  1. Jan 2, 2021 at 10:04 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I need the exit airflow for when I’m in the dunes and the summer. But want to keep the rain out during the winter.
    Slashaar and TodayWasTHeDaY like this.
  2. Jan 2, 2021 at 11:52 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Fair enough. I guess I just figured since when you drive in the rain the engine bay gets pretty soaked anyways I wouldn't bother plugging them if I had them. Looks really clean though. Good job! :thumbsup:
  3. Jan 3, 2021 at 1:22 AM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    Brand?
  4. Jan 3, 2021 at 5:33 AM
    jahulgan
    jahulgan There and Back...
    James
    Central Georgia
    '09 SBDC Green TRD Off-Road 4x4
    Old Man Emu 886 Springs, 255-85-16, ARB Front Bumper w/ Warn 8K Winch, SOS Sliders, Custom Skid Plates
    Definitely not brittle. Not sure on the specific filament. I'll see if I can find out.
  5. Jan 3, 2021 at 5:38 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    If it bends and springs back, it's probably PETG, which is fine for outdoor/elements exposure. The only thing I would tell you is to coat it with a thin layer or two of epoxy resin for enhanced protection against rain/humidity/sun. PLA would be very stiff, and at times, brittle after UV exposure, and would simply start to melt away after the first year or so in the rain/heat/humidity of Georgia.
    ABS would also be stiffer, but would be okay too (I'd still post-process it with epoxy resin).
    Trikster and Key-Rei like this.
  6. Jan 3, 2021 at 5:38 AM
    Key-Rei
    Key
    Florida
    That would be cool to know. :thumbsup:
  7. Jan 3, 2021 at 6:15 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    where is it leaking from?
  8. Jan 3, 2021 at 6:46 AM
    Key-Rei
    Key
    Florida
    You sure it wasn't your AC condensation drip line that was plugged causing the leak? I've been in water over my headlights and never had my passenger floor get wet.
    Well, not until I got stuck and sat in water just an inch over my door seal for 10 minutes.
    Island Cruiser likes this.
  9. Jan 3, 2021 at 7:43 AM
    robm7
    robm7 Well-Known Member
    2012 TRD OR
    so far so good
  10. Jan 3, 2021 at 8:42 AM
    jahulgan
    James
    Central Georgia
    It is PLA-based filament approved for UV outdoor use.
    Slashaar and Key-Rei[QUOTED] like this.
  11. Jan 3, 2021 at 9:05 AM
    cdex8357
    cdex8357 “Everybody gotta die sometime”
    “Dex”
    H-Town
    2013 Taco OR
    Mid travel FOX 2.5 Coilovers FOX 2.5 secondary bypass FOX 12” Triple Bypass
    What brand/model is this ? Look bad ass
    Kuntrykid and verynearlypure like this.
  12. Jan 3, 2021 at 9:23 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    Yeah my truck lives outside most the time so just trying to stop water from raining straight down in all the time. And the latches are by aerocatch.
  13. Jan 3, 2021 at 9:33 AM
    kona2chris
    kona2chris Well-Known Member
    Vancouver BC
    Silver 08 Tacoma Doublecab SR5
    FX Pro Wheels (Dark Gunmetal Grey Gloss) Falken WildPeak AT AT3W 265/70R17 OME 2" Lift kit Kenwood DNR1007XR - 10.1" GPS / Multimedia W/backup Camera Remote starter and CompuStar alarm Baja Design Squadron Sport Fog Pocket Light Kit (Wide cornering) Leer canopy Bedrug Thule Roof Kayak Racks Thule Swing away bike rack Engine 2.0 installed at 270k
    It’s the Kenwood DNR1007XR 10.1” - so far I really like it.
    verynearlypure likes this.
  14. Jan 3, 2021 at 9:34 AM
    kona2chris
    Vancouver BC
    Bratwurzt and Beauxdon[QUOTED] like this.
  15. Jan 3, 2021 at 9:36 AM
    kona2chris
    Vancouver BC
    Cabin air filter intake I believe.
  16. Jan 3, 2021 at 10:53 AM
    patos tacoma
    patos tacoma Well-Known Member
    I went thru this.......
    Ended up cleaning the drains on both sides from leaf buildup.....you have to remove wheel well liner.....because water would go over AC intake......
    Then,
    Put a cover over AC intake, with side openings (mod explained on TW), because I had windshield replaced, and the cowl cover seal was not tight against windshield so water would come into to AC intake........also bought a new cowl cover......
    the water leak, ruined my AC blower and Cabin Air filter.........
    also did AC drain tube mod........(mod explained on TW)
    no more water issues.
    kidsmoke, DG92071 and JimIowa like this.
  17. Jan 3, 2021 at 11:01 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Got as far as I can get on my lift without the new A arms and alignment cams/bolts.
    Installed the wheelers +4" brake lines and bled the brakes. The fittings on the hard lines are now round, vice grips did work on them but got it done. Found one of my bleed nipples was pretty stuck, had to work it back and forth to get it back to bleed-able form.
    Installed Toytec sway bar drop kit, installed new grease-able sway bar end links since I popped the boots when removing them.
    Took off my softopper to re-weather seal the bars. For some reason mine got sticky and stuck to my bed rack bars ripped up when I was removing them.
    Removed my bedrack mounts for re-coat when I coat my skids.
    As soon as these A-arms and cam bolts get delivered its time for the front lift and UCA's. I will admit with the lift it was much easier to sit under the back end while installing the brake lines.
  18. Jan 3, 2021 at 11:24 AM
    verynearlypure
    verynearlypure Clean & Decent
    Ernest
    The Buckeye State
    2015 BRM DCSB TRD OR
    Ray 10’s & Basic Bastard Goodies
  19. Jan 3, 2021 at 12:16 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    Finally fixed my backup camera that was fubar when the frame was replaced and also labeled the cables for future reference. Now, if I could just figure out how to install a front anytime camera.
    GRNT4R, Kuntrykid, GonzoQuick and 2 others like this.
  20. Jan 3, 2021 at 12:38 PM
    arctic04trd
    arctic04trd VA7XTE
    British Columbia
    2010 DCLB
    Oil change....and removed aluminum steps, prepping for sliders. Hit 300,000 a couple days ago.
    :eek:
