  1. Jan 25, 2021 at 9:24 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    You don’t want weight at the tailgate. Ideally you want it just forward the rear axle. The further back you go you’ll be taking pressure off the front axle and will cause issues with steering.
  2. Jan 25, 2021 at 9:39 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Its less about amplifying the weight in the bags but making sure you don't over amplify the weight behind the axle. Too much weight behind the axles lifts the weight on the front of the vehicle causing the front tires to push when turning and going over bumps instead of steering. Proper or heavier amount of weight over the axle is always safer from a stability standpoint than overly heavy weights behind the axle. Not everyone is a mathematician or physicist so its always recommended to people to just throw the weight over the axle. If you are one of the select few who can calculate max weight + down force at the weights position behind the axle as to not lift weight from the front you are a smarter man than I. Since I cant I throw weight over the axle.
    Jimmy92870 and Sideways1 like this.
  3. Jan 25, 2021 at 9:49 AM
    KCTaco77
    KCTaco77 Well-Known Member
    Kansas City
    2011 Tacoma 4X4
    3" Lift, AMP Running Boards and tailgate step, ANZO head and tail lights.
  4. Jan 25, 2021 at 9:52 AM
    DocD
    DocD Well-Known Member
    Mn./SoCal
    09 access cab
    well to each there own, no offence but maybe a little more schooling in physics iis needed, putting 500#s near the tailgate would make that front end a little squirrely on ice, distributing the weight over the bed is the way to go. you certainly want weight over your drives, not unlike loading a trailer. However what ever works for ya (maybe your post was for humor)
  5. Jan 25, 2021 at 10:04 AM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Yes,
    Loading past the axle would create a lever that pivots at the axle.
    Loading on or before the axle would weight the axle.
    wi_taco and Jimmy92870 like this.
  6. Jan 25, 2021 at 11:24 AM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    Finished my de-badging over the weekend. No more Tacoma badges on the front doors, and I took the pinstripes off, too. All that's left is "Toyota Tacoma" on the driver side of the tailgate.
    srspicer, whatstcp, Bratwurzt and 4 others like this.
  7. Jan 25, 2021 at 11:28 AM
    BuschWacker
    BuschWacker Well-Known Member
    Calgary, Alberta
    2015 TRD Sport DCLB
    I did the exact same thing to mine this weekend.
    DG92071, whatstcp, irayfz6 and 3 others like this.
  8. Jan 25, 2021 at 11:28 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    First off, nobody said to put 500 lbs of sand in the bed for traction purposes. 200-250 is plenty. Secondly, the tongue weight limit when towing is around 500 lbs (*give or take) so you could safely put 500 lbs near the tailgate and be fine with regard to steering. Remember there is a pretty heavy engine up front. Your not gonna pull a wheelie.
  9. Jan 25, 2021 at 11:31 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Weird how yours is a different style. Are they different for the 2.5 gens?
  10. Jan 25, 2021 at 11:32 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i looked at my ODO the other day. i dont know how i got to 190k miles so quickly. i called a mechanic friend and he is gonna flush my transmission for me tomorrow.
    my mechanic is in another town, but i trust him..he said he will do it while i wait. he bought the fluid already. i'll get some chinese grocery shopping done while he does the work.
    JimIowa and Taco-Obsessed like this.
  11. Jan 25, 2021 at 11:32 AM
    KeithB
    Keith
    Cheshire, CT
    OK, so you're saying since its a pivot point that there would be no additional downward force at the wheels on the ground? That's makes no sense. Additional weight in the bed, no matter where it's placed, is going to make the back end of the truck heavier. There will be more downward force at the wheels the further back the weight is placed. Period.
    Walldiver7 and DG92071 like this.
  12. Jan 25, 2021 at 11:35 AM
    KeithB
    Keith
    Cheshire, CT
    Anywhere weight is place at the back end is going to have a lifting effect on the front end. All I'm saying is you can carry less weight in the bed, say 200 lbs at the tailgate and have the same effect as say 220 lbs at the cab end of the bed.
    Walldiver7 likes this.
  13. Jan 25, 2021 at 11:36 AM
    BuschWacker
    Calgary, Alberta
    2015 TRD Sport DCLB
    archive flip kit and I used a 4Runner bump stop kit. The Tacoma bump stop kit has the tabs that go under the square u bolts. I wanted something that had holes that would line up with the holes on the flip kit.
    dpele[QUOTED] likes this.
  14. Jan 25, 2021 at 11:37 AM
    gotblika
    Maui
    2015 DCLB Sport 4X4
    Just different manufacturers, his looks to be Archives.
  15. Jan 25, 2021 at 12:28 PM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    Nope that is incorrect. The rear axle and the front of the truck is what would be considered a first class lever. Weight applied at or before the axle (fulcrum) keeps weight on both the front and rear of the vehicle, weight after the axle would cause lift on the front. A great amount of effort is needed to lift the front of the vehicle and these trucks aren't clearly going to wheelie or anything with a few sand bags in the back. However even slight effort pushing the front up is a decrease in potential traction the front has which is the greatest danger in this. When weight in the bed is most needed is when traction both front and back are critical (slippery roads). Greater increase on the rear with even the slightest decrease on the front could be the difference between spinning out or not. Placing the weight at or in front of the axle creates the most optimal down force on all four tires when driving.
    Granted 20lbs of down force behind the axle isn't going to equate to a lot of up force on the front of the vehicle while its rolling on flat ground, but what happens when you hit a dip in the road and your front suspension rebounds pushing the front up and you have extra weight behind the axle making that rebound easier. The front rebounds further than it needs to creating more lift on the front tires decreasing traction. Now instead of having 200lbs spread across all 4 tires in some form you have 200lbs pulling the rear down as the front lifts.
  16. Jan 25, 2021 at 12:30 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Cleaned her up, debating on selling.
    NmapFE, rtilton12, K-DubTaco and 14 others like this.
  17. Jan 25, 2021 at 12:30 PM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Class is in session!:popcorn:
    crashngiggles likes this.
  18. Jan 25, 2021 at 12:34 PM
    KeithB
    Keith
    Cheshire, CT
    Sorry, not buying what you're selling. Every other vehicle on the road has more weight in the back than a pickup truck. A couple hundred lbs in the bed even behind the axle is not going to send you out of control. People tow with more than 200lbs on the hitch, which if I remember correctly is behind the rear axle.
  19. Jan 25, 2021 at 12:35 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    If you were a little closer, I’d have you price me the soft top! If you’d sell it separately...
    IvanhoeTaco[QUOTED] likes this.
  20. Jan 25, 2021 at 12:37 PM
    IvanhoeTaco
    Eastern NC
    I do love the softopper!
    whatstcp and 308savage[QUOTED] like this.
