  1. Jul 11, 2021 at 10:25 AM
    jkauf
    jkauf Well-Known Member
    2013 Tacoma Supercharged - Stock
    Prepping for molle panel
    SYLVANIA headlight restoration kit complete. I kinda messed up on the last UV protection step. anyone know if I can sand it again with just reg paper then apply another coat of UV protection?
  2. Jul 11, 2021 at 10:57 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Reinstalled the little protector on the bottom of the transfer case.
    Had it sand blasted and then I hit with a couple coats of black caliper paint.
    BassAckwards and Kuntrykid like this.
  3. Jul 11, 2021 at 11:11 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    What seats did you order and where did you order them from?
    superman2481[QUOTED] likes this.
  4. Jul 11, 2021 at 11:42 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    SS3 fogs, checked all fluids and an oil.change. working on my factory fog switch.
  5. Jul 11, 2021 at 12:02 PM
    Joeyourbro
    Joeyourbro Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    Sorry about the truck but at least it’s fixable. Did the cam manage to get any plate numbers? What cam are you using as well?
    Fluffymonkey[QUOTED] likes this.
  6. Jul 11, 2021 at 1:03 PM
    superman2481
    superman2481 Well-Known Member
    Ordered from prp.com and the new seats are the model enduro elite and the old seats are daily drivers
  7. Jul 11, 2021 at 2:19 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    Pulled the driver side back seat, yanked the plastic cubby, cut off the mounting tabs, dynamatted the entire area, and got the back seat back in just in time for another Gulf Coast afternoon shower. Mr Marv box on track to deliver tomorrow, figured I’d get the truck prepped while I had a break in this ceaseless rain.
    BustinJass17 and Kuntrykid like this.
  8. Jul 11, 2021 at 2:35 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    As a FedEx delivery driver I can say I see it happen all the time tires get split up @ the hub or left behind cuz it wouldn't fit in the truck so they probably got separated same way
  9. Jul 11, 2021 at 2:38 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    Replaced front brake pads with pad set 04465-04070, Shim kit 04945-0C030, 2 pin holds 47743-04093 and an Anti-rattle clip set 04947-0C010. I believe these are the semi-metallic pads, i think the other option (04465AZ200) is ceramic. This is the first break job since owning the truck, I bought it used, I believe the pads I pulled off were probably the ceramics, as they were stamped Toyota, but had different ADVICS part numbers (V6063-FF in the top right corner and 37331 bottom middle of the back plate) Also whoever replaced the pads prior had only partial shims on it, not sure if that’s all they had or didn’t push back the pistons enough to fit the pads on with the complete shim pack. So far happy with the braking. In the 30 years DIY maintenance on cars and trucks, probably the easiest pad replacement.
    Also replaced the burned out headlight high/low beam bulbs with Sylvania SilverStar 9003, haven’t had a chance to try them out yet.
  10. Jul 11, 2021 at 2:47 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Reattached the temperature sensor wires going to my "Bob's mirrors" mirror.
    I crimped them when I installed the mirror but upon removing the Ultra Gauge, the wires pulled out of the crimp.
    I used uninsulated crimps this time with heat shrink.
    Put the correct bolt in that holds my brake lines to the frame. I removed the bolt (to install a transfer case skid plate), threw it in the bed and thought I lost it until I swept out the bed and there it was.
    Gr8rSherman8r likes this.
  11. Jul 11, 2021 at 2:47 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    You should've done the dual anti-rattle clip mod.
    twotwentyswift and Taco-Obsessed like this.
  12. Jul 11, 2021 at 3:02 PM
    Micbt25
    TM
    Top and bottom?
  13. Jul 11, 2021 at 3:10 PM
    Sideways1
    Sideways1 Old Dirt Rider
    Dan
    Portland Oregon
    2015 TRD Sport 4x4 DCLB Pyrite Mica
    ADS 2.5 with Extended travel/ADS 2.5 Piggyback rear. Dakars. Pelfreybilt Aluminum front bumper,Skid and Brute Force Fab HC rear bumper. 5 x SCS Stealth 6's in Matte Bronze wrapped in Nitto Ridge Grapplers. Wet Okole front and rear seat covers. Wilco Bed Rail Tire Carrier. Light Racing Upper Control Arms. Marshall Fabrications sliders with kick out. Mobtown Tailgate Reinforcement Skin. hyper15125 retrofits. And many many odds and ends.
    Yes like this.
    be safe
    Dan
  14. Jul 11, 2021 at 3:17 PM
    Micbt25
    TM
    Thanks Dan, I’ll give it a try.
    Sideways1[QUOTED] likes this.
  15. Jul 11, 2021 at 3:36 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    I bought extra anti rattle clips when I was buying other parts and haven't put them on yet. Even though I had my wheels off last week for a rotation, I forgot to bring the parts with me.
  16. Jul 11, 2021 at 5:39 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    Added some 12v outlets where there should have been some from the factory
  17. Jul 11, 2021 at 6:26 PM
    superman2481
    Yeah my younger bro works for fedex too so it wasn’t a problem and they delivered it today but yeah I wasn’t upset about it.. if anything I thought maybe the driver left my neighborhood not knowing he had another for me and had already gone too far to come back
    Kuntrykid[QUOTED] likes this.
  18. Jul 11, 2021 at 7:09 PM
    Kuntrykid
    Jon
    Sharpsburg, MD
    Yeah... I get paid by the stop so if it's unmanifested then it gets delivered nxt day. I usually make a mental note & leave notes for customers that I deliver too as well
  19. Jul 11, 2021 at 7:21 PM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    I took that little bitch across some fuckin WHOOPS today! Goddamn it feels good.
  20. Jul 11, 2021 at 7:23 PM
    superman2481
    Installed new seats
