  1. Jan 5, 2021 at 11:52 PM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    If you have a sleeping platform the bump in height will be welcomed. I tried it with a standard shell and it was too tight to be useable(DCSB problems, lol). For $250, not a bad way to go.
  2. Jan 6, 2021 at 12:04 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Drove it finally! its been down for 2.5 months and so today i finally got to get an alignment, then drove up to a buddies to show it off i guess...lol
  3. Jan 6, 2021 at 5:10 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I think it's cool, just like the lower side console versions, but I'm not too keen on screwing through the headliner for very limited storage power. Now the one that goes in front of the seat with the option of elevating risers, that one is cool to me since it doesn't permanently change anything. That's just my opinion though.
    theolee[QUOTED] likes this.
  4. Jan 6, 2021 at 5:41 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Got my lift finished and everything bolted back up. Goes in for alignment Friday DCLB 887/5100 with Icon RXT Option 2/B110. Measurements with full tank of gas.
    Stock - Lifted
    DF 19 3/4" - 23 1/4"
    DR 21 1/4" - 25"
    PF 20" - 24"
    PR 21 1/2" - 25 1/4"
    Now I am planning on adding a skid set and am anticipating the front settling down closer to 3" lift. However with a 1/4" spacer on the driver side for taco lean I am still 3/4" lower than the passenger side. Should I switch out the spacer plate for a 1/2" plate or a 3/4" plate to get it even with the passenger side?
    Also pics incoming later this afternoon after work.
    theolee, DG92071 and kidsmoke like this.
  5. Jan 6, 2021 at 6:06 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    After three weeks running this sweet spacer lift!
    I reinstalled my King coilovers that were sent off to @AccuTune Offroad for a revalve and rebuild. Those guys were great to work with. Now I wait impatiently for my new king 12” 2.5 smoothies for a rear shock relocate.
  6. Jan 6, 2021 at 6:22 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
  7. Jan 6, 2021 at 6:23 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    thats so cool... I hope to be able to be a friend of Santa one day
    Do the 4 cylinders not use the ALT-S circuit to sense voltage and change charge voltage?
  8. Jan 6, 2021 at 6:44 AM
    DG92071
    DG92071 Well-Known Member
    FYI: I have a spare 1/2" thick (1" lift) strut spacer that I'll never use. If you want it send me a PM.
  9. Jan 6, 2021 at 6:53 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    I have a second back-ordered 1/4" spacer that is supposed to be delivered Friday. I was going to stack the two and re-measure to see if that helps get the numbers closer. If that does do the trick I will totally reach out to you so I can replace them with a single spacer.
    So I don't clearly understand the spacer lift measurements fully. Mainly because I didn't plan to run spacers outside of taco lean spacer. So the lift gained from a spacer on top of the strut hat is double the thickness of the spacer? So in my case a 1/4" spacer is giving me an extra 1/2" lift on the driver side. If I replaced it with your 1/2" spacer I would get 1" of lift? Am I understanding that correctly?
    DG92071[QUOTED] likes this.
  10. Jan 6, 2021 at 7:09 AM
    Tttacodan
    Tttacodan Well-Known Member
    Dan
    Looks Great Man!
  11. Jan 6, 2021 at 7:15 AM
    Tacospike
    Two Trucks
    Yeah they have been floating around for a while. I'm loaded up with center console and rear overhead molle racks so I's good not messing with the headliner.
  12. Jan 6, 2021 at 7:53 AM
    acdubstaco
    acdubstaco Well-Known Member
    Adam
    NorCal
    2011 TRD OR
    Boy I sure hope you are wrong, that won't be cheap! I am keeping an eye on my MPG and will see if the light comes back in the next 30 miles.
    This was my thought, I haven't heard a rattle or noticed any decrease in HP or MPG. I am curious what the average life span is of these O2 Sensors and Cats.
    SilverYeti[QUOTED] likes this.
  13. Jan 6, 2021 at 8:59 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Hector, the guy who runs OG Fab, is a standup dude. Those molle panels are only good for about 3lbs because of the headliner. I think any more than that and you would suffer separation with the headliner pulling toward the middle.
  14. Jan 6, 2021 at 8:59 AM
    patos tacoma
    patos tacoma Well-Known Member
    Doesn’t look bad at all with the stripping and 3rdgen rims........where did you get headlamps, thanks
  15. Jan 6, 2021 at 9:40 AM
    TacoEspecial
    TacoEspecial SSSlow
    Mark
    Sacramento
    13 Sliver TRD AC
    BAMF RCLT Deaver Fox 2.5 StopTech Dana 60 37s 475:1
    10.2" wide isn't so skinny.
    I sure like mine.
  16. Jan 6, 2021 at 10:19 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Your numbers are going to change a little after alignment. I have the same front kit as you DCLB w/ shell, I swapped the 1/4” for a 3/8”. Also if you reversed the truck then took measurements they will be higher, this drove me nuts for a while until I figured that out.
    AStinkyBumb[QUOTED] likes this.
  17. Jan 6, 2021 at 10:23 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Yeah I know everywhere lists the 887/5100 at being a 2.5-3" lift and most people are stating they see some sag down to those numbers post install and settle. Now that you mention it I dont remember what I did right before I measured. Placed it on flat ground, deflated the air bags, then measured. three quarters of an inch isnt bad and probably not very noticeable. I just know before the lift some days my rear would have an inch difference in measurements for some reason and it bugged the hell out of me cause I thought my topper was crooked.
    I might just leave the 1/4" spacer in for a month and take measurements again after things settle and adjust as needed.
  18. Jan 6, 2021 at 10:57 AM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    This is awesome! Congrats! I tried a couple years ago after reading Crom's post, and DMV said the law had changed to prevent fee avoidance. They said I needed a full-time running water sink in the truck bed and a couple other things, which made me drop it. I wonder what changed since then?
  19. Jan 6, 2021 at 11:24 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    I'm glad we don't have to deal with BS like that in MN. Our tags are straight forward and cheaper then that and no annual inspections.
  20. Jan 6, 2021 at 11:27 AM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    probably a dumb question, but this probably won't work for a softtopper:oops::confused:
