  1. Mar 11, 2021 at 5:17 PM
    Stemmy
    Stemmy Certified Wombat Rancher
    Rob
    Pennsylvania
    2013 Pyrite Mica DCLB
    I'm gonna do that possibly this weekend. The lower idler pulley has the squeaks so I'm replacing all 3, the tensioner, belt, hoses, thermostat & waterpump while its apart. I leave for Idaho (driving from PA) in about 2 months, doing it all for peace of mind even though I only have 96K on my truck.
    Micbt25[QUOTED] likes this.
  2. Mar 11, 2021 at 5:18 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    The sound deadening alone helped. I want to pull the headliner back down to run wires so I figured, while it was down I should add some of this stuff.
    outxider[QUOTED] likes this.
  3. Mar 11, 2021 at 5:25 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I have a 2015 with 100k miles, I checked all the idler pulleys and they sounded good and spun without resistance, guess I’m lucky. I did all that for peace of mind too, the coolant and belt looked fine, but why take the chance. What’s the saying, an ounce of prevention...It also satisfies my OCD!
    Stemmy[QUOTED] likes this.
  4. Mar 11, 2021 at 5:36 PM
    Stemmy
    Rob
    Pennsylvania
    THIS, haha. My coolant is good but its not gonna hurt to change it, need to find some hose for the block drains yet.
  5. Mar 11, 2021 at 5:46 PM
    Micbt25
    TM
    Those block drains were tricky, just have enough 3/8s extensions, the drivers side is the harder one to reach and you get the least amount of coolant from. They’re not hard to get to, just be persist, very easy job tho. Take a look at the attached manual file, it’s all very straightforward. Good luck!
  6. Mar 11, 2021 at 6:36 PM
    patos tacoma
    patos tacoma Well-Known Member
    When you change the coolant flush the heater core.....incredible what came out of mine, and it was nice to get a better heater going.
  7. Mar 11, 2021 at 6:44 PM
    Whitetacomacalifornia
    Whitetacomacalifornia Well-Known Member
    Steven
    2011 Tacoma DCLB
    Mid travel with camburg arms and fox dsc coilovers. Rear SUA soon
    Giant motorsports bolt on kit but with 3 link set up
    m00seNUckLEz[QUOTED] likes this.
  8. Mar 11, 2021 at 6:52 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    This is on my to-do list
  9. Mar 11, 2021 at 7:39 PM
    that guy again
    that guy again Well-Known Member
    NW Oregon
    2012 DCLB
    Removed the badges and gave her a bath
  10. Mar 11, 2021 at 8:32 PM
    Tejas
    Tejas Member
    Texas
    PreRunner
    RollnLock Added Tie Downs Katzkin Leather LED lights behind grill
    Just hit 80k miles on my 2012 Prerunner. Switching out stock shocks for Bilstein 5100s all around. Thinking about changing tires from BF Goodrich TA KO2s to Geolander AT G015. Chasing a better ride for highway trips.
    1Shifter and Grossomotto like this.
  11. Mar 11, 2021 at 9:25 PM
    tazgohome
    tazgohome Well-Known Member
    2009 Tacoma 4X4 SR5 V6 DCSB
    Congrats. Pay off the wife's car in a month or two. No more payments for awhile.
  12. Mar 11, 2021 at 9:36 PM
    Hunter_Bick12
    Hunter_Bick12 Just a Yota guy
    Hunter
    Alabama
    2011 Black DCSB TX TRD Prerunner, 1986 Gray SR5 4x4
    Update: Smittybilt Overlander Gen 2 is installed. I honestly could not be happier with my purchase. Some people like to knock Smittybilt, and I’m unsure why, but this is one hell of a tent. I say that without even taking into consideration that it’s one of the lowest priced RTT you will find. This is very well made and the only thing I found remotely close to being an issue was the ladder mounts potentially rubbing a hole in the cover over time. I used some fabric from the packaging to fix this in about 30 minutes. Very excited to get out this weekend and use it!
  13. Mar 11, 2021 at 9:40 PM
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    Very nice, sir.
  14. Mar 11, 2021 at 9:44 PM
    m00seNUckLEz
    Fresno, CA
    Under Construction
    I like how these discretely hide the mounting points in the back. I several accessories connected and you cant even tell.
    Correct.
    A little snug. I just bent the main positive end down a little bit to accommodate.
  15. Mar 11, 2021 at 9:49 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Replaced the Schrader valve on the in cab manifold with an 8mm QC that connects to a HP air canister. Either the 2 gallon tank or the bottled air could supply enough to lift the cap 20” silently with 4 - SC40 x 500 double acting cylinders. Nice for those late camp arrivals. The compressor is basically for filling the tank while on the move or airing up. Since I use bottled HP air for work(paintball rig for pneumatic guns) I added the connector as an alternative/backup. In a pinch a bike pump could lift the cap, about like filling 2- mtb tires, more if the cap is loaded.
  16. Mar 11, 2021 at 9:55 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Took it for a drive :mudding:
    TacoTime10, dino41, DG92071 and 19 others like this.
  17. Mar 11, 2021 at 9:57 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    If you only cut the post loop off the neg battery clamp end(save the crimp and the part with the bolt hole) you can use that as a lug. The factory clamp is tinned copper.
  18. Mar 11, 2021 at 10:18 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Just because I know I'll get some responses here, when should I worry about replacing my alternator, battery, serp belt, pulleys etc? I have 141k miles, but everything seems to be running smoothly.
  19. Mar 11, 2021 at 10:32 PM
    Crazy Nick
    Crazy Nick Well-Known Member
    Crazy
    03" TRD 4X2, 07" 4Runner 4X4, 2015 TRD Sport 4X4
    They grow up so fast..
  20. Mar 11, 2021 at 10:40 PM
    patos tacoma
    Have Bilstein 5100s all around, and the G015s.......envious of the fatter tires, but the setup is great for Highway driving, good handling, quiet, good on gas.....
