  1. Dec 12, 2020 at 1:04 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    New idlers all around and a new belt. #1 and the tensioner idler sound like the bearings are made of granola when I spin them in my hands... Annoying squeak gone.
    I went with Gates pulleys from @RockAuto and was pleased with the quality. The parts were made in Canada and had good name brand dual-shielded bearings in them. I used
    If you're replacing one, might as well replace them all, and as far as the tension arm being bad, it's relatively rare for the actual arm to go bad as opposed to just the pulley.
    In my case, I checked before ordering by getting under the truck with a 14mm socket on a short breaker bar and torqueing counter-clockwise on the idler pulley bolt to check the strength of the arm, and it was fine. It took two hands (at an awkward angle) to fully exercise the tensioner. I have no idea what the scientific numbers are for that, but I was satisfied that the actual arm was A-OK.
    Beware that the tension arm idler pulley goes on with reverse threads, and also that the GATES 36174 has slightly different dimensions that the OEM tension arm idler pulley. You can source a longer reverse thread bolt if you want, but I (and many others) simply ended up taking the bushing that comes with the GATES 36174 and putting it into the front of the pulley, then re-using the factory bolt. This will center the bolt in the pulley bore correctly, and the factory tension arm mount point has a mating surface that meets the rear face of the bearing correctly for a mechanically sound mount.
    Since the bearing is shielded on the back, it is not of serious concern to not use the supplied dust shield. If you do try to use it, or to put the bore spacer on the back, it moves the pulley farther forward than the OEM part relative to the path of the belt, which may cause issues with the edge of the belt running off the back of the pulley.
    Torqueing it to the correct value was a bit of a pain since my torque wrench wouldn't fit in order to tighten to spec (since the threads are reversed and the tensioner moves clockwise, you're fighting against the travel of the tensioner while tightening), so I tightened with a socket just until the tensioner started moving CCW and then checked in "reverse" (CW) with the torque wrench. It took two tries to get it within 1 lb of spec, and I called that good.
    billnye1999, irayfz6, DG92071 and 7 others like this.
  2. Dec 12, 2020 at 1:25 PM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    On my to do list pretty soon.
  3. Dec 12, 2020 at 1:37 PM
    deanosaurus
    deanosaurus Caveman
    Northeast Region
    09 TRD OR AC
    It's not bad at all. It took about 2 hours for the 4 including getting the belt back on, and I've never done this job on the 1GR-FE before.
  4. Dec 12, 2020 at 1:39 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  5. Dec 12, 2020 at 1:43 PM
    Andy Standard
    Andy Standard To the Window, to the Mall. All the Tacomas Crawl
    California
    2011 TRD Sport 4x4
    Relentless Fabrication Hybrid Front Bumper, Sliders from Ghost Ship, Brute Force Fab High Clearance Rear Bumper, OEM Roof Rack, BedSlide S, Billie Bars, TuffStuff 4x4 Alpha II RTT, Countersteer X from FN Wheels, Nitto Ridge Grapplers in 285/75-17, Weathertech digital floor mats, FX-R retrofit projectors with 5000k HID, BD S8 30in bar, Diode Dynamics SS3 Pro, G4 Elite cover, Wet Okole seat covers, Flyzeye LED light, Bed Light LED kit, All in one key from Neneago
    Installed the @BillieBars today. Had the brackets on but there was a gap on all sides of my tonneau cover so had to wait until a Home Depot trip to get these weather strips and now they fit perfect. Preordered a RTT for February to put on top of these beefy bars.
    MN-Taco, irayfz6, DG92071 and 7 others like this.
  6. Dec 12, 2020 at 1:46 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Yes! You nailed it! Thank you Josh
    :cheers:
    DG92071 and JdevTac[QUOTED] like this.
  7. Dec 12, 2020 at 2:11 PM
    michiganoutside
    michiganoutside Member
    Drew
    2014 BRM TRD Sport 4x4
    First “mod”. Used the loose rubber on the wipers as an excuse to replace both OEM wipers with Trico Force ones (O’Reilly has a sale). Just got it on Wednesday. Saved the intact passenger side OEM wiper as a spare.
    Anthony 82, irayfz6, DG92071 and 2 others like this.
  8. Dec 12, 2020 at 2:38 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
    You my friend are screwed! :spending:
    outxider[QUOTED] and 771Doug like this.
  9. Dec 12, 2020 at 2:42 PM
    Gen2Tacoma
    North East Atlanta
    I like the color I have one too! Sharp truck right there!
    fasteddieyj[QUOTED] and sbu249 like this.
  10. Dec 12, 2020 at 2:45 PM
    771Doug
    771Doug Well-Known Member
    Virginia Beach, VA
    '08 V6 Pre-Runner
    Nice work! :thumbsup:
    Strictlytoyz[QUOTED] likes this.
  11. Dec 12, 2020 at 2:49 PM
    sbu249
    sbu249 Well-Known Member
    Rhode Island
    2012 Pyrite Mica TRD Sport
    love that pyrite mica, same here, thinking about a cap but move too much crap. Sweet ride!!
    fasteddieyj[QUOTED] likes this.
  12. Dec 12, 2020 at 2:53 PM
    Gen2Tacoma
    North East Atlanta
    That's why I have a Softopper! Just say'in!
    sbu249[QUOTED] likes this.
  13. Dec 12, 2020 at 2:56 PM
    fasteddieyj
    Ed
    Hanover, PA
    Thanks guys. Didn't buy it for the color but definitely like it.
  14. Dec 12, 2020 at 2:57 PM
    sbu249
    Rhode Island
    How’s it do in snow? See you’re in hotlanta but just curious
  15. Dec 12, 2020 at 3:01 PM
    Gen2Tacoma
    North East Atlanta
    I'm so glad this thread came back alive I'm simply tired of the turd gen threads! Just as a rule of thumb that is! :crapstorm:
    sbu249 likes this.
  16. Dec 12, 2020 at 3:02 PM
    sbu249
    Rhode Island
    I can’t do the new colors, Home Depot orange or stapler grey? Maybe OD green but the rest are a nope for me. Trying to get to 300k and then I’ll consider a new truck
  17. Dec 12, 2020 at 3:04 PM
    Hippiglass
    Hippiglass Well-Known Member
    riverside ca
    2012 tacoma sport DCSB
    DTF race kit, DTF front bumper, king 10"dual rate shocks, URD CAI, total chaos upper control arm brackets, method race wheels, 35/12.5/17 bfg ko2, mcneil TT bedsides, custom SLX Motorsports front fenders, fox bump stops
    took out the tiny 6.5 rear speakers and installed some 8" mids.. also woking on a amp rack for the subs and door speakers under the back seat..20201208_185535.jpg 20201211_204452.jpg
  18. Dec 12, 2020 at 3:05 PM
    Gen2Tacoma
    North East Atlanta
    No snow here but definitely don't want to roll up or collapse in cold weather.....from what I've read. If your rear window is older it can crack.... again from what I've read on here. Never had a problem being in Atlanta. If it gets down to freezing just let it sit until about 1:00 PM.
  19. Dec 12, 2020 at 4:20 PM
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Lift, wheels, and a Apple carplay stereo. That's it! :anonymous:
    GonzoQuick and DG92071 like this.
  20. Dec 12, 2020 at 4:37 PM
    Gen2Tacoma
    North East Atlanta
    Sure then your'e done right! NOT Likely! :anonymous:
