  1. Mar 22, 2021 at 7:50 PM
    patos tacoma
    patos tacoma Well-Known Member
    Did you notice a difference?.....in gate or handling
  2. Mar 22, 2021 at 9:26 PM
    Hemibee
    Hemibee Grumpy Old Man W5BSC
    Tony
    Southeast Texas
    2013 Taco & Triumph Tiger 800XC
    ARB, Dobinsons, JBA, Shrockwork.
    I haven't noticed any real change. My sides were still right at factory settings and just installed to keep it that way. The tailgate still opens and closes like it did prior to the install.
    DG92071 likes this.
  3. Mar 22, 2021 at 10:43 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Installed the driver’s side heated mirror harness that goes to the center console along with the trigger and “on” wires plus made up the passenger side harness. That spotter mirror is out of stock till may.
  4. Mar 23, 2021 at 12:02 AM
    tbraumb11
    tbraumb11 Well-Known Member
    nanaimo
    2015 tacoma double cab magnetic grey
    what are those?
    what are the little lights below the headlights on the trim piece?
    2013XSPX[QUOTED] likes this.
  5. Mar 23, 2021 at 12:40 AM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Finally got around to removing (some of the) extraneous audio wiring from the prior owner's stereo setup, and got the mic and steering wheel controls working properly. Still have a few doodads in there that clearly aren't OEM, but, given that everything's working properly now, I'm not going to bother removing them and splicing wires.
  6. Mar 23, 2021 at 1:03 AM
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    @plurpimpin Nice job! I wanted to install a Dometic Hardwiring kit in that location...Where did you source that panel? Was it a blank panel that you drilled holes into? That's what I'm looking for...just the blank panel material...
    Curious how you routed your wiring through that storage area...Any tips on wiring from that storage compartment to the battery would be greatly appreciated! :headbang: (btw, I uploaded the Dometic images as thumbnails...don't know why they posted so large...:confused:_)
    Cross-posted in the Dometic CFX3 Mega thread...:typing:
    https://www.tacomaworld.com/threads/the-dometic-cfx3-mega-thread.647777/page-27#post-25388840
    hwk-dc_9600024894_68018.png dometic-hwk-dc_9600024894_68019.png hwk-dc_9600024894_68020.png dometic-hwk-dc_9600024894_67940.jpg
    Kuntrykid likes this.
  7. Mar 23, 2021 at 1:40 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Brought my fender home after drilling holes for the snorkel.
    NOT EVEN CLOSE! :mad:
    I triple checked the positioning of the template before drilling the holes. I'm not sure how the holes could be this far off.
    The only hole that looks to be correct is the large one for the actual snorkel (not the mounting holes).
    Does anybody have pictures of holes drilled for a Dobonson's snorkel?
  8. Mar 23, 2021 at 2:08 AM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    Let’s see yours first..
  9. Mar 23, 2021 at 2:17 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    These came with the XSPX trim package. They're fun lil lights.
  10. Mar 23, 2021 at 2:33 AM
    m00seNUckLEz
    m00seNUckLEz tAc0 aFiCi0nAd0
    Fresno, CA
    Under Construction
    I removed my factory inner tie rod and aluminum spacer and replaced it with a Camburg Steering Heim Clevis Kit and a solid piece 4130 chromoly tie rod from Kartek.
  11. Mar 23, 2021 at 4:10 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    nice job.
    Cali Raised sells one. Grabs those two 10mm hex heads at the top of the bed sides and provides a mount outside the bed/topper above the taillight housing
    https://www.extremeterrain.com/cali...ByGHhYWRKYUZ-amx8PsaAtSFEALw_wcB&gclsrc=aw.ds
  12. Mar 23, 2021 at 4:32 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    That sucks man. Are the holes all off in one direction or are they all over the place? How far off are they?
    Unfortunately you aren't the first person I've seen post about issues with their templates. I have one in the basement to go on soon. Makes me a little nervous for sure.
  13. Mar 23, 2021 at 5:00 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I was leery when I did because for the same reason, but after marking the holes on the fender with the template I then put the template on the actual snorkel body to make sure the holes aligned properly with the holes on the snorkel and it was fine.
    fasteddieyj[QUOTED] likes this.
  14. Mar 23, 2021 at 5:23 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Just ordered the Dauntless tailgate assist kit (just got put on Amazon at the end of February) -- it looks pretty solid compared to the other tailgate assists I've seen, and now that I am running both a kb voodoo cap and a mobtown plate, I figured it's time to keep me from accidentally dropping it too quick.
    https://www.amazon.com/gp/product/B08XNPTBBR/
    Also have a rivnut setter on the way today for two reasons, one, the tailgate, two, my CB mount. I tried to set some M6 rivnuts in the tailgate yesterday and found that I didn't have any M6 nuts of a good enough hardened steel, so heck with it, time to get the rivnut tool. My CB mount I put in last year was just with self-tapping screws, and they've already backed out on me enough to make it wobbly, so it's time.
    For reference, this is where my mount is, right behind the cab.
    irayfz6 likes this.
  15. Mar 23, 2021 at 6:29 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    I don't have any pics of the hole themselves, but I do know that the template was off when I installed a couple of them on other people's vehicles. I ended up making a template from another piece of sheet paper and matched it up directly to the snorkel itself. Before I installed it, I matched up the original template to the snorkel and saw huge differences. Here is a link to one of the installs I did.
    https://www.tacomaworld.com/threads...150-build-and-bs.655049/page-20#post-23850937
  16. Mar 23, 2021 at 6:43 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    So an update on this and for those out there running the Spyder/Tcmabeast lights that utilize a H1 bulb. In doing some searching on powerbulbs website I have found that Osram makes a H1 version of their Super Bright that is recommended in the ultimate headlight thread. These are rated at a whooping 100W @ 12V while the standard H1 is only rated for 55W at the same voltage. My plan is to combine these with the Headlight Services harness and to see what kind of performance can be squeezed out of these (I've yet to have leaks/condensation issues). If all else fails I'll revert back to factory housings and the true Ultimate headlight upgrade.
    fasteddieyj likes this.
  17. Mar 23, 2021 at 7:06 AM
    fasteddieyj
    Ed
    Hanover, PA
    Those are the bulbs I am currently using with the Headlight Services harness, although with the stock headlight housings. I will however say that they were a huge improvement over the stock bulbs and wiring.
    Rezkid[QUOTED] likes this.
  18. Mar 23, 2021 at 7:31 AM
    YourActualName
    YourActualName Well-Known Member
    NH
    2015 Black Tacoma Limited DCLB
    Magnuson SC, +
    6 Year update.
    zippo88, Kuntrykid, GARSHA91 and 20 others like this.
  19. Mar 23, 2021 at 7:41 AM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
  20. Mar 23, 2021 at 7:50 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    OB? PB?
