  1. Mar 25, 2021 at 3:31 PM
    Andocalrisian
    Andocalrisian Well-Known Member
    North Vancouver BC
    2015 Tacoma SR5 Access
    I've got a canopy with a camper in the back, I'm guessing this would just stink up the back with horrible differential stank? You think it would cause issues if I just extended it up a bit but not into the storage spot?
  2. Mar 25, 2021 at 3:39 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Got the CVT hybrid. Man this thing is NICE and THICK fabric. Nicest RTT I’ve ever seen. Well worth the $$$ can’t wait to take it out!
  3. Mar 25, 2021 at 3:40 PM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
  4. Mar 25, 2021 at 4:14 PM
    trdmtb
    trdmtb Well-Known Member
    Michigan
    RIP: 07 DCSB TRD OR current: 19 Ram
    lol I didn’t even think about that...I don’t think you’ll really be able to smell it, and I guess it’ll work as a sign on when to change your fluid too ha
    I hope not anyways, I have a bed rack and am buying a tent soon
    Andocalrisian[QUOTED] likes this.
  5. Mar 25, 2021 at 4:40 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    Icon 3 leaf Add A Leaf installed with my existing 1" block gave me the perfect stance, and made such a huge difference in ride quality. No more bro lean but now I feel like I need to address the brake hoses. They're feeling you short for any flex.
    Andocalrisian likes this.
  6. Mar 25, 2021 at 5:25 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    its for air to escape. It shouldnt stink
  7. Mar 25, 2021 at 7:22 PM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Never ever heard or thought of that concern. @elricfate has your solution. That’s where I ran mine was into the taillight cavity. Ends up being about 10” higher anyway.
  8. Mar 25, 2021 at 8:26 PM
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Run it inside the fuel filler cavity.
  9. Mar 25, 2021 at 8:29 PM
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Finished stripping the chrome off all the parts that are going to be painted for my retrofit. Sourced a professional autobody shop whose going to spray them for me. They will spray an adhesion promoter before painting. When I did the BHLM I sprayed them myself with Krylon Fusion. It turned out pretty good but it doesn't compare to a professional finish.
    Next step is to scuff everything to prepare for paint. I learned my lesson doing the BHLM last year, 400 grit sandpaper is way too rough. I picked up some grey scuff pads (~800 grit) and going to try and find some sanding paste to use with it. From what I've read these pads + paste is a much better solution than sandpaper when scuffing plastic for paint. Going to post a brief DIY thread when I'm done with all the tips I've picked up.
    Slashaar, zippo88, dpele and 4 others like this.
  10. Mar 25, 2021 at 8:34 PM
    Travlr
    Middle'a Utah
    How do you strip chrome off plastic?
    Slashaar likes this.
  11. Mar 25, 2021 at 8:37 PM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Today I spent a long time at the car wash. 9DB77362-FF35-43C7-BE20-23FA63B60708.jpg
  12. Mar 25, 2021 at 8:38 PM
    Audi403
    This stuff is fantastic. It's very harsh though so make sure to wear nitrile gloves. If it gets on your skin you will know right away, it burns lol. Also good to have some sort of ventilation. It's snowing here so I did it in my garage tonight instead of outside but I wore a respirator. It makes you feel sick if you breathe the fumes in, trust me lol. The directions on the bottle say it works better if you preheat your oven to 200 degrees before using it. This makes me think it would work even better if you preheat the plastic pieces before using it. It's -4 degrees here right now, I didn't want to shock the plastic going from hot to cold so I didn't test my theory.
    Slashaar and dpele like this.
  13. Mar 26, 2021 at 2:41 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    How exactly did you go about doing this? I've tried the Easy off 2 or 3 times for chrome removal without any luck.
  14. Mar 26, 2021 at 6:07 AM
    etx
    etx Active Member
    Smithwick
    07 4x4 DCLB
    Revtek garbage spacer
    At the alignment shop now pretty stoked
  15. Mar 26, 2021 at 6:52 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
  16. Mar 26, 2021 at 6:59 AM
    deekyn
    deekyn Well-Known Member
    Dustin
    Yellowstone
    2015 Black Tacoma TRD Off Road
    just extend it into the tail light housing hole. Like I did
    Or next to the gas cap.
  17. Mar 26, 2021 at 7:04 AM
    DG92071
    DG92071 Well-Known Member
    The nuts for the front struts on mine are the same way. The only way the strut could fall out is if the nuts backed out by themselves and the front wheels would have to leave the ground. I still used blue loctite on the driver's side front strut retaining nuts just because there's so few threads left. No problems on mine yet, it's been a couple months now.
  18. Mar 26, 2021 at 7:09 AM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Cool paint scheme. Did you paint your scoop insert? I replaced by hood last year and the unpainted plastic insert has started to fade to grey. But - I may paint it grey to highlight the grey on my Off Road's bed decals.
  19. Mar 26, 2021 at 7:14 AM
    guyfromky
    guyfromky Well-Known Member
    Finally got around to ordering my AJT climate knobs and put them on yesterday. Absolutely love them!
    grrck, dpele, Nickkos taco and 10 others like this.
  20. Mar 26, 2021 at 7:17 AM
    JimIowa
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    man. That sucks. Sorry that this happened.
