  1. Dec 19, 2020 at 12:56 PM
    Taco-Obsessed
    It's been a while seen I did my my lights, but don't the instructions say to have the Morimoto ballast vertical? Pretty sure that was what the instructions said that came with my harness. Perhaps it is not a big deal either way? Dunno.
    Squatch_Taco[QUOTED] likes this.
  2. Dec 19, 2020 at 12:58 PM
    Squatch_Taco
    Squatch_Taco Founder of Team Overland
    Matthew
    Southern Oregon
    2014 Pyrite Mica Tacoma TRD "Squatch Edition"
    Performance: TRD Supercharger :D HP Tune using Overland Tailor Tuning with custom supercharged calibration. Cravenspeed Flex pod with Auto Meter Boost and Wideband A/F gauge. AFE Stage 2 CAI In House Fabrication Stainless Snorkel Aeroturbine 2525XL muffler, with rerouted crossover and chopped exhaust pipe Sierra 4.88 R&P gears for front axle Yukon 4.88 R&P gears for rear axle Power: CBI Group 31 battery cage Odyssey Group 31 extreme duty X2 Power AGM Battery 100W Overland Solar Panel Landstar Solar Charge Controller Redarc Smart Battery Isolator Busman Circuit Breaker Blue Sea aux fuse box (12) Blue Sea aux fuse box (6) Newport Vessels trolling motor smart battery box and power center with usb and DC ports Suspension & Brakes: Icon 2.5 EXT remote reservoir Coil-overs with 14" 700# springs (set at about 2.5 inches of lift) Camburg UCA's w/ moog balljoints Icon EXT VS 2.0 remote reservoir rear shocks Old Man Emu Dakar rear leaf pack Wheelers Superbumps front and rear Extended stainless steel rear brake lines Old Man Emu carrier bearing drop Sway bar delete All-Pro U-Bolt flip Power Stop Carbon Fiber Ceramic Disc Brake Pads Power Stop Drilled and Slotted Brake Rotors Power Stop Rear Break Shoes Interior: Expedition Essentials dash mount Rago Fabrication center console mount w/ Bridge Various RAM Mounts Dorman universal seat heaters Blue Sea Systems 4 volt dual USB port wired to constant power Weathertech (black) floorliners front and rear Bird Dawg industries rear view mirror riser Molle visor organizer OEM door sill protectors Salex console organizer Liviqily molle sun visor organizer Wet Okole seat covers front and rear (black) LED Map and Dome lights Kenwood Excelon DNX695S Double Din JL Audio C3 front door speakers JL Audio C2 rear door speakers JL Audio Stealth box w/ 1 10" sub Kenwood Excelon 5 channel 800w amp Navigation: Garmin inReach mini iPad mini 5th Gen Earthmate GPS App Gaia GPS MotionX-GPS Exterior: Outer Tents Osprey Slimline Aluminum rooftop tent Snugtop Rebel Sportsman Canopy Prinsu Cabrac Prinsu Top Rack Debadged Cravenspeed Stubby antenna Mud flap delete OEM bed mat "Hi-Lift" - Hi-Lift mount Color matched Satoshi grille from TW member StealthTaco BAMF bed tie downs 15% Tint on all door windows "Custom" trail pinstriping CVT 55" Summit Series awning in grey Cut fenders to clear 35’s Auto Ventshade Window Deflectors Lighting: AlphaRex USA 880752 Nova Series Full LED Projector Headlights Rigid SR 20 inch light bar Rigid Dually floods OTRATTW switches LED license plate lights Aurora Diffused 40w pods in rear bumper Wheels/Tires: (5) BFGoodrich Mud Terrain T/A KM3 35X12.5r17 (5) 17x8.5 SCS Ray 10's in matte dark bronze 4.30 BS Armor: BAMF Sliders w/kickout (weld on) Pelfreybilt steel plate bumper with center hoop and fog/LED bar cutouts Brute Force Fab High Clearance rear bumper (custom length side pieces) with swing out and double Jerry can holder and C4 Fabrication rear camera relocate Pelfreybilt steel IFS skid Pelfreybilt steel Mid skid Pelfreybilt steel T-case skid Recovery: Warn 9.5xps winch and Factor 55 1.0 Hawse fairlead Factor 55 Flat Link Warn Medium-Duty Epic Recovery Kit Misc ropes/straps Fiskers Axe Hults Bruk Axe 48" Hi-Lift Jack Hi-Lift Jack and Quick Fist Shovel Mount Fiskars Steel Shovel MaxTrax Boards and Mount ARB tire repair kit Smittybilt receiver hitch shackle Coms: Yeasu FTM-400DR Dual Band Ham Radio Uniden 510XL CB 3ft (offroad) and 2ft (in town) Firestik Tram 140MHz-170MHz + 430MHz-470MHz Dual Band NMO Antenna Baeofeng Handheld 2m radio Relentless Fab Passenger side antenna hood mount Relentless Fab driver-side antenna hood mount Misc mods: 12volt.solution Remote Starter DFG-Offroad fridge slide SnoMaster fridge Prinsu Fill Plates repurposed to mount fridge Gear Tech Customs wheel well liners Diff breather extension (behind taillight) Seat belt beep disable Door lock/Unlock beep disable ARB CMKA12 Onboard air compressor under the hood ARB inflation kit Anti-Dark underhood lights Redline QuickLift Plus hood struts Locker anytime mod Black "Team Overland" Trasharoo Big cab mount chop BFH massaged pinch weld Trimmed fender flares ECGS diff bushing Headliner patches #EAF CaliRaised Bedside stiffeners
    honestly I didn’t look at the directions. I will and if it does say that I’ll move it. Thanks for letting me know! :cheers:
    Taco-Obsessed[QUOTED] likes this.
