  1. Jan 22, 2021 at 1:54 PM
    Dlo455
    Dlo455 Well-Known Member
    BC Canada
    2021 Tacoma TRD Sport Premium DCSB 6MT #Armygreen
    Well boys, I think I sent her a little too hard...
  2. Jan 22, 2021 at 2:09 PM
    Bootselectric
    Bootselectric Well-Known Member
    Stirling
    2004 PreRunner (RIP) 2013 TRD Sport (DCSB-BRM)
    I cold chiseled and torched the mother fudger front diff bolt off that of course stripped and left me up the diarrhea river without a pot to piss in. This little bastard was a royal pain to dislodge. But once I did..........
    and then
    I know it’s a little thing but the satisfaction of hearing that bolt snap off after hammering and hammering and hammering, it felt so good!
  3. Jan 22, 2021 at 2:32 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Which means it will rub alot when off road at full lock.
    whatstcp likes this.
  4. Jan 22, 2021 at 3:05 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Drove it around town today
    MoTacoX, dborrer, irayfz6 and 7 others like this.
  5. Jan 22, 2021 at 3:06 PM
    Ezriderga
    Ezriderga Well-Known Member
    Georgia
    2008 Tacoma base truck
    Spent 3 hours prepping for my engine bay detail tomorrow. Removed battery and cleaned and while I had it out I thought this was an opportune time to clean the battery post and terminals. I also gathered the tools and products I thought necessary to complete the job. I also cleaned and sealed all areas I thought were critical and could cause a problem if not protected. I put a tarp covered with a moving blanket underneath the area I will be cleaning so the garage floor will still be clean when I finish. I’ve already detailed underneath the hood and it was just as nasty as the engine bay.
  6. Jan 22, 2021 at 3:14 PM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Are you going to be cleaning it with a fire hose?! :rofl:
  7. Jan 22, 2021 at 3:48 PM
    Beltfed762
    Beltfed762 Well-Known Member
    Virginia
    2011 DCSB TRD Offroad
    6" lift, 35x12.50R20 Firestone m/t, 20x10 XD Spy wheels, Fox shocks/coilovers, dif breather mod, SAIS delete, Alcan +5 leaf springs, U-bolt flip kit, Superbump bump stops, cab mount chop, poly performance leaf bushings, taco tabs, all-pro cam tab gussets, diy fender trim, fender flare delete, pinch weld smash, cloth seat delete + factory leather swap, seat heaters, remote start, 20% tint, ARE camper shell, ... im sure im forgetting something.
    Added ditch lights and a 32” light bar in the bumper
  8. Jan 22, 2021 at 4:49 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    I've had mine on for bout 3 months but I have no lift
    GrubesBaja[QUOTED] likes this.
  9. Jan 22, 2021 at 4:49 PM
    crackils
    crackils Sith Lord Jar Jar
    Shane
    FL
    2012 TRD DCSB Off-Road - KINGS/5125s AF
    Technically this didn't happen today, but it did happen this month :D
    Installed my Martin Off Road cap rack from @gmartin284
    HD Dakar Install thanks to @Strictlytoyz
    JR SLASH 33, dpele, gabbo2112 and 7 others like this.
  10. Jan 22, 2021 at 5:07 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Nothing major, got 180lbs of tube sand over the rear axle finally. In case of ice or whatever this winter.
    DG92071 likes this.
  11. Jan 22, 2021 at 5:23 PM
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    I’ve never really looked into this.......is it only 1 traction bar?
    DG92071[QUOTED] likes this.
  12. Jan 22, 2021 at 5:24 PM
    DG92071
    DG92071 Well-Known Member
    Today I bent the crossmember that my traction bar bolts to. Lmao. I couldn't get a decent picture of it.
    Sorry to interrupt... on mine I swapped the power port for the lighter and the lighter for the power port.
    Never mind the "custom" cell phone mount or the Harbor Freight receipt for submersible trailer lights. Lol. The power port went into the cigarette lighter hole with zero issue, it snapped right in, it's weird because the power port hole is smaller than the lighter hole. I drilled out the old power port hole for the cigarette lighter size using a step bit or unibit.
