  1. Jan 30, 2021 at 10:59 AM
    AKTacoParty
    AKTacoParty Well-Known Member
    Jake
    Astoria, OR
    2013 DCLB
    885s, Dakars, Bilsteins, Allpro Sliders, Archive Garage Hammer Hangers, Wheelers Ubolt flip, super bumps, RCI front skid
    Swapped headlights to trd pros
  2. Jan 30, 2021 at 12:16 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This just arrived. Going on in a bit. 42B98B34-228B-4DE0-A4FD-43F4735FCF7B.jpgB1CF1BFA-81CA-4F70-B2CA-44D8667BD1F5.jpg
  3. Jan 30, 2021 at 1:02 PM
    Toywoodsguy82
    Toywoodsguy82 Well-Known Member
    Patrick
    Oregon
    2007 Silver DCSB TRDOR 2017 black crewmax tundra
    Body Armor front and rear bumpers Method 703 Wheels Falken wildpeak AT3’s Ironman Foam Cell Pro kit
    Well... on Wednesday I did front diff and transfer case oil change...
    As well as replaced my warped rotors that were warrantied and in the process decided to put new calipers on.
    In the process of the brake job my mechanic friend said I should replace my driver side wheel bearing sooner rather then later... but that will be a project for another day.
  4. Jan 30, 2021 at 1:44 PM
    memtaco
    memtaco Well-Known Member
    Stephen
    2023 TRD OR in Lunar Rock
    Installed Diode Dynamics SS3 fogs in the sport yellow. Super quick to do coming through the fender liner from underneath. Got the aimed down as far as I could to not annoy other drivers. Gonna take them for a spin after dark.
  5. Jan 30, 2021 at 1:51 PM
    gotoman1969
    Installed. Quality is 100%!!! Time from order to arrival 3 days!!!! Way to go Teton Workshop. 89A9D48D-A21A-41C4-A17F-2052AFF330E6.jpg302DD6F0-8B23-4CE4-8573-BB84ACF09472.jpg EDC6B712-A689-44F3-8295-BD31D2299888.jpg
  6. Jan 30, 2021 at 2:00 PM
    Squatch_Taco
    Squatch_Taco Founder of Team Overland
    Matthew
    Southern Oregon
    2014 Pyrite Mica Tacoma TRD "Squatch Edition"
    Performance: TRD Supercharger :D HP Tune using Overland Tailor Tuning with custom supercharged calibration. Cravenspeed Flex pod with Auto Meter Boost and Wideband A/F gauge. AFE Stage 2 CAI In House Fabrication Stainless Snorkel Aeroturbine 2525XL muffler, with rerouted crossover and chopped exhaust pipe Sierra 4.88 R&P gears for front axle Yukon 4.88 R&P gears for rear axle Power: CBI Group 31 battery cage Odyssey Group 31 extreme duty X2 Power AGM Battery 100W Overland Solar Panel Landstar Solar Charge Controller Redarc Smart Battery Isolator Busman Circuit Breaker Blue Sea aux fuse box (12) Blue Sea aux fuse box (6) Newport Vessels trolling motor smart battery box and power center with usb and DC ports Suspension & Brakes: Icon 2.5 EXT remote reservoir Coil-overs with 14" 700# springs (set at about 2.5 inches of lift) Camburg UCA's w/ moog balljoints Icon EXT VS 2.0 remote reservoir rear shocks Old Man Emu Dakar rear leaf pack Wheelers Superbumps front and rear Extended stainless steel rear brake lines Old Man Emu carrier bearing drop Sway bar delete All-Pro U-Bolt flip Power Stop Carbon Fiber Ceramic Disc Brake Pads Power Stop Drilled and Slotted Brake Rotors Power Stop Rear Break Shoes Interior: Expedition Essentials dash mount Rago Fabrication center console mount w/ Bridge Various RAM Mounts Dorman universal seat heaters Blue Sea Systems 4 volt dual USB port wired to constant power Weathertech (black) floorliners front and rear Bird Dawg industries rear view mirror riser Molle visor organizer OEM door sill protectors Salex console organizer Liviqily molle sun visor organizer Wet Okole seat covers front and rear (black) LED Map and Dome lights Kenwood Excelon DNX695S Double Din JL Audio C3 front door speakers JL Audio C2 rear door speakers JL Audio Stealth box w/ 1 10" sub Kenwood Excelon 5 channel 800w amp Navigation: Garmin inReach mini iPad mini 5th Gen Earthmate GPS App Gaia GPS MotionX-GPS Exterior: Outer Tents Osprey Slimline Aluminum rooftop tent Snugtop Rebel Sportsman Canopy Prinsu Cabrac Prinsu Top Rack Debadged Cravenspeed Stubby antenna Mud flap delete OEM bed mat "Hi-Lift" - Hi-Lift mount Color matched Satoshi grille from TW member StealthTaco BAMF bed tie downs 15% Tint on all door windows "Custom" trail pinstriping CVT 55" Summit Series awning in grey Cut fenders to clear 35’s Auto Ventshade Window Deflectors Lighting: AlphaRex USA 880752 Nova Series Full LED Projector Headlights Rigid SR 20 inch light bar Rigid Dually floods OTRATTW switches LED license plate lights Aurora Diffused 40w pods in rear bumper Wheels/Tires: (5) BFGoodrich Mud Terrain T/A KM3 35X12.5r17 (5) 17x8.5 SCS Ray 10's in matte dark bronze 4.30 BS Armor: BAMF Sliders w/kickout (weld on) Pelfreybilt steel plate bumper with center hoop and fog/LED bar cutouts Brute Force Fab High Clearance rear bumper (custom length side pieces) with swing out and double Jerry can holder and C4 Fabrication rear camera relocate Pelfreybilt steel IFS