  1. Mar 26, 2021 at 8:19 AM
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Shake the bottle, set the parts on cardboard or something to protect the floor, spray the shit out of them, wait about 15 minutes, scrub with a rag. 90% of the chrome came off without scrubbing on most of the parts. The Morimoto shrouds must have had a thicker layer of chrome, they required more time and a little more scrubbing.
    fasteddieyj[QUOTED] likes this.
  2. Mar 26, 2021 at 9:16 AM
    Andocalrisian
    Andocalrisian Well-Known Member
    North Vancouver BC
    2015 Tacoma SR5 Access
    The old sniff test. I just changed my rear diff fluid and definitely did not pass the test.
    trdmtb[QUOTED] likes this.
  3. Mar 26, 2021 at 10:31 AM
    Audi403
    Retrofit shit
  4. Mar 26, 2021 at 11:42 AM
    fasteddieyj
    fasteddieyj Well-Known Member
    Ed
    Hanover, PA
    2015 camping/mild wheeling rig. 2014 DD
    I was trying to remove the chrome from my grill emblem. Maybe I just need to let it sit longer. Thanks.
  5. Mar 26, 2021 at 11:59 AM
    fasteddieyj
    Ed
    Hanover, PA
    Made a small platform for the rear drivers side. Would have liked to do the whole back seat but I have an 11 year old niece that would be mad if she couldn't ride in Uncle Ed's truck. Used a piece of 3/4" mdf that I had laying around, plus I already had the d-rings and the short piece of 1 1/2" steel that I used. Attached it using the factory hinges so it still tilts forward and I can access the factory storage area if needed. After taking these photos I ran the router around it real quick to ease the edges. Going to probably just paint it tomorrow.
  6. Mar 26, 2021 at 12:13 PM
    etx
    etx Active Member
    Smithwick
    07 4x4 DCLB
    Revtek garbage spacer
    Got aligned this morning. Driving good! Changed front wheel bearing/hubs from 05Taco4x4's press service. Got lawn and garden on my parking brake line that was rubbing my icon rxt hardware.
    Slashaar, irayfz6 and Island Cruiser like this.
  7. Mar 26, 2021 at 12:15 PM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Did you not drill out the bolt hole on the OE bracket that holds the brake line? I took a slightly larger drill bit to the hole and it worked just fine.
    outxider likes this.
  8. Mar 26, 2021 at 12:19 PM
    Audi403
    Yeah maybe try and let it soak for half hour or so. It doesn't seem to damage the plastic at all, give it a little more time to work. I'd try heating the emblem in the oven next time. The bottle says it cleans ovens best if you preheat to 200 degrees. I'm assuming this logic will apply to stripping chrome as well.
  9. Mar 26, 2021 at 12:30 PM
    etx
    etx Active Member
    Smithwick
    07 4x4 DCLB
    I thought about it but I'm just gonna cut those brackets off with a grinder. I think..
    EatSleepTacos and whatstcp like this.
  10. Mar 26, 2021 at 12:36 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Kicked off "Spring Cleaning" with my Bestop Supertop.
    Slashaar, FreshPots, srspicer and 5 others like this.
  11. Mar 26, 2021 at 1:11 PM
    Goosie0080
    Goosie0080 Well-Known Member
    North East
    07 Tacoma Access Cab 4x4 base
    Finally finished the radio and blackout on the dash
    Mr Yoda, Slashaar, zippo88 and 13 others like this.
  12. Mar 26, 2021 at 1:13 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Interesting approach. I used wire loom but that looks cooler lol. I believe that bolt should be the other way so that the bolt itself is less susceptible to puncture into the gas tank.
    Edit: Then again, should something catch on fire, you’re partially ready with your water hose lol! Sorry sorry
  13. Mar 26, 2021 at 1:24 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    2007 Tacoma TRD Prerunner Sport 4x4
    a lotta money spent, lotta scars made
    I
    couldn’t get mine to lay flush...I have a few thread showing, should I keep cranking on it?
  14. Mar 26, 2021 at 1:25 PM
    huyner
    huyner CoCKaSiAn
    Huy
    Orlando
    How you get the black hazard and did you rewire the ac controls from a newer gen? Thanks
  15. Mar 26, 2021 at 1:29 PM
    Goosie0080
    North East
    i found the black hazard switch at a junk yard. got it shipped. $60... and Yes i did rewire and move the pins for the AC controls which i also sourced from the junk yard.
    Eaux8Taceaux and theolee like this.
  16. Mar 26, 2021 at 1:32 PM
    HasbroGamer
    HasbroGamer Well-Known Member
    Nicola
    Washington State or Arizona
    2007 V6 Tacoma TRD Sport Double Cab
    Bed Stiffeners, Martin roof rack, 2 inch Dobinsons lift, black seat covers, taco garage tech deck and ram mounts, amazon backup camera, custom 2.5 gen facelift, Stingray front bumper, Diode dynamic foglights, wheels & tires, OME leafs.
    what kit is that
  17. Mar 26, 2021 at 1:34 PM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    March Maintenance Madness continues. Flushed radiator and refilled with the pink stuff. Also drain and fill my AT. Had both done at my local dealer cause I'm old and have a sketchy back. Next up is a brake job, probably in June or July.20210326_134925.jpg
    irayfz6 likes this.
  18. Mar 26, 2021 at 1:38 PM
    ninja89
    ninja89 HUH?
    OOOO AWESOME IDEA! Thanks for the sharing brother
  19. Mar 26, 2021 at 1:42 PM
    Goosie0080
    North East
    American international TOYK973
  20. Mar 26, 2021 at 1:43 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    0326211548_HDR~2.jpg I actually like the kc covers more than I thought I would
    trdmtb, lynyrd3, El_Capitan3 and 20 others like this.