    To get the power port out without taking the dash apart at all you'll need 2 picks similar to these
    They can both be 90* or both hooks or one of each it doesn't matter. You'll use one pick to unlock the tabs that lock in the power port and the other pick to gently pull the power port out of its hole on the same side of the power port that is getting unlocked first. You pull the power port out a little crooked and then move to the opposite side of the power port to unlock that sides lock using both picks like you did on the first side. So my power port has one of its locks at about 8:00
    You use a pick and push the black lock out of the rectangle shaped hole and with the other pick grab the same hole to pull the power port out slightly. Then move to 2:00 where the other lock is and repeat.
    For the lighter it is the same principal but it doesn't have a rectangle shaped hole, it has holes shaped like an L, ar around 4:00 and 10:00 on my lighter.
    Push down on the black and gently pull on the lighter at the same time.
    I hope I'm wrong and you're right but I don't think PreRunner's have splined slip yokes.
    Edit: fish the wires out of the power port hole and lighter hole with a wire coat hanger.
  13. Jan 22, 2021 at 5:25 PM
    emglishe30
    emglishe30 Well-Known Member
    NJ
    2010 SR5 Base 4x4 DCSB
    Pioneer Touch Screen, Sub, Diode Dynamics SS3 Sport amber fogs, Oem skid plate, led accent lights, led 3rd brake, 2011 color matched honeycomb grill. Plasti dipped pieces.
    Installed these beauties..diode dynamic ss3 sports.
    upload_2021-1-22_20-24-21.jpgupload_2021-1-22_20-25-7.jpgupload_2021-1-22_20-22-59.jpg
    JR SLASH 33, dpele, DG92071 and 11 others like this.
  14. Jan 22, 2021 at 5:29 PM
    DG92071
    Yes, only one. Near the center of the truck.
    JuanitoBonito[QUOTED] likes this.
  15. Jan 22, 2021 at 5:31 PM
    JuanitoBonito
    Juan
    CHI-TOWN
    2024 Raptor
    I know yours is custom, is it all bolt on?
  16. Jan 22, 2021 at 6:28 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Aaaaand I guess follow up question....
    Did the bed bolt D-Ring mod on my truck. And clue what the maximum weight on these is? I strapped the sandbags down to them.
    Island Cruiser likes this.
  17. Jan 22, 2021 at 7:05 PM
    Taco-Obsessed
    @Pibbles99
    Pibbles99 and SilverYeti like this.
  18. Jan 22, 2021 at 9:51 PM
    HDMOTT
    HDMOTT lil_tacoma
    Harrison
    Arkansas
    2013 Tacoma 4x4 2017 4Runner TRD Pro
    SCS BR6/ Bilstein 6112/5160/ BajaDesigns Squadron Sport Fog Lights/ BajaDesigns Squadron Pro Ditch Lights/ BajaDesigns S1 Flush Mount Reverse Light/ 32" Light Bar/ Rago Fab Ditch Light Brackets/ CaliRaised Lower Bumper Light Bar Brackets/ BPF Tow hook/ BPF TRD Skid Plate/ Bora 3/4in Wheel Spacers/ Icon 3 Leaf AAL/ BAMF HD Shackles/ TRD Pro Grill/ OEM Roof Rack/ OEM Bed Mat/ Nitto Trail Grapplers/ Every Bulb LED
    New tires installed, Nitto Trail Grapplers. Also turned 81k miles today.
    tacofish, rtilton12, 99kx250 and 14 others like this.
  19. Jan 22, 2021 at 11:13 PM
    Asianguywithatruk
    Asianguywithatruk Well-Known Member
    CenCal
    05 taco DCSB
    King RR coilovers Ironman leaf springs 17" scs sr8 jet black 285 75 17 Yokohama geolandar Demello front bumper Brute force rear bumper
    D5D51200-E12D-461F-9812-B5F34287336F.jpg Button everything up and cleaned up the Lens on my retrofitted headlights
    01B659B9-A5D2-4412-8C72-6EF642D51714.jpg output shot for y’all to see. This was before polishing the lens.
  20. Jan 23, 2021 at 2:30 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    How was the install difficulty? Did you need a adapter, or was it plug and play? I didn’t see one as part of the parts shown on website . I’ve been dragging my feet on ordering because work has been crazy and life as well. Website from hot shots didn’t pic it. They look real nice
