  1. May 10, 2021 at 6:56 PM
    619_TaCo
    619_TaCo Well-Known Member
    Luis
    San Diego, CA
    ‘08 Tacoma AC PreRunner V6
    -Duratrek Side Step Bars -Flowmaster FlowFX Cat-back Exhaust -‘Master Tailgaters’ Tailgate Backup Reverse Handle with Camera -‘StyleLine’ Smoke Tail Lights -Cooper Discoverer STT PRO 315/75/R16 -SCS F5 16X8 3.50” -25mm
    Custom made by @HomerTaco :D
    theolee likes this.
  2. May 10, 2021 at 7:01 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Goosie0080 and loyaltothetaco like this.
  3. May 10, 2021 at 7:03 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Looks good, first time I've seen someone do tabs like that, what's the reasoning?
    uncleART[QUOTED] likes this.
  4. May 10, 2021 at 7:05 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Nah... I only have, and used, the aluminum (silver) Anti-seize.
  5. May 10, 2021 at 7:09 PM
    Key-Rei
    Key
    Florida
    You can always replace with 1/2" stainless bolts.
    Chris(NJ)[QUOTED] likes this.
  6. May 10, 2021 at 7:11 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    If I can't keep these from corroding beyond repair again I think I might go that route!
    Key-Rei[QUOTED] likes this.
  7. May 10, 2021 at 7:14 PM
    uncleART
    uncleART Well-Known Member
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    3" Toytec ULK 285/75-16 BFG KO2 Verge FN Wheels DeBadged, Toyota Bedmat, Window tint 30%, DeFlapped the front, Bilstein 5100s, Toytec coil overs, Dakar leafs, LR UCAs, SwayBar relocate, TRD Offroad tow hook, RotoPax, DeFlapped the rear, Tailgate mod, CBI receiver shackle w/ Bolt Hitch Pin, BFG KO2 285/75-16, FNWheels Verge, Weathertech Floor Liners, Spare tire mod, UWS toolbox with Bolt Latch Retrofit, Rear Diff vent relocated, Blacked-out grill emblem, Toolbox Bedrail mod, Trailer Plug relocated, ECGS bushing, Redline Hood Struts, Leer 100XR, C4 Fabrication Lo-Pro Bumper, Relentless Fab Frame Reinforcements, Warn 9.5XP-S Winch, Baja Designs S8 20" Lighbar, Off-Grid Engineering Dual Battery Tray, Odessey 35-PC1400 Batteries, BlueSea ML-ACR
    I’m going to do custom liners and will support them with the tabs.
  8. May 10, 2021 at 7:21 PM
    Key-Rei
    Key
    Florida
    Don't forget to get longer bumpstops and/or extended them down, with 34's and Fox DSC's, 14" 700# King coils and DuroBumps my tires still touch the top pan of the inner metal fender under full compression. Meaning your 315's will do you the favor of removing that hard work for you if you compress them too far and have no effective up travel limiter.
    I decided that since the factory splash guards didn't seem to do much more than give mud and sand a nice place to hide and a way to hold it in as well as wanting to have as much up travel as possible I decided to forgo splash guards.
    Dye22 and uncleART[QUOTED] like this.
  9. May 10, 2021 at 7:40 PM
    Quakes15
    Quakes15 Well-Known Member
    Peninsula (BAY AREA)
    TRD Sport Toyota Tacoma X DCSB 4WD
    ICON Stage 3/ Stealth 6's/ Nitto Trail Grapplers
    Finished up some projects the past week. Finally added my rci bed rack with all the gear and the waterport.
  10. May 10, 2021 at 7:59 PM
    Ryan2103a
    Ryan2103a Well-Known Member
    SoCal
    2011 Sequoia 4x4 2022 SR 4x4
    Looks clean and +1 on the roof basket. Rarely do I see another taco rocking a bajarack roof basket :thumbsup:
    Quakes15[QUOTED] likes this.
  11. May 10, 2021 at 7:59 PM
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    the new shock had a slightly different bolt at the banjo fitting for the hose to the reservoir…
    my guess is they have identified a problem and fixed it.
    no complaints here.
  12. May 10, 2021 at 8:02 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Good advice. I’ll have to see if my wheelers bumps will work as they are. If not, I might put spacers on them.
  13. May 10, 2021 at 8:08 PM
    Key-Rei
    Key
    Florida
    Super bumps are pretty soft, and your 35s (or 315) are going to be a bit taller obviously than my 34's, plus the loss of top out from the splash guard though not much even with a quarter inch of space on my stock bumps I was still touching under compression and the stock bumps don't squish at all really. I'd probably get 3/8 spacer, you can run down to your local hardware store and get some 1/8" thick stainless washers with a 3/8" hole that will work perfectly.
