  1. May 6, 2021 at 3:23 PM
    Sasquatchtaco
    Sasquatchtaco Sasquatch Taco
    Catskills NYS
    09 MGM DCSB 4X4 TRD
    Too many to list.
    holy crap.. I did the same with a bachelor's party back in 2002 or something like that.. my wife won't let me forget.
    Edit: Are you ok? :rofl:
    super_white[QUOTED] likes this.
  2. May 6, 2021 at 5:05 PM
    Picantesauce
    Picantesauce Member
    Vancouver
    2015 Tacoma AC 2.7L 4x4
    Got the 3rd gen rims on my 2nd gen
  3. May 6, 2021 at 5:56 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Unbent my new rci skids.:D This along with some interesting setups on the knee mill got them straight...ish.
    4x4cajun, uncleART and irayfz6 like this.
  4. May 6, 2021 at 6:30 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Gave it a little long... long overdue attention.
    Pressure washed the most recent adventure off the top engine and the undersides.
    Then gave it a proper two bucket wash, clay mitt, and a good waxing, no correction this time though it could definitely use one.
    Changed out the charcoal canister to hopefully permanently solve my emissions CEL that comes and goes. Wasn't as expensive as K was afraid it would be. Also pretty sure it would not have been possible to change without removing the bed bolts if it wasn't for my 1/2 bed lift.
    Lastly did my outer tie rod ends, they really weren't too bad but now everything in the front end should be peachy.
    They were really the last pieces.
  5. May 6, 2021 at 6:34 PM
    point45
    SoCal, OC
    05 DCSB TRD offroad
    I need to replace the bushings on my steering rack and tie rods. Not looking forward to it.
    Personally if you don't have a state inspection I would remove the charcoal canister as it will just plug up again.
    BustinJass17 likes this.
  6. May 6, 2021 at 7:18 PM
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    Look, Twins!!
    FF7D968D-6885-439C-94D7-92875687B90D.jpg FB13EC69-6ACF-46E3-854E-4D3AE8EC86F4.jpg
  7. May 6, 2021 at 7:20 PM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Interesting air box, is it off of a 5th gen 4R?
    Key-Rei[QUOTED] likes this.
  8. May 6, 2021 at 7:26 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Chopped off the exhaust. I also fixed my rattling exhaust issue with some spacersC73AD481-7C83-46C0-AAE8-CC29FC9B8D92.jpgEB3610E3-0CEF-44E6-95FB-269A2B4DA6C6.jpg91015392-D59A-4103-85BE-8BB7C0FEA424.jpg
    T.Barn, Tacoma13_NC, uncleART and 6 others like this.
  9. May 6, 2021 at 9:09 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Nice. Always liked those tail lights. Might be next on the list.
    theolee[QUOTED] likes this.
  10. May 6, 2021 at 9:22 PM
    Rezkid
    TJ
    WTX
    '08 DCSB TRD RT
    Nice! What color/brand did you use? The color match is pretty dead on.
  11. May 6, 2021 at 9:29 PM
    Key-Rei
    Key
    Florida
    2013 FJ cruiser box with Tredstone MAF tube, airflow straightener, couplers, vibrant T clamps, fuel pressure regulator has some reducer nipples and is screwed into the FJ's MAF hole. The FJ box has the centrifugal water separator and flapper valve in it and fits a large standard readily available filter, plus the FJ filters come with a water repellant "wool" glued to them.
    Kolter45 and Rezkid[QUOTED] like this.
  12. May 6, 2021 at 9:32 PM
    Key-Rei
    Key
    Florida
    Replacing the rack bushings is a pain in the arse job, supposedly you can replace them in the truck but don't bother fighting it, just take the rack out, do your inner tie rods and boots while you're at it like I did.
    I considered it but I'd still get a CEL due to the ECU being unable to complete the test and CEL's drive me insane.
  13. May 6, 2021 at 10:16 PM
    theolee
    theolee www.nickleecreations.com / IG @nickleecreates
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Thanks, great TLs. Still looking and working like new after two years :)
  14. May 6, 2021 at 10:23 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    Hah, nice! :D
    I like the spacer you have on the rear bracket too! :thumbsup:
  15. May 6, 2021 at 10:25 PM
    theolee
    Theo
    SAN DIEGO
    Original Dip (black) and a few coats of Dip clear coat. It may look that way from afar but not up close lol. It's close enough though :D
  16. May 7, 2021 at 2:21 AM
    theolee
    Theo
    SAN DIEGO
    While doing a little rewiring I've been unintentionally scratching the hell out of my recently painted radio panels. I'm over it. I ordered a all black 2.5 one.
    I've always felt the 2.5 gen radio panel bezel looked alot cleaner than the 2.0s anyway :D
    On another note, anyone know the part number for non clock hazard switch panel?
  17. May 7, 2021 at 3:39 AM
    TRDProBuddy
    MD (Kent Island)
    I believe that spacer comes on the TRD Pro Trucks
  18. May 7, 2021 at 5:45 AM
    SliMbo4.0
    SliMbo4.0 Well-Known Member
    Rick
    Colorado Front Range
    07 Tacoma DCSB TRD offroad
    BP51, BAMF hangers, BruteForce HC, SCS, Vagabond Drifter
    I still need to do the rears on mine. Should do it when I get the new leaf pack in.
    hoffengineering likes this.
  19. May 7, 2021 at 5:57 AM
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2024 Blue Crush TRDOR 4x4
    Bought this today at O’Really... of course, I only need probably 8-12 ounces to take above the “Low” line in the reservoir when it’s cold. When it warms up it comes up maybe a quarter more towards the “full” line.
  20. May 7, 2021 at 6:36 AM
    JRYTacoma
    JRYTacoma Well-Known Member
    British Columbia
    2012 Tacoma Sr5 Spruce Mica
    Today I took the gas out of my completely full washer fluid tank...
    Never trust the gallon jugs of any kind of fluid that your family leaves around...and always smell / look inside before you pour it anywhere into your truck then drive it for 3 days wondering why it smells like gas fumes up front. Enough time to warp the tank and pop the lid open, I heard gas splashing around the engine bay while driving is optimal...
    I really can't believe I didn't notice when pouring it. But for some stupid reason someone decided to fill a nearly new Rain-X summer washer fluid jug with gas - and then put it back by all the other washer fluid jugs.
    gkomo, 4x4cajun, fasteddieyj and 4 others like this.
