  1. Mar 24, 2021 at 10:37 AM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    i was gapping the new plugs during my remote staff meeting and thought i was on mute. Tap Tap Tap Tap !!! OOOPPPPPSSS!
    Philrab and dustinJ like this.
  2. Mar 24, 2021 at 12:10 PM
    Islandtaco671
    Islandtaco671 Well-Known Member
    Daniel
    San Diego
    2006 Double cab Tacoma TRD O/R
    Made a tray/shelf for my stuff with some wood I had laying around. I don’t think it came out too bad!
  3. Mar 24, 2021 at 12:26 PM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    I had a stowaway...
  4. Mar 24, 2021 at 12:36 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    dusted off the soft top for some long distance furniture hauling next month. Nice sunny day makes it easier to get everything to stretch out.
    Also threw some new LED's in the reverse sockets. Someone here had recommended them a while back. Major Improvement. $13.00 Callin' it a win. :thumbsup:
    https://www.amazon.com/gp/product/B07D9DFWGM/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8
  5. Mar 24, 2021 at 1:04 PM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    Dang! What the hell did he jump from to get in there?
    Choco_Taco[QUOTED] likes this.
  6. Mar 24, 2021 at 1:05 PM
    jon_elc
    NorCal
    i pulled one out of the right side - looks pretty decent
    then again, these are what i pulled out of the bimmer
    DG92071 and irayfz6 like this.
  7. Mar 24, 2021 at 1:14 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Cleaned my MAF sensor and throttle body today. This is the first I've done this to this truck, and I don't know if it's been done before by the previous owner, but the MAF was visibly dirty. After cleaning everything up good, the truck idles and runs much smoother now. :thumbsup:
  8. Mar 24, 2021 at 2:37 PM
    Geronimo1111
    Geronimo1111 Well-Known Member
    Ventura, Flagstaff & Phoenix
    '07 Silver Streak Mica 2.7L AC
    Ride-Rites LEER 100 XQ Cap Homemade Bedslider Bilsteins
    Thanks, @bagleboy :thumbsup: Screenshot for future reference...drill 1/4" hole, put ABS panel on, star washer, rivnut, washer, 2" grade 8 bolt (same thread), drive w/ impact driver...sounds doable! Appreciate the instructions! :proposetoast:
  9. Mar 24, 2021 at 2:46 PM
    Geronimo1111
    @plurpimpin Understood. Thanks for walking me through the logic. ABS piece just showed up today...It's been about 30 degrees and snowing, so I've been avoiding going outside...that's why I've been trying to get as much info as possible via this forum...So, when I do get out there, I've got an idea of what I'm doing.
    As far as wiring, how did you go about that?
    Did you drill a hole into the pocket from the outside or from the inside?
    Any tips on running the wires to the battery?
    Also, wondering if we can take this over to a dedicated thread so the info doesn't get lost for future installers....
    Here is a link to that thread:
    https://www.tacomaworld.com/threads...e-wheel-well-2nd-gen-ac.713751/#post-25396822
  10. Mar 24, 2021 at 3:06 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    A little teaser of what I have planned for the next couple days/week (if the weather cooperates).
    Slashaar, Key-Rei, GRNT4R and 9 others like this.
  11. Mar 24, 2021 at 3:17 PM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    Just an FYI, you need a minimum of 50 posts to sell anything on TW. Since you are 6 posts away it won't take long but the other rules are that the part has to be removed from the vehicle and you must post pictures and a price. Best of luck!
  12. Mar 24, 2021 at 3:25 PM
    JTB Tacoma
    JTB Tacoma Well-Known Member
    Central NJ
    2015 Tacoma TRD, Super White
    I picked it up from having the CRC treatment applied to the frame. Since they had the truck already, I also had them do the front and rear diff service and trans fluid.
  13. Mar 24, 2021 at 3:48 PM
    DG92071
    DG92071 Well-Known Member
    Depending on your perspective I either helped a fellow TW member out or I hacked up a fellow TW members truck. A version of the CMC that I wondered why no one else had done (that I've seen, I'm sure someone out there has done it before).
    So this is after the cuts.
    This picture shows clamps on it after I re-formed the steel a little bit however I did end up re-forming the steel and re-clamping it down however I forgot to take a picture of that new position.
    All welded up. So I use a Hobart that's a 110v machibe and in my experience 110v machines require a different technique than a 220v machine so you'll notice some areas were ground smooth and others left alone, the areas that are ground down had a ton of wire shoved into a big puddle to get more penetration out of the 110v machine. That process can make incredibly large bougers lol, so those get ground off, but it's strong AF. Other areas got plenty of penetration and were welded about 3/8" at a time and allowing it to cool for a few seconds so holes weren't blown into it. All welds were done with my machine on its max amp output because I personally care only about penetration versus appearance. I've been using 110v machines for decades.
    Passenger side.
  14. Mar 24, 2021 at 3:51 PM
    Evergreen_Offroad
    Evergreen_Offroad Well-Known Member
    Andrew
    2009 Tacoma TRD Offroad Access Cab
    35s, armor, mid travel etc.
    Finally did the front end facelift, just waiting on some trim for under the headlights.
  15. Mar 24, 2021 at 3:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I removed the TOYOTA decal from the tailgate. It felt a little busy back there with the tepui emblem and cova overland stickers now. I also swapped out my mismatched cam straps for some over priced Dometic ones so they all match now.
    8B0BBF2E-131F-4241-B086-CB40C9C3EC2F.jpg FFCA20B0-A89F-48BE-9D9A-219A341C6252.jpg
    Slashaar, grrck, G.Lloyd.624 and 15 others like this.
  16. Mar 24, 2021 at 4:02 PM
    Fosterlr
    Fosterlr Well-Known Member
    Mancos, CO
    2013 TRD Off-Road
    On my list to do as well after upgrading to TRD Pro Headlights
    Minny Taco[QUOTED] likes this.
  17. Mar 24, 2021 at 4:35 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Nice. I like the more angular look of the 2.5 gen, that's why I bought a 2012.
    What headlights are those?
  18. Mar 24, 2021 at 5:11 PM
    ken01976
    ken01976 Well-Known Member
    St Louis MO
    2014 Tacoma TRD Sport 4x4
    Installed trd pro skid. Finished ditch lights.
  19. Mar 24, 2021 at 5:27 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Huh, that's kind of a cool paint scheme. Very original.
  20. Mar 24, 2021 at 5:45 PM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    Got the rivnuts in today.
    Kuntrykid, irayfz6 and loyaltothetaco like this.
