  1. Mar 11, 2021 at 10:42 PM
    patos tacoma
    patos tacoma Well-Known Member
    Alternator when it fails, Battery no more than 4 years, I replaced SERP belt @200k to know what I had, pulleys were good....
  2. Mar 12, 2021 at 2:49 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    This has been on my to do list since last fall when I installed my Martin roof rack. Now that the weather rises getting nicer maybe it's time to get to it.
  3. Mar 12, 2021 at 4:30 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    I've got an 09 with 143k on her. I replaced the serp belt at 110k. I asked the same question about the alternator and most said to replace it when it quits. No issues with it or the pulleys
  4. Mar 12, 2021 at 4:31 AM
    dborrer
    dborrer Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    https://www.cvjreman.com/cv-axles/ top notch....
  5. Mar 12, 2021 at 5:07 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Yea but so is the compression lug. I didn't see the need to recycle it so I chucked it.
  6. Mar 12, 2021 at 5:27 AM
    BravesFan95
    BravesFan95 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR 4x4 mgm
    I know the feeling. This just happened for me
    irayfz6, theolee and loyaltothetaco like this.
  7. Mar 12, 2021 at 5:33 AM
    ctcz28
    ctcz28 Well-Known Member
    Texas
    2015 Blue Ribbon Metalic DCSB Prerunner
    Just so there is no misunderstanding, the BG EPR is used just before draining the oil for a change. You put it in an already warmed engine and let it idle for about 20 minutes to thoroughly clean the ring lands, etc, then drain with the oil. DO NOT put EPR in as an additive. BG does make an oil additive you put in with the new oil and it's called MOA. Info on these products is available on the BG Products website. One drawback to their engine oil related warranty plan is that you have to use the MOA and the oil change has to be done by a shop so goodbye to $6/qt Mobil 1 at Costco or Walmart and hello $10/qt oil at the oil change place. You can't put the MOA in yourself and keep a receipt, BG won't accept that.
  8. Mar 12, 2021 at 6:59 AM
    patos tacoma
    Is it a great product?, will it help my truck last longer?......then it’s worth the
    Money.....
    Did the BG fuel injector clean program at a shop........game changer for the good, noticeable difference in engine performance......obviously my fuel injectors were dirty.
    Kirky likes this.
  9. Mar 12, 2021 at 7:24 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    :annoyed::annoyed: Just one thing after another this week! After doing my steering boots over the weekend I noticed that my lower ball joints were fully shot after ignoring them for a year. Replaced them last night and found my passenger side front cam bolt is basically welded in place and I couldn't get it to loosen. SO after I got it aligned on Wednesday and now doing lower ball joints I have to cut out my cam bolt and install a new one tonight that I have to drive 30 miles to another dealer to pick up, get it aligned and all before I leave for a 3 week 4k mile trip that we are suppose to leave tomorrow. I hate waiting till last second to do things but I am do damn good at it!:bananadead:
    fasteddieyj, Travlr and Fluffymonkey like this.
  10. Mar 12, 2021 at 7:34 AM
    ah805
    ah805 Well-Known Member
    Alex
    Central Coast, CA
    2013 Trd Sport DCLB
    870k more to go!
  11. Mar 12, 2021 at 8:09 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    your a v6 right will? I might have a spare oem belt still I will sell you for less if you want it. And honestly unless it has a lot of internal cracking or is making noise I keep running them.
  12. Mar 12, 2021 at 8:39 AM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    my 14 has 132k. I replaced battery only when it died. replaced serp belt at 120k just for piece of mind. have old one in back for emergency. pulleys were all good. changed all oils on drive train. lubed U-Js. Alternator when it dies. baby running fine so far.
    ps. have plans to replace thermostat and water pump and fluid soon. again piece of mind. hoping to take trip, don't want to worry about them.
  13. Mar 12, 2021 at 9:22 AM
    1Shifter
    Jeff
    09 PreRunner
    Got a great deal on these 3rd Gen wheels.Tires balanced, rotated and 4 wheel alignment 20210312_120210.jpg
    winkel, Not a golfer, irayfz6 and 2 others like this.
  14. Mar 12, 2021 at 9:25 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    New tires showed up today, thanks @Discount Tire. Just waiting on wheels and I can get these and my LCAs installed and be done with mods!
    (yeah right)
  15. Mar 12, 2021 at 9:32 AM
    FreshPots
    FreshPots "Spared no expense"
    Dylan
    Cuyahoga Falls, OH
    2015 Tacoma TRD Off Road "Lars"
    Never enough
    Having looked at the Smittybilt Gen 2s I would definitely say they're very well made for the price! Compared to the gen 1s they're a completely different tent. Nice score!
    Hunter_Bick12[QUOTED] likes this.
  16. Mar 12, 2021 at 9:40 AM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    I bought a brand new Cutlass that had a power steering pump spring a seal leak at 15K. Covered under warranty, but the belt wasn't, and the dealership told me they needed to replace the belt because "it has cracks" in it.
    I told them no. I had them put the old belt on... mainly because I've seen too many mechanics advise new belts because of cracks but have not seen much evidence of those cracked belts being a problem. Belts crack after a minimal number of miles.
    I drove that car for another 80K miles and replaced the belt and the brake pads for the first time at 95K, just to sell the car in good shape.
    I really don't know how long a belt will last. I've heard they are designed to last 8 years regardless of miles, but I've seen lots of 20 year old belts.
  17. Mar 12, 2021 at 10:04 AM
    elricfate
    Cracks don't bother me unless there's more than ten in a 2" stretch - then I just swap to another OEM belt and keep the old one as a trail spare.
  18. Mar 12, 2021 at 10:18 AM
    Crazy Nick
    Crazy Nick Well-Known Member
    Crazy
    03" TRD 4X2, 07" 4Runner 4X4, 2015 TRD Sport 4X4
    I also have a 2003 TRD that I drive for work that has almost 270K, that's why the 2015 only has 40K.
    What year is your truck ?
    Not a golfer and irayfz6 like this.
  19. Mar 12, 2021 at 10:19 AM
    patos tacoma
    Cracks, no cracks....wtf
    The cost of a new belt is @$40...........let that sink in.......a family of 4 at McDonald’s for lunch.....
    And then piece of mind for 100K
    Less than hour, and you see how your pulleys are too.
    JimIowa, 4x4cajun, SJBlack and 3 others like this.
  20. Mar 12, 2021 at 10:26 AM
    Travlr
    Middle'a Utah
    :rolleyes:
