  1. Jan 15, 2021 at 3:27 PM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Exactly, only true fix to improve the performance of these lights is a proper retrofit. I'm wrestling with the idea of doing a retro to these or stealing the lenses and doing the BHLM to my factory housings along with the Ultimate H4 upgrade.
    theolee[QUOTED] likes this.
  2. Jan 15, 2021 at 3:57 PM
    ArizonaComa
    ArizonaComa Well-Known Member
    Erik
    AZ
    2007 Impulse Red ACLB TRD
    285 K02s, Bilsteins, and a GoFastCamper
    I have been having issues for years now with corrosion on my battery, mostly on my negative terminal. Can't seem to come up with a fix, but I came across CRC terminal spray and so I thought I'd see if it helps at all.
    I also re-torqued all of my leaf spring hardware associated with the add-a-leaf I added about 500 miles ago. Glad I did. I had some considerable movement on my u-bolt nuts. They're all good now, and I torque striped the u-bolt nuts.
    Afterwards, I took my spare down for some undercarriage cleaning and inspection, and tested out my factory bottle jack. Still works with my 285's. Nice!
  3. Jan 15, 2021 at 4:05 PM
    Taco-Obsessed
    Sweet, been looking for a hawse thats not bare thats black or grey. Like that it matches the hook, that the warn hook? Easily folds sideways to mount flat (like factor 55s) or you got to pull it in just right? My truck is metallic dark grey, so both of those might look good on mine.
    TRDguyKC[QUOTED] likes this.
  4. Jan 15, 2021 at 4:05 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    I use fluid film on the terminals.
    jakezna and ArizonaComa[QUOTED] like this.
  5. Jan 15, 2021 at 4:13 PM
    ArizonaComa
    Erik
    AZ
    Nice, I have heard about others using fluid film as well. I will keep this in mind.
  6. Jan 15, 2021 at 4:51 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    I use the same crc on my terminals. It does the job. Need to inspect during oil change to see how it is doing. Preventative maintenance keeps the terminals clean.
    ArizonaComa[QUOTED] likes this.
  7. Jan 15, 2021 at 4:53 PM
    idriveabox
    idriveabox Well-Known Member
    Calgary, AB
    2015 BRM SR5
    Do you have a link for the trans PID? Your set up is slick.
  8. Jan 15, 2021 at 5:36 PM
    Hobieflyer
    Hobieflyer Member
    2012 access cab Sr5
    This is the post I found. I don't know how to link it sorry. I used the 21D9 pid instead of the 2182 and it works for me I think
    QUOTE="biborado, post: 4320749, member: 27707"]Ok I think i figured it out for the 2010+ Tacoma
    For sensor 1 (Pan Temp):
    OBD2 Mode and PID:
    2182
    Long Name:
    Transmission Fluid Temperature 1
    Short Name:
    Trans 1
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((A*256)+B) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    For sensor 2 (Converter outlet temp):
    OBD2 Mode and PID:
    2182
    Long Name:
    Transmission Fluid Temperature 2
    Short Name:
    Trans 2
    Minimum Value:
    0.0
    Maximum value:
    300.0
    Scale factor:
    x1
    Unit Type:
    °F
    Equation:
    ((((C*256)+D) * (7/100) – 400)/10)
    OBD Header to use:
    left blank
    I'm going to set the truck into the Diagnostic Mode to check and see if the numbers match up. If the PID and equation are correct, the A/T Temp light should light up at 115°F and start flashing at 130°F.[/QUOTE]
  9. Jan 15, 2021 at 6:10 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Link for the cup holders?
  10. Jan 15, 2021 at 6:12 PM
    TRDguyKC
    TRDguyKC Well-Known Member
    Kris
    Sierra Vista, AZ
    I wasn’t planning on getting a new fairlead TBH but after mounting the winch and seeing how the rope feeds onto the edge of the ARB, I had no choice. I did a bit of searching for a cheaper alternative but there’s not much out there. The SLEE was $90 or so shipped.
    The hook is actually a harbor freight badlands. It easily folds flush on the fairlead. I’ll eventually get a thimble but for now it has worked out well.
    Taco-Obsessed[QUOTED] likes this.
  11. Jan 15, 2021 at 7:06 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    gkomo, DG92071 and theolee[QUOTED] like this.
  12. Jan 15, 2021 at 7:07 PM
    theolee
    Theo
    SAN DIEGO
  13. Jan 15, 2021 at 7:19 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    Passenger fender. Should finish all my polishing tomorrow. Next week I’ll start on my engine bay detailing.
  14. Jan 15, 2021 at 7:21 PM
    theolee
    Theo
    SAN DIEGO
    Do you think these would fit properly? I like the idea of the drainage hole and double cup size.
    DG92071 likes this.
  15. Jan 15, 2021 at 7:30 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I added some more weight to test out the supercharger.
    dpele, gkomo, whatstcp and 4 others like this.
  16. Jan 15, 2021 at 7:46 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Those might be tight given they are deeper anyway + the drainage part length.
  17. Jan 15, 2021 at 8:02 PM
    theolee
    Theo
    SAN DIEGO
    Figured, thanks dude :)
  18. Jan 15, 2021 at 9:10 PM
    kidsmoke
    Flyover Country
    And they’d drain into the tailgate. I saw those but felt that any moisture would fall harmlessly into the bed when you lift the gate. Better, imho.
  19. Jan 15, 2021 at 9:29 PM
    theolee
    Theo
    SAN DIEGO
    Oh ya, I agree. A closed cup is definitely the way to go. In the long run you probably don't want any fallen crap marinating in the gate. :)
  20. Jan 16, 2021 at 5:07 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Exactly. I put a bead of silicone around the bottom of the cup lip to hopefully seal them tight.
    theolee likes this.