skid Pelfreybilt steel Mid skid Pelfreybilt steel T-case skid Recovery: Warn 9.5xps winch and Factor 55 1.0 Hawse fairlead Factor 55 Flat Link Warn Medium-Duty Epic Recovery Kit Misc ropes/straps Fiskers Axe Hults Bruk Axe 48" Hi-Lift Jack Hi-Lift Jack and Quick Fist Shovel Mount Fiskars Steel Shovel MaxTrax Boards and Mount ARB tire repair kit Smittybilt receiver hitch shackle Coms: Yeasu FTM-400DR Dual Band Ham Radio Uniden 510XL CB 3ft (offroad) and 2ft (in town) Firestik Tram 140MHz-170MHz + 430MHz-470MHz Dual Band NMO Antenna Baeofeng Handheld 2m radio Relentless Fab Passenger side antenna hood mount Relentless Fab driver-side antenna hood mount Misc mods: 12volt.solution Remote Starter DFG-Offroad fridge slide SnoMaster fridge Prinsu Fill Plates repurposed to mount fridge Gear Tech Customs wheel well liners Diff breather extension (behind taillight) Seat belt beep disable Door lock/Unlock beep disable ARB CMKA12 Onboard air compressor under the hood ARB inflation kit Anti-Dark underhood lights Redline QuickLift Plus hood struts Locker anytime mod Black "Team Overland" Trasharoo Big cab mount chop BFH massaged pinch weld Trimmed fender flares ECGS diff bushing Headliner patches #EAF CaliRaised Bedside stiffeners
    Added a dual battery to power the Snomaster 12v fridge. Also using the dual battery to run some accessories off the constant power like the canopy light and probably some other stuff later on. I used a trolling motor battery box, a Redarc smart battery isolator, busman circuit breaker, and a Blue Sea fuse panel.
  7. Jan 30, 2021 at 2:04 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    I did something that you're NEVER supposed to do with a 4cyl. Taco- I pulled my 5x10 utility trailer with a cord of firewood. Up a bunch of hills.
    I somehow managed to survive the experience! LOL
  8. Jan 30, 2021 at 2:53 PM
    CatmanUSN
    CatmanUSN Active Member
    Jim
    PacNorthWest
    2012 MGM Tacoma TRD Sport DCLB
    NorthWest Punisher... 32s, 265-70R17 Mazama Open Range on Fuel Shok Gun Metal Gray, full RCI Aluminum Skids, RCI Fuel Skid, N-Fab Rockers, Hooke Road Recovery Rear Bumper, SSO Hybrid Front w/Bull Bar, Warn VR Evo 10-S, 3 inch lift- Bilstein 5100 all around, Toytec Springs, AAL, SPC UCAs, Pedal Commander, Line-X Bushwackers, ARE Z-Series in OTR... ARB Front and Back Lockers, ARB CKMA12 Air Compressor, Auxbeam Control Pod...
    Gotblika was right on, put new cap with large OEM T-30 heads, worked like a Champ. Thanks Gotblika! See better pics.
    TomTwo, Quakes15, Tacoma13_NC and 6 others like this.
  9. Jan 30, 2021 at 3:08 PM
    the_bluetaco
    the_bluetaco Well-Known Member
    Artem
    California
    2014 TRD Off Road DCSB
    Method Racing Wheels-Double Standards 16x8 Falken Wildpeak AT3W -285/75R16 FRONT: Bilstein 6112, TOTAL CHAOS FABRICATION UCAs REAR: Bilstein 5160, OME DAKAR leaf spring set
    Doing a tire rotation and saw that the rack and pinion boot looked wet. I do have clunking when turning the wheel at slow speeds, could this be the cause?
    whatstcp, DG92071 and irayfz6 like this.
  10. Jan 30, 2021 at 3:09 PM
    etx
    etx Active Member
    Smithwick
    07 4x4 DCLB
    Revtek garbage spacer
    Installed arb bumper yesterday, got sidetracked need to finish wiring arb's led "fog" lights.2 diodes, honestly underwhelmed. 2 diodes?
    FreshPots, 13txtaco, TOYTONKA and 4 others like this.
  11. Jan 30, 2021 at 3:10 PM
    etx
    etx Active Member
    Smithwick
    07 4x4 DCLB
    I would say yes
    the_bluetaco[QUOTED] likes this.
  12. Jan 30, 2021 at 3:29 PM
    Steevoreeno
    Steevoreeno Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
  13. Jan 30, 2021 at 3:30 PM
    Crazy Nick
    Crazy Nick Well-Known Member
    Crazy
    03" TRD 4X2, 07" 4Runner 4X4, 2015 TRD Sport 4X4
    She cleans up nice..
  14. Jan 30, 2021 at 3:39 PM
    Nato1012
    Nato1012 Well-Known Member
    Silver Tacoma Double Cab
    None
    Put on the yakima overhaul side bars.
  15. Jan 30, 2021 at 3:55 PM
    Toywoodsguy82
    Patrick
    Oregon
    or CV
  16. Jan 30, 2021 at 4:11 PM
    memtaco
    Stephen
    Did a test drive. Not sure I love the yellow but I want to try again when it’s not raining. In the rain, the sports didn’t seem as bright as the OEM fog lights.
    JR SLASH 33 likes this.
  17. Jan 30, 2021 at 4:58 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    This is why I put Baja design pods in my bumper
    irayfz6 likes this.
  18. Jan 30, 2021 at 4:58 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    They are bright. Like you said could've been the rain.
    JR SLASH 33 and memtaco[QUOTED] like this.
  19. Jan 30, 2021 at 5:13 PM
    DG92071
    DG92071 Well-Known Member
    It's working correctly:)
  20. Jan 30, 2021 at 6:28 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Towed it down to KOH.
