  1. Jul 12, 2021 at 8:06 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    If you pull the center console there's plenty of chassis ground locations. But I'm assuming you're going to want something a bit more substantial?
  2. Jul 12, 2021 at 8:07 PM
    Philrab
    Philrab Curator of useless knowledge
    Phil
    New Orleans, Louisiana
    2015 Pyrite Mica Quad Cab Prerunner
    Bunch of Basic Taco mods.
    My Mr Marv box showed up, threaded inserts all installed, two coats of stain laid down. Tomorrow morning starts the high gloss urethane and sanding.
    I don’t know why I’m so hellbent on making this pretty when it going behind the seat, probably because I know someone is going to see it.
    ace96 likes this.
  3. Jul 12, 2021 at 8:07 PM
    cbarham
    cbarham Well-Known Member
    Was hoping to use a factory ground so I didn't have to drill/sand paint away, I'm sure I'll figure something out once I get it all torn apart.
  4. Jul 12, 2021 at 8:13 PM
    Philrab
    Phil
    I found a threaded hole under the center console, found a spare bolt that fit, and grounded my amps there with a ring terminal. I believe there’s another ground stud under the carpet under the front seat as well.
  5. Jul 12, 2021 at 8:14 PM
    cbarham
    Thanks, I'm sure I'll find it just haven't looked very hard yet.
    Philrab[QUOTED] likes this.
  6. Jul 12, 2021 at 8:25 PM
    Wyckedan
    Dan
    Woodinville WA
    I used this one to ground my outlets to
  7. Jul 12, 2021 at 8:30 PM
    Philrab
    Phil
    The one I used was on the driver side rearward of the shifter, threaded right into the center transmission tunnel. Took a 10mm bolt, looked nice and sturdy. I need to circle back around and add another battery to chassis ground, and alternator wire if it isn’t awful to get to.
  8. Jul 12, 2021 at 8:30 PM
    SawF16
    SawF16 Well-Known Member
    21 TRD Sport DCSB
    TRD SEMA Wheels, 265/70R17 Toyo ATIII tires, Pro Grille
    Traded her in for a 2021. Cost me about $2k to drive for 9 years- not including the mods along the way.
  9. Jul 12, 2021 at 8:34 PM
    Fixxxer
    Fixxxer Well-Known Member
    Port Angeles
    '13 TRD Sport DCLB Super White
    ARB Front/Rear Air Lockers, Nitro Gear 4:88's, Hutchinson Rock Monsters, SOS Concepts Front Aluminium Bumper, UpTop Overland Alpha XL Roof Rack, ARB Snorkel, AVS Rainguards, Redline Hood Struts, Weathertech Mats, Flyzeye led's, MESO Molle Rack, Meso LED Dome Light, K&N Air Filter, UNI Filter Mod, Bosch Wiper Blades, Snugtop Sportster Reinforced Canopy, Viper 2-Way Remote Start, ARB Twin Compressor,
    I printed a mount for the switches. I went about it this way so I can relocate them to somewhere more permanent once I decide where I want them. The mount is held on with some industrial velcro, this way it is totally removable and no holes drilled into the interior.
  10. Jul 12, 2021 at 8:39 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I rarely see tires at my station. Usually 35s though when I do see some lol
    Kuntrykid[QUOTED] likes this.
  11. Jul 12, 2021 at 9:37 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    Silly question,
    does the ADD need to be deleted with the locker install?
    Thanks.
    Aardvark13[QUOTED] likes this.
  12. Jul 12, 2021 at 10:49 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    6112 plus top spacer... sayonara CV boots.
    dpele likes this.
  13. Jul 13, 2021 at 6:04 AM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 - BUILT FOR GO
    No, the ADD delete is just a way to remove some electronics from the process. I decided to knock it out since I was swapping front diffs anyway. This fall I will be installing an FJ case which will be one more actuator I will remove from the process. At that time I will either go air locker in the rear, or do the Elocker anytime mod(depending on how broke I am :rolleyes:).
    MSN88longbed[QUOTED] likes this.
  14. Jul 13, 2021 at 6:07 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Mines grounded to the bolt holding the seat down.
    BustinJass17 likes this.
  15. Jul 13, 2021 at 7:00 AM
    Steevoreeno
    Steevoreeno Well-Known Member
    Merrimack Valley, MA
    2015 Access Cab TRD Off-road
  16. Jul 13, 2021 at 7:03 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice! Where di you buy these?
    Sasquatchtaco[QUOTED] likes this.
  17. Jul 13, 2021 at 7:04 AM
    horchata
    horchata Member
    Davis
    2013 Taco TRD Sport
    After the first shock was installed I realized this was a problem. The previous owner had installed the spacers and I was not familiar with that initially, and was freaking out when my UCA wouldn’t stop rubbing on my spring. Luckily Autozone carries KYB top hats :)
  18. Jul 13, 2021 at 7:52 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Don't like you went for turd gen but damn $2k for 9 years of driving!:eek: That's just crazy! How many miles did you put on it?
  19. Jul 13, 2021 at 8:29 AM
    billnye1999
    billnye1999 Well-Known Member
    2013 Magnetic Gray Metallic Tacoma TRD Off-Road
    Which Jackery and Fridge is that?
  20. Jul 13, 2021 at 9:32 AM
    Wyckedan
    Dan
    Woodinville WA
    Explorer 1000 and a cheap Costway from Amazon
    billnye1999[QUOTED] likes this.
