  1. Oct 20, 2020 at 8:22 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I recommend just selling them and buying a set of the Total Chaos ones (I have a pair for sale).
    Squatch_Taco[QUOTED] likes this.
  2. Oct 20, 2020 at 8:24 PM
    Squatch_Taco
    Squatch_Taco Founder of Team Overland
    Matthew
    Southern Oregon
    2014 Pyrite Mica Tacoma TRD "Squatch Edition"
    Performance: TRD Supercharger :D HP Tune using Overland Tailor Tuning with custom supercharged calibration. Cravenspeed Flex pod with Auto Meter Boost and Wideband A/F gauge. AFE Stage 2 CAI In House Fabrication Stainless Snorkel Aeroturbine 2525XL muffler, with rerouted crossover and chopped exhaust pipe Sierra 4.88 R&P gears for front axle Yukon 4.88 R&P gears for rear axle Power: CBI Group 31 battery cage Odyssey Group 31 extreme duty X2 Power AGM Battery 100W Overland Solar Panel Landstar Solar Charge Controller Redarc Smart Battery Isolator Busman Circuit Breaker Blue Sea aux fuse box (12) Blue Sea aux fuse box (6) Newport Vessels trolling motor smart battery box and power center with usb and DC ports Suspension & Brakes: Icon 2.5 EXT remote reservoir Coil-overs with 14" 700# springs (set at about 2.5 inches of lift) Camburg UCA's w/ moog balljoints Icon EXT VS 2.0 remote reservoir rear shocks Old Man Emu Dakar rear leaf pack Wheelers Superbumps front and rear Extended stainless steel rear brake lines Old Man Emu carrier bearing drop Sway bar delete All-Pro U-Bolt flip Power Stop Carbon Fiber Ceramic Disc Brake Pads Power Stop Drilled and Slotted Brake Rotors Power Stop Rear Break Shoes Interior: Expedition Essentials dash mount Rago Fabrication center console mount w/ Bridge Various RAM Mounts Dorman universal seat heaters Blue Sea Systems 4 volt dual USB port wired to constant power Weathertech (black) floorliners front and rear Bird Dawg industries rear view mirror riser Molle visor organizer OEM door sill protectors Salex console organizer Liviqily molle sun visor organizer Wet Okole seat covers front and rear (black) LED Map and Dome lights Kenwood Excelon DNX695S Double Din JL Audio C3 front door speakers JL Audio C2 rear door speakers JL Audio Stealth box w/ 1 10" sub Kenwood Excelon 5 channel 800w amp Navigation: Garmin inReach mini iPad mini 5th Gen Earthmate GPS App Gaia GPS MotionX-GPS Exterior: Outer Tents Osprey Slimline Aluminum rooftop tent Snugtop Rebel Sportsman Canopy Prinsu Cabrac Prinsu Top Rack Debadged Cravenspeed Stubby antenna Mud flap delete OEM bed mat "Hi-Lift" - Hi-Lift mount Color matched Satoshi grille from TW member StealthTaco BAMF bed tie downs 15% Tint on all door windows "Custom" trail pinstriping CVT 55" Summit Series awning in grey Cut fenders to clear 35’s Auto Ventshade Window Deflectors Lighting: AlphaRex USA 880752 Nova Series Full LED Projector Headlights Rigid SR 20 inch light bar Rigid Dually floods OTRATTW switches LED license plate lights Aurora Diffused 40w pods in rear bumper Wheels/Tires: (5) BFGoodrich Mud Terrain T/A KM3 35X12.5r17 (5) 17x8.5 SCS Ray 10's in matte dark bronze 4.30 BS Armor: BAMF Sliders w/kickout (weld on) Pelfreybilt steel plate bumper with center hoop and fog/LED bar cutouts Brute Force Fab High Clearance rear bumper (custom length side pieces) with swing out and double Jerry can holder and C4 Fabrication rear camera relocate Pelfreybilt steel IFS skid Pelfreybilt steel Mid skid Pelfreybilt steel T-case skid Recovery: Warn 9.5xps winch and Factor 55 1.0 Hawse fairlead Factor 55 Flat Link Warn Medium-Duty Epic Recovery Kit Misc ropes/straps Fiskers Axe Hults Bruk Axe 48" Hi-Lift Jack Hi-Lift Jack and Quick Fist Shovel Mount Fiskars Steel Shovel MaxTrax Boards and Mount ARB tire repair kit Smittybilt receiver hitch shackle Coms: Yeasu FTM-400DR Dual Band Ham Radio Uniden 510XL CB 3ft (offroad) and 2ft (in town) Firestik Tram 140MHz-170MHz + 430MHz-470MHz Dual Band NMO Antenna Baeofeng Handheld 2m radio Relentless Fab Passenger side antenna hood mount Relentless Fab driver-side antenna hood mount Misc mods: 12volt.solution Remote Starter DFG-Offroad fridge slide SnoMaster fridge Prinsu Fill Plates repurposed to mount fridge Gear Tech Customs wheel well liners Diff breather extension (behind taillight) Seat belt beep disable Door lock/Unlock beep disable ARB CMKA12 Onboard air compressor under the hood ARB inflation kit Anti-Dark underhood lights Redline QuickLift Plus hood struts Locker anytime mod Black "Team Overland" Trasharoo Big cab mount chop BFH massaged pinch weld Trimmed fender flares ECGS diff bushing Headliner patches #EAF CaliRaised Bedside stiffeners
    I thought about that but it would mean drilling more holes, unless the Total Chaos ones have the same bolt pattern. I just got a plasma cutter so I may just give that a shot. Do you know if the bolt pattern is the same for different stiffeners? My guess is no…
  3. Oct 20, 2020 at 8:35 PM
    DanaPtTaco
    DanaPtTaco Never-ending problems
    Thomas
    Orange County, CA
    07 ACLB Prerunner 4.0 AT
    Like others have said, with proper maintenance, it'd be very weird for it to not hit 200k or even 250k. Unfortunately for me, the previous owner decided he didn't like changing the oil too often so there was some carbon buildup that I didn't see until i had to replace the valve cover gaskets. It crapped out right at about 195k and I now have a remanufactured engine with a 2 year 20k mile warranty.
