  1. Mar 23, 2021 at 7:19 PM
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    Just reviewed...got it. Thanks for the clarification. :thumbsup:
    Just out of curiosity...did you rivet the pocket to the bed because you took it out to drill a hole for the wires and it wouldn't snap back in? Or for some other reason?
    I'm going to try to avoid riveting the pocket to the bed if I can and looking for breadcrumbs as to why that was necessary.
    I get the rivet nut thing now...wasn't aware of that product before...looks like I'm gonna need another tool. :cool: Unless I can find a neighbor who has rivet nut tool. I've got one for rivets, but not sure if that will work...haven't used it in a long time.
    @plurpimpin do you find it fairly easy to access that cubby location to see the voltmeter reading, flip switches, etc.? That's my main concern with the location...
  2. Mar 23, 2021 at 7:24 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Last service before 100k ticks over. Also had the aftermarket alarm ripped out, fuckwads installed it with a 10A fuse taped into the harness 6” from the effing fuse panel. Found it because the module and bundle completely blocked access to the driver’s side door grommet. 8-10 t-taps left behind w/out the male spade connectors.
  3. Mar 23, 2021 at 7:31 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Look up diy rivnut install. All you need is a grade 8 bolt the same thread as the rivnut and maybe 1/2” longer, some washers to let the bolt spin and a star washer to inhibit the rivnut from spinning, a cordless impact driver, and about .8 seconds. That’s for aluminum rivnuts, for steel you probably need the most expensive tool available. For 1/4x 20 I used a 2” bolt.
    Geronimo1111[QUOTED] likes this.
  4. Mar 23, 2021 at 7:42 PM
    PyritePirateBill
    PyritePirateBill Well-Known Member
    Bill
    North Myrtle Beach, SC
    2014 pyrite mica TRD Sport 4x4 AC
    OME 886 Nitrocharger lift, Dakar HD leaf pack, u-bolt flip kit, Bilstein b110 rear shocks, Wheeler's super bumps,18x9 Worx Havoc, 35/12.50/18 Nitto Ridge Grapplers, ENVE Grille with LED lightbar & raptor leds, ditch lights, 6k hid, tinted tails, AtTheHelm bed stiffeners, SOS Concepts rear bumper, Demello baja front bumper, Smittybuilt 9.5k winch, Mobtown weld-on sliders, AllPro IFS & transm. skid, Mobtown transfer case skid, led fogs, led lights in rear bumper, 54" Bulldog hi-lift jack, Razorback shovel & axe on Quickfist mounts, Cobra CB w/Firestik antenna, Yellow wire mod for 4Lo, URD y-pipe, 2.5" custom exhaust w/ Borla muffler, Viair portable air compressor, Kryptek Typhon seat covers, AJT dash knobs
    I remember when doing mine that I had to enlarge the holes a little more than what the instructions suggested to get it to fit perfectly. Then used larger stainless steel washers on the backside.
    Damn! I almost posted to warn you of this before you had the fender painted after drilling, but I figured you'd pre-fit it first
  5. Mar 23, 2021 at 8:00 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    That don’t look that bad. Think you need to put it on the truck to see where you at.
    crashngiggles likes this.
  6. Mar 23, 2021 at 8:08 PM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    Went off roading for a couple hours today for science!! (Or to test the flex of my new rear shock relocate). And see how she rides empty with the heavy duty Deaver u402 stage 3 leaf springs
    She’s a little bouncy without all the weight... but...
    That bitch flexy!
    Turns out when she’s flexed this much⬇️... the frame is so twisted it’s actually hard to open and close the door, gets hung up on the access cab door.
    Plus got her ass in the air a little bit.
    And scuffed up the drive shaft a smidge.
    Then managed to break off a valve stem, and had to do a trail tire swap. Good times!
  7. Mar 23, 2021 at 8:19 PM
    HalcyonDaze
    HalcyonDaze Member
    Darren
    DFW
    2015 Taco AC SR5 V6 4WD
    2.25" level kit, Pro Comp Series 01 17x8, Toyo Open Country III 265/70
    That is super nice. Last thanksgiving I grabbed my 2015 SR5 V6 4x4 Access cab. Same color even. 47k on it, I paid similarly to you, $24k and some change. Clear title and all that. Came with a bull bar, weathertech inside and out. No camper shell tho, that's nice.