    I had a quarter inch of spacer on my stock ones before I went to the duro bumps, I'm going to put an 1/8" spacer on my duro bumps.
    whatstcp likes this.
  14. May 10, 2021 at 8:12 PM
    uncleART
    Arty
    Bothell, WA
    13 MGM DCLB Sport
    Thanks. That’s good info.
  15. May 11, 2021 at 1:52 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Nope.
    I found out that OET is for the company Oetiker https://www.amazon.com/Oetiker-Clamps/s?k=Oetiker+Clamps
    Now to see if I have the right size for my driveshaft.
  16. May 11, 2021 at 1:54 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can get a mirror with compass and temp from here: https://www.bobsmirrors.com/
    BIG EYE[QUOTED] likes this.
  17. May 11, 2021 at 6:15 AM
    DaytonaTaco
    DaytonaTaco Well-Known Member
    2015 Tacoma Sport 4x4 access cab 6spd w/ tow package
    A Toyota Prado? Shift knob. Fit perfectly
    uncleART, Rezkid, Dye22 and 2 others like this.
  18. May 11, 2021 at 7:12 AM
    Tactical_Panda
    Tactical_Panda Armchair Anarchist
    Tim
    Fredericksburg, VA
    2015 Tacoma Double Cab, Off-Road Edition
    AJT Designs Shifter AJT Designs Battery Hold-Down ARB Awning 2500x2500 ARB Twin Compressor w/ Slee Offroad Mounting Bracket Avid Brush Bar Avid Step Bars Black Rock Wheels Series 997 Type 8 Circuit Breaker/Relay Panel Custom TRD Decals Bulletproof Fabricating Raptor Grill Bulletproof Fabricating Cooling Panel Bulletproof Fabricating Tow Hook Duluth Trading Company Dog Hammock Exhaust Breather Mod eBay Special 3-Gallon Air Tank Expedition Essentials TPAM EZ Down tailgate damper Flagpole Mounts, Dual Foglight Mod Front Camera Rear Camera; full time available General Grabber tires Goat Armor Hella Supertone Horns Iggy Switch Panel Icon Dynamics Stage 3 Suspension Katskin Leather Interior KickAss camp shower LED Bed Lights LED Interior Lights Midland MXT275 GMRS Two-Way Radio OEM Audio Plus Reference 500 audio upgrade Plano Cases. 42" roof mounted, X2 Pop-N-Lock Tailgate Handle Prinsu Cab Rack Prinsu-like Shell Rack Redline Tuning Hood Struts Rigid Industries 40" Light Bar Rigid Industries Ditch Lights Rigid Industries Spotlights Toyota Bed Step UltraGauge EM Plus v1.4 Vixen Air Horns, Four-Trumpet Whole bunch of decals worth about 5HP each Yakima Road Shower, 10-gal
    Today I finished installing a wireless rearview/backup camera for use with my overland trailer.
    When pulling my overland trailer I often have trouble seeing what is going on behind me. My truck's rearview mirror is partially blocked by the pillars on the trailer that support the RTT. So how do I get a better view of what's going on back there when driving?
    The solution (for me, anyhow) was to install this AUTO-VOX Solar Wireless Backup Camera system.
    https://www.amazon.com/dp/B08B1BFRNX?ref=ppx_yo2_dt_b_product_details
    The installation is so simple that even your boss could do it.
    The system consists of two parts: In rearview camera/battery/solar charger and in display module for inside the cab.
    This is the display module. Is comes with a suction-cup windshield mount but I instead ordered some RAM mount pieces so I could install it on my Expedition Essentials TPAM system. The most difficult part of the install was hiding the power supply cable.
    Here is the camera unit.
    It easily mounts behind your license plate. The camera is on top and the solar-charged battery is at the bottom. No wiring, no muss, no fuss. The camera transmits the video signal (digital; not analog) to the receiver in the cab.
    Now how cool is that?
  19. May 11, 2021 at 7:41 AM
    VA_Taco
    VA_Taco Well-Known Member
    Chino
    Virginia
    2012 TRD Sport 4x4
    6" w/35's
    Goodbye vibrations! New Tom Woods driveshaft.
  20. May 11, 2021 at 8:44 AM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    So wait, are saying a 1/2” bolt fits the metric threads on the frame??! That would be awesome.......
