  1. Feb 5, 2021 at 8:50 PM
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Neg 3 deg exhaust gears and a relentless stinger bumper)
  2. Feb 5, 2021 at 9:00 PM
    El_Capitan3
    El_Capitan3 @ElCapitan355
    2013 Tacoma TRD Sport 4x4
    Clean and Simple
    Installing the Wheelers progressive 3 leaf AAL soon. Hard to tell in pic but currently rocking a lean.
  3. Feb 5, 2021 at 9:11 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I got the truck back on four wheels today. Pin back in the leaf springs so they are all put back together. The U-bolts and brake drum from the burned donor truck cleaned up good, although the drum was a bitch to get off and needed a light turn.
    But... as with all days when you think you've got it licked, once the wheel was back on it wouldn't spin.
    I'll be taking the wheel and drum off tomorrow to see WTH.
    Northbound_Taco and Daves300 like this.
  4. Feb 5, 2021 at 9:14 PM
    DG92071
    DG92071 Well-Known Member
    Today I checked the trucks mpg and I regretted that decision. 10.2
    A repost of my fav pic of my truck.
    I had PowerStop rotors and proprietary pads on my 1st gen. I towed boats with that truck. I never had a problem with those drilled and slotted rotors and pads. Quite, minimal dust, and it stopped better than stock.
    For this 2nd gen of mine it has larger 4Runner rotors, calipers, and super cheap Chinese pads. Lol. Works outstanding.
    X2!
  5. Feb 6, 2021 at 12:09 AM
    thiencao95
    thiencao95 Well-Known Member
    Houston, TX
    13’ DCSB TRD Sport 4x4
    Did you have a dealer or shop install the katzkin for you? Or did you do it yourself?
  6. Feb 6, 2021 at 12:48 AM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Came on the truck when I bought it pre owned.
  7. Feb 6, 2021 at 1:31 AM
    ThaiChillyTaco
    ThaiChillyTaco David aka Chilly aka Booty Freak
    David
    Goose Creek - South Carolina
    2021 Cement Grey TRD Off-road 4x4 Longbed
    Rough Country 3.5 Lift SCS BR6 wheels rolling in 285/70/17 Falken Wildpeaks
    Can never go wrong with Wildpeaks on SCS rims. :fistbump:
    LitFuse and airmax233[QUOTED] like this.
  8. Feb 6, 2021 at 3:01 AM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    Get a ratcheting strap wrap the tire and pull it towards your tow hitch. Mine use to move when froading and kiss the pumpkin or squish n pop lol
  9. Feb 6, 2021 at 3:02 AM
    Beer-toe
    Berto
    Menifee
    Dad Mobile
    Stickers
    Fuckin sweet! I want the -38
    airmax233[QUOTED] likes this.
  10. Feb 6, 2021 at 6:10 AM
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    Snapped the bolt on the brake line bracket. Fuck.
    146929415_10226238788056344_481846796717_89041011bae484b1991811e286a6d340d3183393.jpg
    LitFuse, GonzoQuick, whatstcp and 3 others like this.
  11. Feb 6, 2021 at 6:52 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I have a used pair for cheap. Pm me if interested
  12. Feb 6, 2021 at 8:59 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My wheels have two valve stems and this morning I started the journey of installing powertank monster valves in place of one of them. With powertank (co2) the choke point of airing up and down is the stock valve stem. They created a mega high flow one to fix that. I can air down in less than 20 seconds and airing up is about the same, 25 seconds. Pretty wild. This is with a 35” tire.
    https://www.youtube.com/watch?v=iaSg9pQSAWo&feature=youtu.be
  13. Feb 6, 2021 at 9:20 AM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    Reinstalled my Pedal Commander today, because I just can't deal with the factory mushy pedal, and I don't want to drive around in 4 all of the time either. I removed the leaf-spring U-bolt clamps I put on last week because they didn't help with vibrations at all, just stiffened up the ride quality which I didn't like. I also ordered a set of SDHQ A-pillar mounts and a set of Baja Design S2 wide-cornering pods to set up for ditch lights.
  14. Feb 6, 2021 at 10:32 AM
    cltucker
    cltucker Member
    2014 Gray Tacoma Limited Crew Cab
    Blacked out the side mirrors, changed chrome door handles, and got new wheels. First bit of modification I've done. Eventually planning to go bigger on the tires and add some lift.IMG_4410.HEIC.jpg
    DG92071, irayfz6, whatstcp and 2 others like this.
  15. Feb 6, 2021 at 11:16 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Transmission DAF
    dpele, LitFuse, DG92071 and 3 others like this.
  16. Feb 6, 2021 at 11:16 AM
    TacoManSam
    TacoManSam Well-Known Member
    Sam
    Saint Augustine, FL
    2013 White Tacoma TRD Sport DCLB V6 4x4
    Faux TRD Pro Grille | 3rd Gen TRD-OR suspension | 6' Leer Topper | Running Boards
    :ohsnap:
    That sucks... I had to deal with a similar situation when replacing my old rusty hitch recently. But it was on a separate part, not yet attached to the truck. Ended up taking it my local mechanic and he helped me out.
    Do you have any tools to extract the shaft of the bolt?
    whatstcp likes this.
  17. Feb 6, 2021 at 12:48 PM
    dwick37
    dwick37 Member
    SLC Utah
    2015 TRD Sport 2021 TRD PRO 4Runner (Wife's)
    Intalled new wheels and tires and sound deadening on the back wall.
    FBA18452-6F64-4851-9AE9-56FC8A81078F.jpg 69F4E9C7-EF42-4FF6-8128-323E31250A1D.jpg
  18. Feb 6, 2021 at 2:21 PM
    Iz88
    Iz88 Member
    11 reg cab
    Installed my new “trunk” to make the regular cab a better grocery getter. Used blind fasteners in the bed to make it easily removable when needed.
  19. Feb 6, 2021 at 2:26 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Finished up my 'small' lift this afternoon which consisted of having a shop install the OME 883 coils and myself adding the rear Headstrong 3-leaf AAL (removed overload leaf in process):
    Before - OEM Suspension on Bilstein shocks, fronts set at .85"
    FD - 20.75"
    FP - 21"
    RD - 21.75"
    RP - 22"
    After - OME 883 coils up front and headstrong 3-leaf progressive AAL in rear with Bilsteins on all four corners (front set back to 0")
    FD - 20.5"
    FP - 20.5"
    RD - 23"
    RP - 23.5"
    I would give my measurements a +/- .5"
    So, with that said it looks like the 883's on bottom notch kept the front roughly the same height as the OEM coils set at the first notch. The HS AAL is pretty accurate at 1.5"-ish with the overload leaf removed. I'll be honest I thought the 883's would provide a smidgen more lift up front but that's okay.
    My goal with this lift is to be able to run a shell and have the truck still sit level but with like the smallest achievable lift possible. Although I don't have a shell yet I think I accomplished that so I am happy.
  20. Feb 6, 2021 at 2:46 PM
    ah805
    ah805 Well-Known Member
    Alex
    Central Coast, CA
    2013 Trd Sport DCLB
    Had the day off today so I washed the truck and did a BHLM to the spare set.