    Like you, I was looking around for months. Was open to getting an access cab if I could find one. But mostly looking at 3rd gens. Decided to expand my search to 2nd gens, and low and behold it was sitting at a dealership 5 minutes away the whole time. Super happy with it.
  8. Mar 23, 2021 at 8:41 PM
    Gilmore6080
    Gilmore6080 Gilmore6080
    Tim
    Nor Bay
    06 Prerunner TRD Sprt V6 A750E SR5 Street Pkg Dbl CB LNG BD W/Tow Pkg
    Snug Top Omni Runningboards Hood bug detector
    I recommend the Hankook Dynapro AT2 RF11 !
    grlnbear04 and kidsmoke like this.
  9. Mar 23, 2021 at 9:16 PM
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Step 1 of my retrofit is complete...more to follow. I think I'll make a post after with some pictures and tips so others can do their own instead of paying someone else a small fortune.
  10. Mar 23, 2021 at 9:32 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I riveted the pocket in because the clips couldn’t hold it with all the added weight of the outlets and wires.
    Then I tried double stick tape when that didn’t work. Then I tried to do rivet nuts in the bed so the bolts would hold the panel and pocket on but the cutout in the bed is so large in relation to the pocket that there wasn’t enough bed material for the rivet nuts to grip but there was just enough for 1/8” rivets so that’s why it’s riveted in and then the rivet nuts are installed around the flange on the pocket.
    you’re installing fewer outlets so extra weight might not be as much of a problem. Midaswell try the clips first
    as for outlet location I have a wedge camper and mostly installed the outlets to use when camping so no problem accessing them. Plus my side panels open so I can just reach the panel through there from the outside.
  11. Mar 23, 2021 at 9:38 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Makes me want to do another build with the d2s 5.0s. I actually had quite a bit of fun making my first set.
  12. Mar 23, 2021 at 9:40 PM
    Audi403
    Those are the projectors I ordered! With Panamera shrouds. They arrive later this week
  13. Mar 23, 2021 at 10:17 PM
    dustinJ
    dustinJ Taco abuser
    Dustin
    Amarillo tx
    09 dcsb Super white 4x4 sr5.
    Bilstein 5100 at 2.5 inch OME dakars with the big overload removed 265/75/16 on stock wheels 290,000 miles and counting
    Please do a thread. I'm really wanting to build my own and would like a definite parts list of what all to get.
  14. Mar 23, 2021 at 10:39 PM
    20somethingwidataco
    Will
    Washington State
    Get some good Phillips bulbs and you won't be disappointed! I went Extra fancy and paint matched the shroud my body color. Pretty cool against the black housing imo
  15. Mar 23, 2021 at 10:40 PM
    20somethingwidataco
    Will
    Washington State
    The retrofit source is pretty helpful for all of that.
    dustinJ[QUOTED] likes this.
  16. Mar 24, 2021 at 1:38 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    If you look at it from the other side, it's tilted backwards, so much so that it will hit the a-pillar.
  17. Mar 24, 2021 at 1:39 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I didn't have the fender painted.
  18. Mar 24, 2021 at 1:46 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Thanks, this mod will be on hold as I do other things.
    I'm having Dobinsons send me a new template. I already know it will be wrong but I'll use it as a starting point. I'm also getting a new fender.
  19. Mar 24, 2021 at 7:32 AM
    tortoise_taco
    tortoise_taco Well-Known Member
    battle born
    2013 SR5 V6 4x4
    The second gen is a good balance between the simplicity that I like from my old one but also having a modern vehicle. I definitely feel great about it, I'm just sentimental
  20. Mar 24, 2021 at 9:54 AM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i bought new Denso Spark Plugs #K20HR-U11. i'm at 45k - i bought it at 39k but i don't think they were changed yet. we'll see when i pull the plugs out.
