch1967
    Mitch1967 Member
    Mitch
    2012 Tacoma Pre-Runner SR5
    None
    I gave my 2012 Taco a face-lift today. Installed new headlight assemblies and wrapped the chrome grill surround with carbon fiber vinyl.
    I will wrap the emblem another day. 20200823_140705.jpg Screenshot_20200823-205507_Messenger.jpg Screenshot_20200823-203525_Messenger.jpg 20200823_183616.jpg
  5. Aug 23, 2020 at 8:45 PM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    Replaced my radiator bushings. 5 years and 80k miles in, they were trashed. I’d like to do the cab ones soon.
    jkauf likes this.
  6. Aug 23, 2020 at 8:55 PM
    JR SLASH 33
    JR SLASH 33 Well-Known Member
    Josh
    Santa Barbara CA
    2010 Tacoma 2wd TRD Off Road
    Morel Virtus 603 3 Way Components in front JL RD900/5 5 Channel Amp in 3 Channel Bridged Mode (Front + Sub) Morel 6.5" Maximo Ultra Coax Speakers in Rear Doors JL MX280/4 4 Channel Amp in 2 Channel Bridged Mode (Rear) JL Stealthbox with 2 10" W1V3-4 Subwoofers Method Race Wheels 17x8.5" Baja Designs LED SAE Fog Lights GTR Lighting Ultra 2.0 LED Headlights
    Here are the results of adding peel and stick weather stripping from Amazon.
    Initial Goal:
    Reduce wind noise for a quieter ride on the highway.
    DB meter used: Extech SL510 (Accurate to + or - 1DB at 94DB 1k Hz)
    DB sound level meter settings:
    DBA not C
    Fast 125ms not Slow 1 second
    How I conducted the test:
    Each test sample was roughly 30 seconds at 65 mph on the highway.
    During each test, the sound level meter saves the highest and the lowest values. (ex. 72 DB A and 66.5 DB A)
    With these two numbers I calculated an average. (ex. 69.25 DB A)
    Once I got 10 test samples and 10 averages, I calculated THE average from the 10 averages.
    Note: In both tests, all of the doors, the back wall and the hood have all been sound deadened. So you might have better results if your car has not been sound deadened.
    Overall I saw 0.9 DB A drop. 67.4 down to 66.5. Not much of an improvement but, if you look at the highest measurements, they were significantly lower than before.
    Documents with all test samples available below.
  7. Aug 23, 2020 at 9:36 PM
    Dawdaw808
    Dawdaw808 Well-Known Member
    Dean
    Oroville, Ca
    06 Silver Tacoma
    3" pro comp
    Really not that bad. Was easier than I thought. Hardest part was probably beating the old carrier bearing off of the shaft and after about 10 minutes it finally came loose. Check out this video by kflo tacoma if you need any pointers. He even has torque specs included.
    https://youtu.be/IF9--WmZOYo
  8. Aug 23, 2020 at 9:48 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Nice setup!
  9. Aug 23, 2020 at 9:54 PM
    theolee
    Theo
    SAN DIEGO
    Do you have the link to actual product? I might look into this, thanks :thumbsup:
  10. Aug 23, 2020 at 11:01 PM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    BEEFCAKE :benchpress:
    Alexely999 and DG92071 like this.
  11. Aug 23, 2020 at 11:20 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    Refreshed front suspension and brakes...
    - New SPC UCA's
    - New OEM LCA's
    - 338mm 4Runner Rotors/Calipers/Pads
    - New Bearings
  12. Aug 23, 2020 at 11:57 PM
    JR SLASH 33
    Josh
    Santa Barbara CA
  13. Aug 24, 2020 at 12:12 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Wired my Aftermarket tag Lights & str8 fl3xed on the hood at midnight. Detailed my buddy’s car because he always helps me with truck projects. He has an insane 08 AWD 3 series with bigger turbos pushing over 500hp with a MT. It’s ridic. And totally a sleeper from the outside. Rear bumper is FS btw.
  14. Aug 24, 2020 at 12:16 AM
    theolee
    Theo
    SAN DIEGO
  15. Aug 24, 2020 at 1:13 AM
    JR SLASH 33
    Josh
    Santa Barbara CA
    yeah so they serve different purposes, the flat kind i used on the bottoms of all the doors, and the front edge of the front doors. And the B shaped kind goes on the bottom edge of the cab, between the front and back doors and behind the back doors. i was left with about 5 ft of the B shaped kind, and i used all of the flat kind.
    So i would get exactly what i ordered. It's so inexpensive anyways, a little extra could be used elsewhere anyways.
    theolee[QUOTED] likes this.
  16. Aug 24, 2020 at 1:16 AM
    theolee
    Theo
    SAN DIEGO
    Right on, thanks for the all the info :cheers:
    JR SLASH 33[QUOTED] likes this.
  17. Aug 24, 2020 at 1:23 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    CB install. I need to make the hole toward the front bigger and decide on a location for the mic jack. I have a 3' extension so I can put it somewhere around the third cup holder.
    JimIowa[QUOTED] likes this.
  18. Aug 24, 2020 at 2:58 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Cut off my X2o for some weight reduction.
    I need to wash my synthetic line sometime.
    irayfz6 likes this.
  19. Aug 24, 2020 at 5:03 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Cheapo Amazon 2 or 3 jaw puller (both work) makes the job even easier.
    Dawdaw808[QUOTED] likes this.
  20. Aug 24, 2020 at 5:17 AM
    ya_boi
    ya_boi Fishin' and Drinkin'
    Eastern Iowa
    2013 Tacoma TRD Sport DCLB
    Bilstein 5100 lift, Toytec 2" AAL, Bull Bar, Inno Roof Racks
    Added some lights from marketplace to the bar and swapped out fog lights from stock halogens to yellow LEDs this weekend. Swapped out cabin air filter while I was messing around.
    99kx250 and irayfz6 like this.
