  1. Jan 8, 2021 at 12:09 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I see you put the cover back on over the filter. I threw my cover away when I first installed the CAI ‍(Facepalm) So my filter is fully exposed.. that’s the reason why I put on the prefilter over it
  2. Jan 8, 2021 at 12:12 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    My concern is moisture getting into the pump and it failing. The more I'm reading though, it might be the fog light mod after all. Everything appeared to operate perfectly, so I don't know what went haywire. I felt it for a second last night when I was driving but I thought maybe I was imagining things. Unfortunately we it's raining today s I can't really test out the moisture theory, but I'll try each mod again separately tomorrow or Sunday and see what happens.
    DG92071 likes this.
  3. Jan 8, 2021 at 12:19 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Sorry to hear you're having a problem. I know I did the relay mod in the exact same way you did, and AFAIK, I was the first to use that relay/approach (per TW threads) and I've had no problems whatsoever.
    Limp mode per the SAIS is definitely a thing folks experience. I'm stock on that front so I can't speak to it. Good luck.
    :popcorn:
  4. Jan 8, 2021 at 12:22 PM
    Tacoma13_NC
    Thanks bud. Hopefully it's nothing serious, and putting everything back to stock and letting it sit will reset things. I wish that I wouldn't have done both mods at the same time, because now I'm not sure which is the culprit. I'll keep you updated though.
  5. Jan 8, 2021 at 12:23 PM
    deadpocketss
    deadpocketss Dingus
    Colorado
    '24 Subaru Crosstrek Premium
    Finally got the Quicklifts that my TWSS got me installed
  6. Jan 8, 2021 at 1:23 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Did you happen to pull the EFI fuse when doing the fog mod? You're gonna have to clear the codes yourself to get the lights out.
    spencermarkd likes this.
  7. Jan 8, 2021 at 1:25 PM
    Tacoma13_NC
    I didn't pull the fuse.
  8. Jan 8, 2021 at 1:28 PM
    trdmtb
    trdmtb Well-Known Member
    Michigan
    RIP: 07 DCSB TRD OR current: 19 Ram
    Put these in a few weeks ago. Cali Raised LED pods and brackets bought from another TW member. Wayyy brighter than the garbage LED bulbs I got from Amazon
    DG92071, Dawdaw808, irayfz6 and 7 others like this.
  9. Jan 8, 2021 at 2:30 PM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    Glad they made it safely!
    Kuntrykid and trdmtb[QUOTED] like this.
  10. Jan 8, 2021 at 2:55 PM
    trdmtb
    Michigan
    thanks again man!
    The Wolves[QUOTED] and Kuntrykid like this.
  11. Jan 8, 2021 at 4:44 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Added SDHQ terminals today. Not sure why I waited so long because these aren’t very expensive and are extremely nice.
    D3C12E71-8C33-4ACD-84B3-ECFBC8A23DFB.jpg 0463423E-2288-4DE2-A4B7-BDE29D522B85.jpg
    dpele, scott_b, Fluffymonkey and 26 others like this.
  12. Jan 8, 2021 at 4:47 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    made some brackets to hold my all weather mats in place on my all weather floor.
  13. Jan 8, 2021 at 4:53 PM
    Richard949
    Richard949 Member
    Richard
    2010 TRD Sport SR5 Double Cab
    I added these Rixxu Milano seat covers -
  14. Jan 8, 2021 at 5:03 PM
    Tacoma13_NC
    Just FYI, i removed the jumpers from the relays and put the SAIS pump back to stock. I let the truck sit for a couple hours and now it is running fine and the CEL/Trac Off lights went out. Whatever it was I did my truck wasn't happy about it. Will a code reader back read prior codes thrown so I can see what the problem was?
    DG92071 and PyritePirateBill like this.
  15. Jan 8, 2021 at 5:49 PM
    Beauxdon
    Beauxdon TTC #289
    Houston, Tx
    2010 TRD Sport DCSB
    These look really good
    DG92071 and Kolter45 like this.
  16. Jan 8, 2021 at 6:05 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Did some upgrades to my base model starting with a leather steering wheel and adding bluetooth/audio controls. Got them wired up to my PAC controller and Pioneer head unit tonight. Also added cruise control a couple weeks back and swapping out the clock spring ended up getting that working which I was in the process of trouble shooting. It was prewired for the cruise control and the steering wheel controls so that made it pretty easy once I figured everything out.
    Parts used:
    - 06 Tacoma steering wheel & CC stalk
    - 04-09 Prius clock spring
    - 03-09 4Runner airbag
    Sky, JR SLASH 33, 05Taco4x4 and 9 others like this.
  17. Jan 8, 2021 at 8:19 PM
    studunk1
    studunk1 Well-Known Member
    stu
    jeff city, MO
    13 Access Cab sr5
    running boards, bug deflector, window deflectors, tail gate liner, bed mat
    Live in Missouri, gets cold, have access cab. Today cleaned all 4 door gaskets, applied silicone to control the squeeky/crunch sound as truck flexes.
    GonzoQuick and DG92071 like this.
  18. Jan 8, 2021 at 10:30 PM
    Hyperbarics
    Hyperbarics Commercial Diver & Taco Driver
    Savannah, GA
    2013 DCSB - Nautical Blue Supremacist
    Installed OEM roof rack a few days ago. Plenty of silicone on the bolt threads, and injected a bit in the holes. Heavy rain for the past two days and haven’t had any signs of leakage. Which is great- my ‘06 ended up having the carpet cut out, and holes drilled in the floor because of a sh#t windshield replacement by SafeLite.
    Getting all set for a 2020’s suspension retrofit.. sourced locally for $100! Really looking forward to the ride improvement on the ‘13. :taco:
    Loving the new profile with OEM rack..
  19. Jan 8, 2021 at 10:46 PM
    _anthony_
    _anthony_ Well-Known Member
    Grand Rapids
    2015 Tacoma SR5
    thank you, in person the clear coat isn’t that good but I’ll deal with it for now
    Tacospike[QUOTED] likes this.
  20. Jan 9, 2021 at 12:05 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    daaannggg thats some big money back there.
