  1. Oct 1, 2020 at 4:57 PM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    No it's the right way. Have you ever seen tape, wrapping paper, aluminum foil, plastic wrap, or anything else manufactured on a roll designed to tear off in the under over orientation?
  2. Oct 1, 2020 at 5:02 PM
    Pointeman
    Pointeman Well-Known Member
    Mark
    2013 Pyrite Mica Tacoma DCLB
    6" Fabtech Amp Research hydraulic steps Front Runner Cab Rack Leer 100xr topper w/rails 17” Black Rhino Warlords Dark Tint 295/70R17 Nitto Ridge Grapplers
    Hahaha I would be careful if I were you...if I did that to my wife eventually she would sneak in at an inopportune moment and take all the paper out of the room. The end result might be the same though because...it would be endless and I would be passionate...Just sayin’...I guess I’d rather have it come off the roll the wrong way than have it come of the roll the wrong way.
  3. Oct 1, 2020 at 5:06 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    You damn straight it is! Your ass still wipes the same I'm guessing. :crapstorm:
    catskinner likes this.
  4. Oct 1, 2020 at 5:50 PM
    pineymudder
    pineymudder Well-Known Member
    91 ext.cab 3.4 v6 / 13 sport ac 6speed
    3" body lift 33 12.50 km2 3.4 swap 4.88 gears lunchbox rear locker
    BigRus75, $yoda$, CraigF and 15 others like this.
  5. Oct 1, 2020 at 5:51 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    Installed new front bearing /hub assemblies. That eliminated the roaring noise I had found after getting the new and much quieter 35" ridge grapplers. Greased front balljoints, outer tie rods, and driveshaft u-joints.
    Also found an 8' roll of rubber seal on ebay to fill the gap between the Demello front bumper and the grille & headlamps since the 1" body lift install. Much cleaner looking now!
    BEFORE
    AFTER
    05Taco4x4, ARoman83, theolee and 13 others like this.
  6. Oct 1, 2020 at 5:54 PM
    Dmeezy333
    Dmeezy333 Well-Known Member
    2015 White Tacoma TRD Sport
  7. Oct 1, 2020 at 6:26 PM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    Finally installed the winch I purchased last black Friday and welded on some SOS Concepts bumper stud reinforcement plates. All in all looks pretty good and should be a lot more solid. It did increase the gap around the top edge and sides of the bumper where it meets the body.
    I cut a section out of the middle of the headlight/grill brace removing the angled bracket in order to make the with fit without having to relocate the control pack and made a couple of support braces to keep it solid.
    ARoman83, Casper66, TomTwo and 7 others like this.
  8. Oct 1, 2020 at 6:52 PM
    99kx250
    99kx250 Taco Bell king
    Joshua
    Arizona
    22 TRDOR
    Deaver+Icon AAL OME 885 springs Bilstein 5100s
    Does anyone know if you can stack 2 of the same size aal on top of each other in a leaf pack?
  9. Oct 1, 2020 at 7:13 PM
    Csaw
    Csaw Active Member
    2011 White Tacoma
    Got the lift, 4-6 in the front, with 4 in Maxtrac lift spindles and 5100 Billy’s set at 2 in. Only threw 2 inch blocks on the back, so might get the Dakar leaf springs eventually. 35 in Pro Comp tires on my XD FMJ wheels (no rubbing wtfff). I only drove it home, but so far she rides so good! She completes me (don’t tell wifey I said that)
    ARoman83, Casper66, TomTwo and 10 others like this.
  10. Oct 1, 2020 at 8:07 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Correct you do not have to use those uca. I just reused mines with no issues.
  11. Oct 1, 2020 at 8:26 PM
    Ren
    Ren Well-Known Member
    Denton, TX
    White 2012 Pre-Runner DCSB
    Helped my daughter move today.
    Yes, the truck is very dirty.
    ARoman83, TomTwo, GonzoQuick and 7 others like this.
  12. Oct 1, 2020 at 8:46 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Installed a Hooke Road Console Safe. Bolts right in. Seems good enough to deter vandals, and keep a handgun in. Bolts to the factory bolts in the center console, but I had to buy longer bolts. 40A067BC-32F8-4336-A145-84D21B0358C8.jpg31E87C51-3DC9-4180-ACBF-2150E283F63E.jpg
  13. Oct 1, 2020 at 9:42 PM
    patos tacoma
    patos tacoma Well-Known Member
    Could you send me a link to where you bought the cover with the us flag for the back gate, thanks
    jrlockman[QUOTED] likes this.
  14. Oct 1, 2020 at 9:49 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Yup, I have the same set up
    loyaltothetaco likes this.
  15. Oct 1, 2020 at 11:05 PM
    sh547m
    sh547m New Member
    Scott
    65E0C12C-F066-4974-8BDC-059E11786B02.jpg Had to post this. My other ride :headbang:
  16. Oct 1, 2020 at 11:28 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    how are you guys keeping the cocoon mounted? mine keeps coming off. I even used industrial strength Velcro.
  17. Oct 2, 2020 at 2:02 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    I used Gorilla heavy duty mounting tape. Cleaned both surfaces really well, laid down several strips of the tape, then mounted the Cocoon and sat 2 or 3 bricks on top of it. left it that way for about a week before reinstalling into the center console. I did that about 6 months ago and it survived a bunch of 90 degree plus days and is still holding on strong.
    https://www.homedepot.com/p/Gorilla-1-in-x-1-67-yd-Black-Heavy-Duty-Mounting-Tape-6055002/308910063
    GonzoQuick likes this.
  18. Oct 2, 2020 at 2:29 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    self tapping 3/4" screws
    Badderup likes this.
  19. Oct 2, 2020 at 2:32 AM
    fatfurious2
    David
    Ashburn, VA
    I re-used my sway bar brackets
  20. Oct 2, 2020 at 4:03 AM
    6Thick
    6Thick Well-Known Member
    Poconos
    2015 TRD Sport MGM 6MT
    TRD Pro Rims, BFKO2 265/70/17, ARE Shell, Leveling kit
    Oh yeah! This one. Love those TRD pro rims on the Tacomas.
