  1. Jan 28, 2021 at 11:51 AM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    Finally upgraded my speakers n head unit. While I had the door apart, switched my red mirror covers to black and added spotter mirrors.
  2. Jan 28, 2021 at 12:15 PM
    themanbearpig012
    themanbearpig012 Well-Known Member
    Rudy
    Nipomo, Ca
    2015 DCSB TRD SPORT
    Fox 2.5 Factory Series Coil-Over Reservoir (Front) Fox 2.0 Performance Series IFP (Rear) Method "Mesh" 17x8.5|6x5.50|0/4.75" wheels
    Got an alignment lol
    Plain Jane Taco likes this.
  3. Jan 28, 2021 at 2:20 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    I cant be the first to come up with this, but have yet to see it on here, so here' goes.
    I made these little clamp on mounts for lightweight stuff (the shovel pictured is all aluminum and insanely light). Cut a couple pieces of PVC LENGTHWISE, drilled a hole and countersunk the inside to accept the screw head. Mounted the quick fist, and snapped onto the softopper frame. Frame won't fold while installed but they just pop off with some force.
  4. Jan 28, 2021 at 2:21 PM
    Todoh13
    Todoh13 New Member
    Trent
    2014 TRD Sprt DCSB Magnetic Gray Mica,
    Icon 2.5 coilovers 2.0 rear and toytec AAL, 16" SR5 charcoal wheels 285/75R16 ProComp Extreme MT2 Nfab steps, BakFlip G2 Tonneau Cover.
    Finally got the rest of the front end taken care of looks much better, thanks @HomerTaco
  5. Jan 28, 2021 at 2:25 PM
    powder1134
    I also test fitted my new trash set up. Not that the Trasharoo isn't cool and all, but @ $50....meh. Ordered this $15 Italian Military rucksack (shipped from Finland, go figure). Works like a charm. Plus it has a chain inside to lock it closed. MAY keep out a racoon, but not a bear.
  6. Jan 28, 2021 at 2:26 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Threw some paint on my dry, dusky frame. I need some new splash guards
  7. Jan 28, 2021 at 2:36 PM
    justcuz
    justcuz Well-Known Member
  8. Jan 28, 2021 at 3:21 PM
    YanE30M3
    YanE30M3 GO PATS!
    Yan
    Woodbridge VA
    15 TRD Sport (DCLB-BRM) - 88 ///M3 (Zinnoberrot)
    OME 887/Dakars/NV305s/33" Duratracs/+
    YES!!!!!!!!!!!!!!!! hahahahahahaha
  9. Jan 28, 2021 at 3:49 PM
    Miller time
    Miller time Well-Known Member
    Shawn
    08 Tacoma TRD off-road blue D-cab SB 4x4 with locker
    I seen a video of a guy cutting up a factory e-locker and he add a cable to convert to a cable locker looked really good. But does any one know if a company sells a kit. His was homemade
  10. Jan 28, 2021 at 3:59 PM
    cfayne
    cfayne Well-Known Member
    Santa Clarita
    2012 Tacoma V6 six speed FUN
    Pro Comp wheels General Grabber AT tires
    @crashngiggles @zippo88 @the_black_tacoma
    Ok, I got the flares back from the paint shop and took some measurements against the factory flares. I did my best to take the measurements from the same spots from flare to flare. Preliminary things look like the flares will cover for wider tires, but I do not know anything about taller yet or not...but I doubt it.
    The paint is still really soft so they will not be getting mounted for another week or so. Please stay tuned.
  11. Jan 28, 2021 at 4:06 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Have you tried the GOOGLE?
  12. Jan 28, 2021 at 4:07 PM
    LC7
    LC7 Well-Known Member
    Far Nor Cal
    2011 MGM DCLB 4x4 4.0L
    5100's w/885's, SPC LR UCA, Deaver U402 stage 1 w/Fox 2.0 RR, 285/75r17 Toyo AT III load C on SCS F5, Dynabeads
    No more BRRRRRRT-BRRRT! :D :cheers:
  13. Jan 28, 2021 at 4:16 PM
    Miller time
    Shawn
    yes and I found this https://www.chilkatdesigns.com/
    but $500 seems like a lot. Anyone know of a cheaper brand like $200-$300ish
    gotblika[QUOTED] likes this.
  14. Jan 28, 2021 at 4:20 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Thank you for this. So how it looks from the pictures......about an inch overall more coverage for wider tires and more negative offset wheels......I am correct in that assumption?
  15. Jan 28, 2021 at 4:25 PM
    CatmanUSN
    CatmanUSN Active Member
    Jim
    PacNorthWest
    2012 MGM Tacoma TRD Sport DCLB
    NorthWest Punisher... 32s, 265-70R17 Mazama Open Range on Fuel Shok Gun Metal Gray, full RCI Aluminum Skids, RCI Fuel Skid, N-Fab Rockers, Hooke Road Recovery Rear Bumper, SSO Hybrid Front w/Bull Bar, Warn VR Evo 10-S, 3 inch lift- Bilstein 5100 all around, Toytec Springs, AAL, SPC UCAs, Pedal Commander, Line-X Bushwackers, ARE Z-Series in OTR... ARB Front and Back Lockers, ARB CKMA12 Air Compressor, Auxbeam Control Pod...
    I reversed the bolts, put large ones in the top, worked much better. The top cap worked better on top of the New insert... As it should have, thanks TW team!
  16. Jan 28, 2021 at 4:37 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    I like those mirrors!
    Tacos4ever15 likes this.
  17. Jan 28, 2021 at 4:49 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Haven't installed yet but picked these bad boys up
  18. Jan 28, 2021 at 4:57 PM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    dpele[QUOTED] likes this.
  19. Jan 28, 2021 at 5:02 PM
    dwick37
    dwick37 Member
    SLC Utah
    2015 TRD Sport 2021 TRD PRO 4Runner (Wife's)
    What head unit is that?
    JR SLASH 33 likes this.
  20. Jan 28, 2021 at 5:08 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    What the deal on those side mirrors? They look great :)
