  1. Jan 3, 2021 at 4:36 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have a fridge but honestly, I didn’t need solar. I just capitalized on an opportunity. My wife wants the driveway back but the truck is plugged into a trickle charger there. I told her if I got solar, I could park in the street. She agreed, and here we are.
  2. Jan 3, 2021 at 4:58 PM
    Badderup
    Badderup Well-Known Member
    Colby
    Utah
    2006 SWB TRD sport DCLB
    Wish that would work on my wife.
    EatSleepTacos[QUOTED] likes this.
  3. Jan 3, 2021 at 5:09 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    Gave ol reliable a decent wash this weekend. Trying to decide what to purchase first, rear bumper (trail gear) winch or sliders
  4. Jan 3, 2021 at 6:07 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
  5. Jan 3, 2021 at 6:41 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    Santa? :spy:
    AugustaTaco and crashngiggles like this.
  6. Jan 3, 2021 at 6:51 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    Yes I am.
  7. Jan 3, 2021 at 6:54 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    I always knew Santa drove a Tacoma!
  8. Jan 3, 2021 at 7:26 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I vote sliders
  9. Jan 3, 2021 at 7:50 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    This cover mod or did you actually put something else over it like a solid plastic "shoe box" lid?
    https://www.tacomaworld.com/threads/cabin-air-intake-screen-mod.566441/
    GonzoQuick likes this.
  10. Jan 3, 2021 at 7:52 PM
    Key-Rei
    Key
    Florida
    What panel/output is that? I want to add solar.
    kgarrett11 likes this.
  11. Jan 3, 2021 at 7:55 PM
    Key-Rei
    Key
    Florida
    They make the flip up license plate bracket too?
  12. Jan 3, 2021 at 8:05 PM
    patos tacoma
    patos tacoma Well-Known Member
    That is a great mod, DID the screen, but the screen is mostly against rodents making a home in your cabin filter. and my Taco lives outside in a forest.
    I also put a piece of sheet metal , rounded between the bottom of the windshield trim and the cowl edge, glued in, for rain water protection ......think I saw a you tube video, it leaves an opening on both sides for air flow from outside for your AC blower......if you cover it with a solid lid, you have no airflow.
    eventually bought a replacement cowl, to get intact tabs, that make a tighter seal with windshield so water doesn’t come from above.
    you will be shocked how much crap is accumulated in those drains.........you have to remove 2 screws in wheel liner.....
  13. Jan 3, 2021 at 8:18 PM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Haven't done anything to it recently but I did bring it to Joshua Tree and my buddy took some pics with his dslr (forget which lens) Never had any pics taken of my truck with anything other than my phone so I'm really liking these! Still have to throw on sliders and trim fenders but that might not be for a few weeks.
    winkel, CGoss, BassAckwards and 21 others like this.
  14. Jan 3, 2021 at 9:12 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Is that a dasaita model? Mine looks very similar to yours and I installed a AT front camera that I can recommend.
  15. Jan 3, 2021 at 10:19 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    nothing major, just added 2 HID spot lights. so now i have HID Lo beams, HID Hi beans, HID Fogs and HID Spots.
  16. Jan 3, 2021 at 11:06 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Took the truck out for some downtime in the mountains.
  17. Jan 3, 2021 at 11:44 PM
    Trikster
    Trikster Well-Known Member
    Kevin
    2008 Tacoma 4x4 Double Cab
    Drivers side, bottom left. Passenger side, bottom right. Allows me to just see my back tires and of course the blind spot. Do this on all my vehicles. I just use the non directional dome style mirror. Just make sure you really get the glass clean before you stick on the mirror...will last longer (107k on the Taco, did it to the truck when my dad bought it, and 165k on my old Rabbit...)
  18. Jan 3, 2021 at 11:59 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  19. Jan 4, 2021 at 1:33 AM
    theolee
    Theo
    SAN DIEGO
    Lower left and rotatable. They really come in handy with dark tinted windows. I always paint the back of the black. No one wants to see the 3M double sided tape. :D
  20. Jan 4, 2021 at 3:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Oops nope that is made by Cascadia4x4
