  1. Mar 3, 2021 at 5:42 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Since I’m running my fridge off it from a single group 27 AGM battery, I thought it would be a good idea to keep and eye on things from there.
    dpele, DG92071 and FreshPots[QUOTED] like this.
  2. Mar 3, 2021 at 5:43 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    how long can you run your fridge without starting the truck? Also have a 27f AGM and looking to add a fridge this spring.
    FreshPots likes this.
  3. Mar 3, 2021 at 5:44 PM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    I'm in a similar boat except I also have a Jackery 500 and solar, if/when the Jackery runs out I can hook up to the truck now without leaving keys in it. My fridge and fridge remote both display current battery voltage so I'll just be going off that or my display in the cab.
  4. Mar 3, 2021 at 5:46 PM
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Was about to ask this question as well. I also have a 27f AGM battery. I was going to test this weekend and see how long it'll go before the safety cutoff engages.
  5. Mar 3, 2021 at 5:46 PM
    deekyn
    Dustin
    Yellowstone
    I’ve only run it for like 36 hours... I’ve not run it to the ground yet. I’ve got a battery jump pack. And will likely add solar at some point. But the fridge (Dometic) is so energy efficient I’m not worried about it for the time being.
  6. Mar 3, 2021 at 5:47 PM
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Also I just realized what your avatar is. I literally have that image tattooed over my heart. :thumbsup:
  7. Mar 3, 2021 at 5:47 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Just a question about the 110 socket... Can you run a freezer off it as you motor down the road? I just got a truck with one and have never tried using it.
    Effenglide and FreshPots[QUOTED] like this.
  8. Mar 3, 2021 at 5:48 PM
    deekyn
    Dustin
    Yellowstone
    I have it on my arm... guess we are tattoo buddies.
  9. Mar 3, 2021 at 5:50 PM
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Yes, the 110 socket will do 100 watts while driving (more than enough for a fridge/freezer) or 400 watts while running and parked. I added the 12v sockets for my 12v fridge while camping.
    Kuntrykid and deekyn like this.
  10. Mar 3, 2021 at 5:54 PM
    Travlr
    Middle'a Utah
    So the 12v fridge runs off an extra battery in the bed of the truck, charged as you drive or idle?
  11. Mar 3, 2021 at 6:07 PM
    FreshPots
    Dylan
    Cuyahoga Falls, OH
    Never enough
    Instead of going dual battery I ended up getting a Jackery 500 and 100watt solar pack. I will use that while camping and run it off my single 27F AGM battery while on the move and backup for if its raining and the Jackery has died. The Jackery ran the fridge for over 48 hours without the solar during tests and assuming it's sunny out the solar will charge the battery faster than the fridge can drain it. Power in the truck bed is backup/failsafe. That being said I want to run tests and see how long the truck battery will last when running the fridge solo. I also have a Noco jump pack in case of emergency.
    Travlr[QUOTED], Effenglide and deekyn like this.
  12. Mar 3, 2021 at 7:17 PM
    TrdAaron
    TrdAaron Well-Known Member
    Ventura, CA
    2012 Silver Tacoma TRD Off Road Access Cab 6MT
    Full OME BP-51 kit, TRD Pro 16in wheels, bel air camper, arb bumper, some other neat stuff….
    Right now I only rub on big dips like going into driveways. I didn’t do any trimming but I would like to do a CMC to be safe and trim a little of the fender liner. I also purchased my tires with the wheels used and they were at about 70% tread maybe, so idk if new tires would rub
  13. Mar 3, 2021 at 7:21 PM
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    Traded the taco for a Lambo..........jk! It wouldn’t make me nearly as happy as ol’ reliable does!
  14. Mar 3, 2021 at 7:36 PM
    Eaux8Taceaux
    Eaux8Taceaux Well-Known Member
    Ben
    Texas
    2008 Tacoma TRD Sport 4x4
  15. Mar 3, 2021 at 7:39 PM
    singletrack_ftw
    singletrack_ftw “I chopped the wrong leaf!”
    Tyler
    AZ
    ‘08 TRD OR 4wd
    https://www.tacomaworld.com/threads/singletrack’s-‘dad-shred-build-thread’-i’m-just-doing-it-for-the-kids.619250/ Sos offroad sliders (kickout + filler) Sos offroad full belly skids (steel) Sos offroad front recovery point Sos offroad concepts HC rear bumper with bedside kickout tubes Marlin Crawler LCA frame brace kit Trail Gear rear diff cover Bilstein 5100 + OME 885 Total Chaos UCA BILSTEIN b110 OME Dakar standard pack Wheelers Ubolt flip kit Wheelers Superbump f/r Wheelers SS extended brake lines FN five star 16x8 -25 Milestar Patagonia MT 315/75r16 Custom projector retrofit (acme super h1 + morimoto 4300k) Baja Designs S2 sport ditch pods on CBI ditch pod mounts Amazon AMAK rock lights CMC CB radio hardmount
    Wired up my new Chinese pods to my fog harness and I’m very impressed with the light output. Naturally, Had to flex on my street. I literally just removed my factory fogs & drilled a hole in the bottom of the fog pocket for these pods and then butt connected fog wires to the pod harness after chopping off the factory connector. I wish I did this a long time ago.
    1. Headlights only
    2. Fog lights only
    3. Flexin on my neighbors
  16. Mar 3, 2021 at 7:50 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Any idea why there is that bent section that greatly reduces clearance? Maybe it's for exhaust on a double cab?
    I hate to say it but, I'm pretty disappointed that the tranny skid needs an extension and the transfer skid sticks way down like that.
    I didn't spend all that money to have to fab my own parts just to make it work. Plus, I got the aluminum version and the carriage bolt spun first try. Yay.
    I hope yours works out better for you...
  17. Mar 3, 2021 at 8:02 PM
    MSN88longbed
    Goleta, CA
    I will probably make one out of 3/16 steel eventually. For now I have a piece of 1/4 x 4" that I will use as an adapter. Ugh
  18. Mar 3, 2021 at 8:04 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Got my shocks back from getting rebuilt and revalved. Install tomorrow or Friday
  19. Mar 3, 2021 at 8:18 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    My lil 4 popper does good w/ 33s. I also ha e a Mobtown offroad bumper. Granted it also has a injen intake, lce headers & clutch just put in last week.
  20. Mar 3, 2021 at 8:30 PM
    fatfurious2
    David
    Ashburn, VA
    yes. I have a box of the hardware that was removed originally. I didnt send those to Downsouth. One thing that I didnt like, they did not replace the lower bearing. I can move it by hand. I know it could be an issue later
    whatstcp[QUOTED] likes this.
