  1. Sep 1, 2020 at 12:56 PM
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    308savage likes this.
  2. Sep 1, 2020 at 1:01 PM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    I gotcha I figured it was the same one that I had. Just a heads up when you’re installing it you may have to have a little super glue or better adhesive on hand. When I did mine the double sided tape supplied on it didn’t hold at all. I prepped the surface as well prior to installing.
  3. Sep 1, 2020 at 2:01 PM
    Rick_Taco
    Rick_Taco I'll do it myself
    Rick
    Indiana
    '13 DCSB 4WD Limited MGM 110K Miles
    Bird Dog RVM Bracket, Tint 20% all around, Spider Trax 1.250" wheel spacers K&N Drop in air filter Ram Mount A Pillar (And hard wire charging) Dual 2.4amp Charging USB LED Lower Center Dash Light Center Console Light Trailer plug moved to bumper Tonneau Cover Air Pump Filter Upgrade (UNI Filter) Ultimate reverse light upgrade (Phillips 18161) Anytime Fog Lights Blue LED shift light Nitto Ridge Grapplers 265/65/18
    I replaced the clutch on mine about a year ago. Its 2 snap rings, 8mm bolt and a 10mm bolt. The snap rings were kind of a pain but not to bad overall. You can also run a shorter belt to bypass it until you get it fixed. I ran mine like this for 3 months. Ill look up the length if you're interested.
    https://www.ebay.com/itm/AC-Complet...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
    FreshPots[QUOTED] likes this.
  4. Sep 1, 2020 at 2:04 PM
    EisenWill
    EisenWill Well-Known Member
    Will
    Shenandoah Valley
    2014 TRDOR DCSB
    RCI Aluminum Skids Alu-Cab Explorer Canopy
    F4E4DDC2-2BEE-4793-BFD1-C3BC4D1F7572.jpg Installed Bestop Supertop
  5. Sep 1, 2020 at 2:12 PM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    I just ordered one of these, hoping it shows up before the weekend. Can I assume you are talking about some double sided foam type tape?
    TacoTyusday[QUOTED] likes this.
  6. Sep 1, 2020 at 2:18 PM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    Sorry to hear it ... let me know how hard it is to replace
  7. Sep 1, 2020 at 2:18 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
  8. Sep 1, 2020 at 2:24 PM
    Man on the Moon
    Man on the Moon Member
    Annapolis, Maryland
    2015 Little Boy Blue DCSB OR MT
    Popped on some d rings, swapped the antenna for a shorty and gave him a good rinse.
  9. Sep 1, 2020 at 2:24 PM
    fasteddieyj
    Ed
    Hanover, PA
  10. Sep 1, 2020 at 2:56 PM
    Kombi
    Kombi Well-Known Member
    Zack
    08 Tacoma 97 Fjz80 01 Tundra
    I have seen the bed start to flex just due to the weight of a fiberglass canopy, We had a guy out with my landcruiser club whos bed split at the front behind the window on some rough roads due to a bunch of weight on his rack that didnt support it well enough.
  11. Sep 1, 2020 at 4:18 PM
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
    Finished installing BP-51s, Dakars, and SPC UCAs today. Also cleaned up alot of crusty paint and rust while everything was apart under there.
  12. Sep 1, 2020 at 4:28 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    51DC5FAB-36D9-4B6C-9E9F-600D7A9085C0.jpg Did a little more work on the stereo today. I’m going to remake the tweeter brackets but these are functional for now I’m also going to relocate the crossovers to inside the cab when I get the multi channel to power the 6 in the doors but these are surprisingly loud for only deck power. The low base notes are definitely lacking and overall it sounds a little unbalanced so I was going to do the back doors with a pair of coaxial then a 4 channel to power them then onto the sub to complete it but I think I will do the sub next. It’s been a fun project but quickly went over budget.
  13. Sep 1, 2020 at 4:29 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Wiring up some switches. Had to order terminals for the fuse boxes (making connections for future relays, easier to do it now).
    Ordered heat shrink. I ran out :oops:
    Also, my black bolts came in for my flares.
  14. Sep 1, 2020 at 4:30 PM
    TacoTyusday
    Zac
    San Diego
    how challenging is it to do the sound deadening? Did you do it when everything was still off the door? or after it was installed? guessing the former because of convenience.
    I got all my speakers done, but the truck is still pretty loud cruising on the freeway if my sound volume is turned down. would love to get it quieter, debating on doing it myself or having the guys who did my sound install it.
    JR SLASH 33 and kgarrett11 like this.
  15. Sep 1, 2020 at 4:33 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  16. Sep 1, 2020 at 4:47 PM
    $yoda$
    Tom
    2007 Tacoma 4.0
    it’s really easy just a little time consuming but not to bad. To be honest though I haven’t noticed a difference really but I did it for vibration dampening if you want to really reduce the noise you have to do the whole cab it will give you a little better sound quality from your speakers.
    GonzoQuick and kgarrett11 like this.
  17. Sep 1, 2020 at 4:53 PM
    TacoTyusday
    Zac
    San Diego
    hm okay...might hold off then lol.
    vibration dampening is basically useless for me because anything that can rattle is taped down, and my sub takes care of the rest lmao. was hoping i could get away with just doing the doors for significant improvement, but makes sense you'd want the whole cab. As i understand, the majority of the noise comes in from the floor and roof.
  18. Sep 1, 2020 at 5:26 PM
    ohiowa
    ohiowa Have you tried rebooting?
    Ohio
    2015 Super White TRD OR DCSB V6 6MT
    ARE Overland Shell
    In the past month or so:
    • Replaced front and rear differential oil with Red Line 75w-85 GL-5
    • Replaced transmission oil with Red Line MT90
    • Replaced transfer case oil with Red Line 75w-90 GL-5
    • Fluid Filmed anything I could reach. Extension kit coming in the next week or so.
    • Replaced spark plugs with K20HR-U11
    • Checked secondary breather filter to make sure my engine wasn't eating it
    • Installed @Baja Designs Squadron Sport yellow fogs
    Still waiting for Red Line D4 ATF to ship so I can flush power steering. Eventually I'll get around to a brake and clutch fluid flush.
    ~95,000mi
  19. Sep 1, 2020 at 5:29 PM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Das some purrdy parts ya go there :thumbsup:
    Jpiskura[QUOTED] likes this.
  20. Sep 1, 2020 at 5:55 PM
    JR SLASH 33
    JR SLASH 33 Well-Known Member
    Josh
    Santa Barbara CA
    2010 Tacoma 2wd TRD Off Road
    Morel Virtus 603 3 Way Components in front JL RD900/5 5 Channel Amp in 3 Channel Bridged Mode (Front + Sub) Morel 6.5" Maximo Ultra Coax Speakers in Rear Doors JL MX280/4 4 Channel Amp in 2 Channel Bridged Mode (Rear) JL Stealthbox with 2 10" W1V3-4 Subwoofers Method Race Wheels 17x8.5" Baja Designs LED SAE Fog Lights GTR Lighting Ultra 2.0 LED Headlights
    For the price and ease of install, I'd say its worth it. You probably won't notice a difference in road noise, but possibly in wind noise. There's much more solid feeling when closing the doors now, they feel much more air tight. Sometimes ill crack a window open before shutting my door when im getting in because it allows the air inside to escape. So for perceived quality alone, it's worth the $30 or so
    GonzoQuick likes this.