  4. Oct 20, 2020 at 10:10 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Right? The AC in my office here in Orange County was a little on the cold side today, I almost had to roll my sleeves back down. :)
  5. Oct 20, 2020 at 11:53 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    ha it’s like a young version of me... a red 240 hatch and a white tacoma... Ka or Sr?
    3NDLESS[QUOTED] likes this.
  6. Oct 20, 2020 at 11:58 PM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Pulled the engine! Decided v8’s are for losers gonna put the 4.0L back in.....
  7. Oct 21, 2020 at 7:49 AM
    MattDaddy
    MattDaddy Well-Known Member
    Matthew
    So-Cal
    2015 TRD OR AC 4x4 6MT
    Since I bought my truck used almost 3 years ago, the horn hasn’t worked. Sounds with the alarm, but not the wheel. So finally got around to replacing the clock switch last night. Pretty quick and easy, the hardest part was finding the tools in my mess of a garage. (Got the switch on eBay for about $15. Maybe just lucky I got a good one?)
    BFEB951D-FB59-41BF-B671-55153AF45670.jpg 171D69BD-9408-4A86-ACF1-AD5A6E23D13E.jpg
    Had a back up plan just in case it didn’t go back together.
    irayfz6, Csaw, loyaltothetaco and 2 others like this.
  8. Oct 21, 2020 at 7:58 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Picked up my new beef, Tcase skid and Trans skid (custom). 1/4inch with square tube gussets. :muscleflexing:[​IMG][​IMG][​IMG]
  9. Oct 21, 2020 at 8:17 AM
    imdickie
    imdickie Member
    Richard
    2013 Mica Access Cab Longbed
    None so far :)
    Bought it and started my needs to and wants to list which is already 25 items long.
    2013 Access Cab TRD 4x4 in Mica with a shell w/170k miles. Bone stock, 1 owner with documented oil changes ever 5k miles.
    Super stoked.
    Edited the year.
    Super tired from driving home last night
  10. Oct 21, 2020 at 8:28 AM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    you got a third gen if you have a 2016. This is the 2nd gen forum. Congrats on the new ride though!
    DG92071 likes this.
  11. Oct 21, 2020 at 8:58 AM
    cromag27
    cromag27 THE insurance expert - licensed in all 50 states
    dexter morgan (matt)
    phx-ish
    2011 trd off road dcsb
    tweaked my design a little.
    10C9C49D-4BAF-4107-9DAA-E39AA616F33D.jpg 431B79AE-C601-4010-9582-240639A72A61.jpg
  12. Oct 21, 2020 at 9:04 AM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Installed a snorkel I found for a fraction of the price of the name brand units.. I assume they are made from the same factory as the plastic is high quality and all components/couplers/worm clamps were included. Was an easy install. Time to go snorkeling
    Grumpy, irayfz6, Sideways1 and 6 others like this.
  13. Oct 21, 2020 at 9:12 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    O man thats rough! :luvya:
    DG92071[QUOTED] and G3Fab like this.
  14. Oct 21, 2020 at 9:19 AM
    Northbound_Taco
    09 Off road build
    We got 6 inches YEsterday in 10 hours. Im hoping it wont stick around to long.
    DG92071 likes this.
  15. Oct 21, 2020 at 10:02 AM
    MattDaddy
    Matthew
    So-Cal
    or did she say “I’m hoping it won’t stick around too long”?
  16. Oct 21, 2020 at 10:03 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I keep getting a dead battery since this is not my DD. Has anyone installed a Battery kill switch for this or theft deterrent purposes? Cant seem to find any threads in here on this
  17. Oct 21, 2020 at 11:05 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I don't see any warm temps on the horizon that will melt this crap until May. One day I was raking, the next day shoveling.
    Saw my turd gen buddy at Mickey D's today and gave him crap about his illegal front window tint like I always do.
  18. Oct 21, 2020 at 11:10 AM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    So I'm just starting to find mounts for my hi-lift with a softopper. They have to hang lower than most because of STopper. Did you make these or can you point me in the right direction. Thanks!
  19. Oct 21, 2020 at 12:53 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    Not installed just yet, but finally have them in hand. Still waiting on the rotors.
    question is....... leave them grey or get them powdercoated...... if so, what color?
  20. Oct 21, 2020 at 1:03 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Now that's funny !!