  3. Dec 19, 2020 at 1:03 PM
    Taco-Obsessed
    For what it is worth, make sure to wire everything good and sturdy so it doesn't move around at all the connection points. I didn't do a perfect job the first time and one and eventually both headlights wouldn't turn on, sporadically, unless I popped the hood and wiggled them (probably bounced around from wheeling offroad). Finally redid everything, cleaned the connections with electrical cleaner, and added dielectric grease to all connection points. Been solid ever since. Because I wheel and my shit bounces around I will always use dielectric grease for my connection points moving forward (eventually adding light bar, etc; locker before lightbar :D).
  4. Dec 19, 2020 at 1:06 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Cut off the ridiculous excess bolt threads on my Wheeler's U-Bolts. It's not very pretty but at least I'm not making corn rows now either. I torqued them down to 70 lb/ft since it's unclear exactly what these things are supposed to be at. Added an AJT Design black emblem too for good measure. :thumbsup:
    NavyDiver72, GRNT4R, 13txtaco and 4 others like this.
  5. Dec 19, 2020 at 1:19 PM
    Taco-Obsessed
    They are ridiculously long. I had to cut mine down that came with my u-bolt flip kit.
    Tacoma13_NC[QUOTED] likes this.
  6. Dec 19, 2020 at 1:25 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    To accommodate larger aftermarket leaf packs, I believe. Imagine trimming those to fit on a stock leaf pack lol
  7. Dec 19, 2020 at 1:31 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Dropped my boy and friend's off for a little downhill fun.
    Timgx77, GRNT4R, whatstcp and 14 others like this.
  8. Dec 19, 2020 at 1:31 PM
    Taco-Obsessed
    I get it, just think they should sell different sizes versus the longest set for all size leaf packs. They were extremely long for my medium Dakars before I upgraded to Deavers. A lot of us will cut them down, but I presume some of their customers are not comfortable doing so.
  9. Dec 19, 2020 at 1:35 PM
    Tacoma13_NC
    I had 2.5 inches of thread after the nut. I couldn't even get a deep socket on to check the torque.
  10. Dec 19, 2020 at 1:38 PM
    Taco-Obsessed
    I had so much my flipped u-bolts would hit the frame before the super bumpstop would fully compress.
  11. Dec 19, 2020 at 1:46 PM
    Tacoma13_NC
    They're great U-Bolts, would just be nice to have the option of shorter ones so we don't need to go through cutting them off. After torquing mine down more, I've lost more vibration in the drivetrain. Was probably getting some axle wrap because if it.
  12. Dec 19, 2020 at 1:55 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    Anyone run into the problem of having their trip-meter stuck on 'Trip A' and not be able to change it to the
    'OD' setting, is there a fix? Is this a symptom of a larger issue like the cluster getting ready to fail?
    DG92071 likes this.
  13. Dec 19, 2020 at 2:01 PM
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Be ready to move mine sold in 1 day full cash offer no closing costs8D5D5FB8-0A60-4864-B5E4-7762A998D4B7.jpg
  14. Dec 19, 2020 at 2:03 PM
    DG92071
    DG92071 Well-Known Member
    Hilarious picture! Thanks!
    We buy, sell, trade, part out, and repair boats.
    Turdyota3000 and Z7Xtreme like this.
  15. Dec 19, 2020 at 2:16 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Built some bed bars for my new rtt. The goal was low and easy access to my bed still since the tent is so narrow. I’m very pleased with it.
    7F519CAE-D827-4F73-9E70-560216F2E873.jpg 32FEFD99-3630-48F1-9A58-C7B1E78A276E.jpg 4BDFC0AF-6F79-4D07-BCFE-D9B9B8A53ACD.jpg C0A27398-EFB9-47C4-AFEA-799F7D1F88D1.jpg BC42CD73-402E-45B2-B83B-2AB31FAA7CFF.jpg
  16. Dec 19, 2020 at 2:36 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Jacked Burton likes this.
  17. Dec 19, 2020 at 3:07 PM
    HIghlande2
    HIghlande2 Well-Known Member
    Wilmington, NC
    15 DCSB Sport
    Little of this and a little of that
    Looks awesome man!!!
    IvanhoeTaco[QUOTED] likes this.
  18. Dec 19, 2020 at 3:08 PM
    HIghlande2
    Wilmington, NC
    15 DCSB Sport
    Crappy pic but installed some new retrofits from Kustom54
    T.Barn, SliMbo4.0, Kuntrykid and 11 others like this.
  19. Dec 19, 2020 at 3:20 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    In hindsight I REALLY wish I went with them for my headlights as opposed to having someone here on TW make them.
    lynyrd3 and HIghlande2[QUOTED] like this.
  20. Dec 19, 2020 at 3:20 PM
    SalmonTaco
    SalmonTaco Well-Known Member
    Andrew
    Naches
    08 Silver TRD Sport
    Brute Force bumpers, TRD FauxLocks, 5100s & 885s, Falken Wildpeaks, SnugTop MVP Shell, Tuffy Bed Box, Console Vault, Fogs anytime, ImMrYo mirror bracket, Wet Okoles, aFe Pro Dry S, PowerStop Z36 pads & drilled/slotted rotors, more shit I can't remember
    I changed my oil (Mobil 1 full synthetic 5w30), banged off/blew out my afe air filter, filled my windshield washer reservoir with Rain-X orange sauce, replaced a burnt out license plate bulb.
    Need to order more OEM drain plug gaskets, used my last one.
    SliMbo4.0, lynyrd3 and JimIowa like this.
