  1. Mar 21, 2021 at 8:45 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Me too till I took the BFH to the spots I was hitting.
    last time I took her out, no more rubbing
    Slashaar, 13txtaco, gabbo2112 and 4 others like this.
  2. Mar 21, 2021 at 9:20 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Looks like a load of crap to me...
  3. Mar 21, 2021 at 9:29 PM
    BIG EYE
    BIG EYE Well-Known Member
    David
    San Diego, CA
    Sold
  4. Mar 21, 2021 at 10:10 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Painted & installed anti-tweaker device from TW member @christian06 to protect against tailgate theft.
    Uni filter mod on SAI.
    Finished up installing new stereo Pioneer DMH-W4660NEX and blackout dash pieces.
    Installed and hardwired Blueskysea B4K dashcam.
  5. Mar 21, 2021 at 10:23 PM
    patos tacoma
    patos tacoma Well-Known Member
    I’ve seen that logo........what does it mean or represent? Tacoma in Japanese?
  6. Mar 21, 2021 at 10:31 PM
    patos tacoma
    What did you use?
    You had to remove whole light ?
  7. Mar 21, 2021 at 11:04 PM
    Beltfed762
    Beltfed762 Well-Known Member
    Virginia
    2011 DCSB TRD Offroad
    6" lift, 35x12.50R20 Firestone m/t, 20x10 XD Spy wheels, Fox shocks/coilovers, dif breather mod, SAIS delete, Alcan +5 leaf springs, U-bolt flip kit, Superbump bump stops, cab mount chop, poly performance leaf bushings, taco tabs, all-pro cam tab gussets, diy fender trim, fender flare delete, pinch weld smash, cloth seat delete + factory leather swap, seat heaters, remote start, 20% tint, ARE camper shell, ... im sure im forgetting something.
    Got some D-ring shackles and threw on an amber light bar.
    Slashaar, Kuntrykid, digdug1 and 7 others like this.
  8. Mar 22, 2021 at 12:32 AM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
  9. Mar 22, 2021 at 1:41 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Looks like it's a bit busy in there. Would've it helped if you used these two terminals?
    Slashaar likes this.
  10. Mar 22, 2021 at 3:28 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Going to clean it up a bit, definitely. The main goal was to get it in. I wish the main posts were pushed further back and those "auxiliary" terminals were spaced further apart. I have a couple of other things to do on the negative side to clean it up a bit. I had to space the terminals around those auxiliary terminals so nothing was touching potentially causing issues.
    Timing was against me yesterday and a few other things needed tending to.
    Slashaar and Kuntrykid like this.
  11. Mar 22, 2021 at 4:22 AM
    JerzRob
    JerzRob Well-Known Member
    Rob
    South Jersey
    2009 SR5 TRD Sport
  12. Mar 22, 2021 at 4:59 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    just gotta work the occasional removal into the routine. I get at it once a month. I keep a recovery point in the hitch as well. There’s a road by my house I travel a daily and there’s often someone that got a bit too wide and gets sucked in the drainage ditch. Poorly engineered road. I like being able to throw a strap on there and not have worry about getting a shackle and pin out. And I like having something in the hitch.
    good to know about that fix with the pipe, tho.
  13. Mar 22, 2021 at 5:09 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    I get it, I run a beaver tail (https://www.amazon.com/gp/product/B004K23KQ0/) for three reasons - 1) a step into the bed, 2) a lashing point for any recovery straps, 3) a radiator stopper if I get rear-ended.
    I take my hitch lock and over-coat the locking tab and key hole with grease every six months or so. Just recently I noticed the weather cap popped off the key end, so I wrapped it in butyl tape to seal it with the grease inside.
  14. Mar 22, 2021 at 6:27 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Went ahead in threw in a second trans cooler
    POOLGUY, irayfz6, whatstcp and 4 others like this.
  15. Mar 22, 2021 at 7:09 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    I used a 1.25" pipe and snapped that old lock right off. Those things are completely useless if it's that easy to bust 'em. My hitch assembly is getting rusted so I plan to take it off this summer sometime and paint it up.
    irayfz6, Joker56ace and Theeangelow like this.
  16. Mar 22, 2021 at 7:20 AM
    Micatom33
    Micatom33 Under the Truck with Beer!
    Santa Cruz,CA
    2008 BSP DCSB
    not as busy as it could be-just finished my relocate- at least now the weight is off my front fender 31m = 71lbs?
    irayfz6 likes this.
  17. Mar 22, 2021 at 7:26 AM
    kidsmoke
    Flyover Country
    yup. Like bike locks...they protect you from the impulsive/opportunist, not from the pro.
    Thing is even with a good lock, that shackle is simply threaded on there....
    Minny Taco[QUOTED] likes this.
  18. Mar 22, 2021 at 7:33 AM
    Minny Taco
    Minnesota
    Yeah if somebody wants it, they're taking it.
    kidsmoke[QUOTED] likes this.
  19. Mar 22, 2021 at 7:38 AM
    kidsmoke
    Flyover Country
    unfortunately we can say that about a lot of the sh*t we put on our trucks. I was looking at my softtopper last night thinking that any dude with a 9/16" wrench and a corolla could be on their way in about 8 minutes with no damage done to the top....
    :notsure:
  20. Mar 22, 2021 at 7:45 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Nice, I use the same ID crossovers!
    Jimmy92870[QUOTED] likes this.
