  1. Jan 9, 2021 at 1:19 AM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I installed LED headlight bulbs went with “Lighting dark” brand, beam pattern and brightness is great. Also installed the LED package from the interior lightings, reverse and license lights. Was gonna leave everything original but had to match the new diode dynamic led fog lights so now it makes the truck a little more updated lol
    BassAckwards and kidsmoke like this.
  2. Jan 9, 2021 at 5:31 AM
    Miller time
    Miller time Well-Known Member
    Shawn
    08 Tacoma TRD off-road blue D-cab SB 4x4 with locker
    I just got the same headlights for Christmas. I told my parents about them and they put them in there Ford Expedition first and they loved them.
    then a week age my wife had a headlight go out and I ordered a set for her Ford Taurus
    Xmplry808[QUOTED] likes this.
  3. Jan 9, 2021 at 5:45 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Looks great! i've been dreaming...... Can we get some angled shots? Curious to see how far around the body the bar(s) wrap/extend relative to the body/fender
    xguntherc, DG92071 and BassAckwards like this.
  4. Jan 9, 2021 at 5:58 AM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    Ditch the old led dome bulb for these...
    Major lighting output.
    Before and after pics
  5. Jan 9, 2021 at 6:32 AM
    DG92071
    DG92071 Well-Known Member
    My truck can tow that boat no problem.
    Lol
  6. Jan 9, 2021 at 7:06 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Drove to mom's on a winter wonderland.
  7. Jan 9, 2021 at 9:01 AM
    SoCalTbird
    SoCalTbird Well-Known Member
    South OC
    06 PreRunner DCSB 05 AC 4X4
    where did you get that LED?
    13txtaco[QUOTED] likes this.
  8. Jan 9, 2021 at 9:47 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    If you re-install the different things do one wait a week then do the other that should pinpoint exactly which one caused it to enter limp.
  9. Jan 9, 2021 at 9:58 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Thanks. I'll probably wait until the code reader comes in and see if it shows what code was thrown yesterday. I think I might have tapped the wrong pin on the relay, possibly causing the limp. I have to do some more researching into that. Next time I will definitely do that though. One at a time.
  10. Jan 9, 2021 at 10:04 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Picked it up from alignment this morning. Started tacking together my Coastal Offroad skid set. After football I'm going to test fit it before burning it in with finish welds.
    winkel, dpele, Kuntrykid and 6 others like this.
  11. Jan 9, 2021 at 10:05 AM
    Xmplry808
    Oh wow that must be crazy bright cause the LED dome light is already bright, must be good for a double cab though. I have an access cab so it’s good enough for me.
  12. Jan 9, 2021 at 10:46 AM
    JBlaze
    JBlaze Member
    Indian Trail, NC
    2005 Tacoma Pre Runner Access cab V6 4.0 MT
    Eibach Stage 1 lift kit (shocks, struts, and springs) OME upper control arms ICON add a leaf kit Moog tie rod ends and sway bar links Fuel Anza Anthracite 17×8.5 -6 wheels Falken 275-70-17 tires MBRP catback exhaust Spectre Cold Air Intake Powerstop Rotors and Pads ARB Single Compressor w/Expedetion Essentials bedside compartment mount AlphaRex Pro series headlights and taillights Diode Dynamics SS3 fog lights Westin Bull Bar Magnum Raptor style steps TacoVinyl color match custom grille Tyger Pocket Style Fender Flares AVS in channel window vents Prinsu Roof Rack RedLine Tuning hood struts Husky toolbox Fia Leatherlite seatcovers Husky weatherproof floormats front Weathertech Floormat rear JVC dvd/bluetooth player Rockford Fosgate 6×9s, 6×5s, 1" tweeters and 8" powered sub Sparco carbon fiber gas pedal OMP clutch and brake pedal Meso Customs map and dome lights AJT Designs climate control knobs and matching keyfob TRD FJ cruiser shift knob CH4×4 switches for compressor, fog, and grille lights BD Diesel throttle controller
    Just finished up installing new grill w/raptor lights, and will be focusing my next couple of mods on headlights and foglights
  13. Jan 9, 2021 at 10:50 AM
    JBlaze
    JBlaze Member
    Indian Trail, NC
    I just installed one early this week and it is insanely bright...soon as they restock them going to get the map lights to match...the 2nd pic is at night with no camera flash...Meso Customs v2 dual color dome light
  14. Jan 9, 2021 at 10:52 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Took the kids on a hike. Loving the Ironman Foam Cell Pro suspension! If anyone wants a set let me know I can hook you up with the best price.
  15. Jan 9, 2021 at 10:54 AM
    13txtaco
    Katy Texas
    2013 Tacoma 4x4
    Amazon
    SoCalTbird[QUOTED] and Xmplry808 like this.
  16. Jan 9, 2021 at 10:57 AM
    T4COM4
    T4COM4 Member
    Erwin Tn
    just got an 03 tacoma mods comming soon!
    Wheels!
    winkel, 99kx250, K-DubTaco and 21 others like this.
  17. Jan 9, 2021 at 11:00 AM
    JBlaze
    JBlaze Member
    Indian Trail, NC
  18. Jan 9, 2021 at 11:02 AM
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Like this? I love how BAMF angles the bars, too, making it look great. I plan on trimming the fender to match the angle. Soon.
    rtilton12, dpele, Fixxxer and 15 others like this.
  19. Jan 9, 2021 at 11:07 AM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    :drool:
  20. Jan 9, 2021 at 11:34 AM
    Tacoma13_NC
    Sometimes it's just the little things.
