  1. Feb 8, 2021 at 7:02 AM
    LitFuse
    LitFuse Member
    An island in Washington
    2007 Pirate Ship
    40 cannons and a black flag
    Saturday AlphaRex Nova and Baja Designs Squadron SAE upgrade
  2. Feb 8, 2021 at 7:18 AM
    DG92071
    DG92071 Well-Known Member
    The BFG's measured 35". It's got Goodyears now with 6k miles that measure exactly 37".
    theolee likes this.
  3. Feb 8, 2021 at 7:28 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    This bitch has got me stumped. I had the wheel off twenty times yesterday and when it goes back on something rubs enough to make the wheel hard to turn. At least at this point I can move the truck. The shoes are adjusted down to the maximium and at this point I've beaten the backing plate away from the drum so there is visible daylight around the entire drum... but when the wheel goes on something rubs. One thing... I can tell the axle is bent so it will have to be replaced.Today my goal is to get the driveshaft hooked back up so the truck won't roll.
    Still to do: Hook up driveshaft. Remove bed to straighten frame and (reinforce?) spring perch. Replace axle, bearing, and backing plate. New shocks. Brakes? Work the quarter panel until it's hard to see the dents from twenty feet away. Replace bed.
    Celebrate with a test drive and a drink...
    DG92071 likes this.
  4. Feb 8, 2021 at 7:48 AM
    Travlr
    Middle'a Utah
    Same thing happened to my truck, and I couldn't find the stop leak I used long ago that worked so well, Silver Seal, so I tried another product. It seemed to work well for about six months and then started to leak again. I used the same product... and the heater core got plugged up. Called the sealer help line and they said to use vinegar to flush the core, so I flushed the entire system and now I'm losing coolant again, froth in the oil but not nearly as bad as yours. I'm thinking of using some AlumaSeal as it is similar to Silver Seal.
    In the meantime I bought a wrecked truck, same year, low miles, just in case.
    Good luck.
    DG92071 and whatstcp like this.
  5. Feb 8, 2021 at 7:54 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    I have a pair from last Christmas I haven't installed yet. This is making me want to!
    JR SLASH 33[QUOTED] likes this.
  6. Feb 8, 2021 at 7:54 AM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    the more I look at these headlights the more I like them, the LED strip follows the hood/bumper lines nicely
    DG92071 and JR SLASH 33 like this.
  7. Feb 8, 2021 at 8:16 AM
    BraddahRO
    BraddahRO I S L A N D E R
    RO
    Nor-CAL
    2013 TRD Sport DCSB
    Toytec 3” lift SPC UCA Shorty Antenna 3rd gen 16” wheels 33” Cooper Discoverer ST MAXX TRD Pro front grill OEM skid pad Black Widow muffler dumped with OEM exhaust tip Husky floor mats OEM TRD skid plate Tinted front windows 35% Tinted windshield 30% OEM bed mat OEM running boards OEM hitch cover OEM TRD Pro headlights Cali Raised fog lights AlphaRex taillights OEM bed extender Tonneau Backflip Sequential side mirror turn signals
    Running boards installed. Wife and kids approved. Now onto new tires and a lift.
  8. Feb 8, 2021 at 8:31 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Did you recover those voids with something to keep moisture out?
    If not, I just put butyl deadener over them and made sure it was sealed along the entire perimeter.
  9. Feb 8, 2021 at 8:50 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    me 2
    Island Cruiser likes this.
  10. Feb 8, 2021 at 9:11 AM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    35 or 37, either way I couldn’t be happier with 5:29 and more people should probably consider this gear ratio
  11. Feb 8, 2021 at 10:07 AM
    GRNT4R
    GRNT4R Well-Known Member
    NC - Triad
    2010 TRD Sport DCLB 4WD Silver
    TBD
    Looks good, where did you get the foam ring for the tweeter?
  12. Feb 8, 2021 at 10:21 AM
    the_bluetaco
    the_bluetaco Well-Known Member
    Artem
    California
    2014 TRD Off Road DCSB
    Method Racing Wheels-Double Standards 16x8 Falken Wildpeak AT3W -285/75R16 FRONT: Bilstein 6112, TOTAL CHAOS FABRICATION UCAs REAR: Bilstein 5160, OME DAKAR leaf spring set
    I recommend making the whole, where you change the oil, bigger. My first time changing the oil with the skids resulted in oil going over the skids and out the sides all over the ground. luckily I had cardboard all around so it wasnt a big deal.
    FreshPots[QUOTED] likes this.
  13. Feb 8, 2021 at 10:34 AM
    Northbound_Taco
    09 Off road build
    Fumoto valve will solve that issue. I didn't have to do anything to mine.
    FreshPots likes this.
  14. Feb 8, 2021 at 10:54 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Those Kicker tweeters come with it.
    GRNT4R[QUOTED] likes this.
  15. Feb 8, 2021 at 11:20 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    What wheels and size are those? They look sick!
  16. Feb 8, 2021 at 11:59 AM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Thanks for the heads up. I've got a fumoto valve and the stream is pretty small. If it makes a mess next oil change I'll make adjustments.
  17. Feb 8, 2021 at 12:47 PM
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    I stuck a small piece of hose to the end of my Fumoto. It is long enough to pass the skid. When done draining plug and slide on top of skid and done.
    Be Safe All...
    Dan
  18. Feb 8, 2021 at 12:50 PM
    Sideways1
    Dan
    Portland Oregon
    Installed my black controls on the wheel today. I like the way it looks.
    Be Safe All...
    Dan
  19. Feb 8, 2021 at 12:56 PM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    That looks great!
    Sideways1[QUOTED] likes this.
  20. Feb 8, 2021 at 2:06 PM
    Doc Samson
    Doc Samson Well-Known Member
    Almost NoVA
    2009 Tacoma TRD Sport
    None... yet.
    Thanks, I was able to determine that it was just due to lot's of short trips in cold weather. I drained the oil yesterday after a long trip and, other than being dirty, it looked good...
