  1. Oct 25, 2020 at 3:21 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I've used it a couple times and it worked fine. I need to check the charge on it actually. Did he try to jump a completely dead battery? It wont. You have to hold down the manual "override" button for three seconds for it to work in those situations.
    GonzoQuick likes this.
  2. Oct 25, 2020 at 3:23 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I don't know the particulars of the situation unfortunately, nor specifically what model he had or the state of his battery but I suspect it was fully dead.
  3. Oct 25, 2020 at 4:26 AM
    Key-Rei
    Key
    Florida
    R
    G
    B
    Under hood lights because I had a long enough strip left over from rainbow puking my computer and I didn't use the controller, so why the heck not?
    In white (Which shows up blueish on this camera) should be pretty handy.
    I just waterproofed the controller with epoxy, and hardwired the 12 volt input eliminating the barrel connector.
    I've had effectively the same setup for my bed lights for a couple years now. The greatest thing is you can still do rainbow puke rave strobe mode!
    dpele, CGoss, GonzoQuick and 4 others like this.
  4. Oct 25, 2020 at 5:32 AM
    grlnbear04
    grlnbear04 Well-Known Member
    2015 Tacoma TRD Sport Blue Robbon Metallic
    That is awesome....:bowdown:
    pilau[QUOTED] likes this.
  5. Oct 25, 2020 at 5:59 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    RC Vertex front and rear coilovers. I absolutely love these.
  6. Oct 25, 2020 at 6:37 AM
    Tacos4ever15
    Tacos4ever15 Well-Known Member
    2015 Pyrite Mica Tacoma TRD Off-road 4x4
    You can add this to your radio even if you didn’t have navigation ? Don’t have it on my 15, would like to have it.
  7. Oct 25, 2020 at 6:45 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Looks great! What made you choose this kit over the "bigger" brands? How's it ride?
  8. Oct 25, 2020 at 6:50 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    No. I didn't have navigation and had to buy a used radio (2015, because I wanted the clock on screen) and I had to to a lot of wiring.
  9. Oct 25, 2020 at 6:51 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    Tried to put a temporary band aid on my split cv boot. Pumped in some grease, wiped it down with some rubbing alcohol, smeared a bit of silicone over the split and wrapped the whole thing in a few layers of exterior grade duct tape. Certainly not looking at it as a permanent fix, just need to try and get a week out of it until I can install a new axle next weekend.
    winkel likes this.
  10. Oct 25, 2020 at 6:53 AM
    Tacos4ever15
    Ok, thanks.
  11. Oct 25, 2020 at 7:15 AM
    ARoman83
    ARoman83 Well-Known Member
    Alex
    Wisco
    '15 TRD OR DCSB PreRunner
    Only legal stuff
    Karma, karma, karma, karma, karma chameleon
    You come and go, you come and go
    Key-Rei and boogie3478 like this.
  12. Oct 25, 2020 at 7:18 AM
    MA_TACO
    Wesley Chapel, FL
    I did some research and after talking to a few people that have them I was like ok for about the price I paid for all four of these you only get 2 of the other brands so I figured why not. Plus they gave me a military discount. After I installed them I went for a spirited offroad test drive at the softest setting (there are 8 settings at the turn of the knob) and they soak up bumps like nobody's business. They are solidly built with billet parts so it was no brainer. The front struts are also height adjustable. RC really stepped up their game with these.
  13. Oct 25, 2020 at 7:31 AM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    :welder:
    llamasmurf[QUOTED] likes this.
  14. Oct 25, 2020 at 7:56 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    The Daystar cradles on the axel/leafs keep you from having to bolt the bottom of the airbag to the same plate. So as your suspension flexes, the airbags are free to move with it. When it comes back down, the bags rest in the cradle to give you support again. I have Dakar medium duty leafs in the rear already so without any air in the bags they already rest above the cradle a little bit. You apparently need to have at lest 5lbs in the bags though. Don't know if this still applies with the cradles. Probably will give me a smoother ride anyway. Need to get a better tire gauge because the regular one can't read something that low accurately.
    GonzoQuick and Key-Rei[QUOTED] like this.
  15. Oct 25, 2020 at 7:59 AM
    pilau
    pilau Well-Known Member
    Las Vegas, Hawaii
    2015 DCSB Tacoma PR
    i bought one, and left it in my truck incase friends family or random people needed a jump.... after a hot summer in 2018 the battery literally popped open... sent it back and bought jumper cables instead. if your climate permits, these things are awesome... jus be wary of heat
  16. Oct 25, 2020 at 8:16 AM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    To be honest this guy sold the bumper for me (3:26 is the key point with a bumper)
    https://youtu.be/9SueKHq6xv8
    The thing is pretty over built for the price, which I like. It is also designed to be integrated with the airbag system. ARB has been designing bumpers for a looong time on Toyotas too. The thing is on there good. 12 bolts from the mounting bracket to the frame and 10 bolts holding the bumper to the mounting bracket. The V4x4 does look really nice, I like how slim it is and it looks like you'll get a decent amount more approach angle compared to ARB. But that price point is kind of high for me to pull away from what you get with the ARB. Granted, the install was a hell of a process. Took me about 10 hours (including the winch) and I needed a buddy to help lift the thing up to be bolted on.
    So far, the downsides to the ARB on the tacoma: 1) no tow hooks on it. This also doesn't give me anything to attach the winch hook to when Im not using it. 2) The factory tow hook is a bit less accessible with the splash plate installed. 3) The winch and bolts to other things that are installed on the bumper are hard to access once the bumper is on.
    dpele, TOYTONKA, GonzoQuick and 2 others like this.
  17. Oct 25, 2020 at 8:26 AM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Just bought redline tuning hood struts with the group sale on here. I did get the elite & no carbon sleeves. Figured the red lettering would look good with my BRM. The group buy ends Nov 6 everyone. 15% off.
    Also bought a mountain hatch too. Got the all black less expensive one. My fucking knees can’t take it any longer!
  18. Oct 25, 2020 at 8:27 AM
    Kolter45
    Denver, CO
    He makes pretty decent videos! He’s on point with that Toyota Shirt too
    winkel and MasonSTL[QUOTED] like this.
  19. Oct 25, 2020 at 8:34 AM
    2013XSPX
    GA/FL Border
    2013 XSP-X
    Awesome. I'm looking at a full OME lift kit for 1600 (includes UCA'S and full leaf packs) but I'm open to other ideas. Who gave you the discount? I wonder if Black Friday will have some good deals....
  20. Oct 25, 2020 at 8:55 AM
    MasonSTL
    Green Bay, WI
    06 TRDOR AC MT
    for sure. I guess he was a tech for toyota, so I'll listen when he says something works well with a toyota over someone who has a Jeep with a tire wall ratio less of than 60%
