  1. Jul 26, 2021 at 10:51 AM
    Jake Sprucer
    Jake Sprucer Member
    Jake
    Los Angeles, CA
    2013 Spruce Mica Tacoma TRD Sport
    - Interior/Exterior LEDs - TRD Pro Grille w/ Raptor Lights (4) - Hooke Road 4x4 Bed Rack - Cali Raised LED Bed Stiffeners - Ronin Factory 50 Cal. Antenna - UNI Filter - Bilstein 5100 lift - OME 886 coils - SPC UCAs - Icon AAL - BFG KO2s (275/70/17) - MRW MR315's - Prinsu Roof Rack - Smittybilt RTT
    New Spec-D Projector Headlights w/ LED DRL bar.
    (Stock day 1)
  2. Jul 26, 2021 at 10:59 AM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Try research Landau contact cement .
    @Wannabe4x
    Wannabe4x[QUOTED] likes this.
  3. Jul 26, 2021 at 2:02 PM
    eric6679
    eric6679 Member
    eric
    Switched out my pro comp struts for some billstein 5100's, Replaced 1.5 wheel spacers for 1.25 (Rubbing was just too much) and rigged up an RK phone mount.
    Also added some new LED reverse lights
  4. Jul 26, 2021 at 2:04 PM
    Clwrz
    Clwrz Well-Known Member
    San Diego, CA
    2007 Silver Double Cab Tacoma TRD Sport
    Can someone help me out really quick, I was wondering if I am going to replace the thermostat, does it have to be the whole thermostat housing replaced or can I just replace the thermo itself and keep the stock housing?
  5. Jul 26, 2021 at 2:09 PM
    Gen2Tacoma
    Gen2Tacoma A Question Asked is an Answer Learned!
    North East Atlanta
  6. Jul 26, 2021 at 2:14 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    Wheeling through tunnels
  7. Jul 26, 2021 at 2:18 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    If you can find this stuff, I've had luck at carpet supply warehouses, it'll glue water to oil I swear. That stuff is ridiculous https://www.amazon.ca/Wolf-Grip-Hi-Temp-Aerosol-Adhesive/dp/B07QY39TWC
    Wannabe4x[QUOTED] and theolee like this.
  8. Jul 26, 2021 at 2:43 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Getting trip ready.. which means I piled a bunch of crap on the roof.. :thumbsup:
  9. Jul 26, 2021 at 2:45 PM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
  10. Jul 26, 2021 at 2:49 PM
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    What wheels are those? True beadlock?
  11. Jul 26, 2021 at 2:51 PM
    eric6679
    eric6679 Member
    eric
    They're Pro Comp Faux Beads
    bprout[QUOTED] likes this.
  12. Jul 26, 2021 at 3:06 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    its the whole housing; i just replaced mine this past weekend. it comes as 1 piece.
    ^^^this doesnt apply to the 2nd gen/1GR engine
    4x4cajun, Kolter45 and Clwrz[QUOTED] like this.
  13. Jul 26, 2021 at 3:33 PM
    jkauf
    jkauf Well-Known Member
    2013 Tacoma Supercharged - Stock
    How often you change the oil? I just got a DD and the Tacoma sits a large majority of the time. Started to question whether I should start changing oil by time rather than mileage
  14. Jul 26, 2021 at 3:37 PM
    jkauf
    Saturday morning new RTT was put on the truck. Saturday night got to test it out
  15. Jul 26, 2021 at 4:12 PM
    Kolter45
    Kolter45 Well-Known Member
    Denver, CO
    2013 TRD Sport, 2015 Inferno 4Runner
    Toytec Boss Leer/Rhino Rack TRD Wheels/Falkens
    I gotta upgrade my headlamps. These look great
    Aardvark13 likes this.
  16. Jul 26, 2021 at 4:20 PM
    AVGeek
    AVGeek Well-Known Member
    Boulder City NV
    2011 Barcelona Red Reg Cab 4WD
    I’ve been getting a vibration around 60-70mph, and I think I may have found the cause. While under the truck doing an oil change, I grabbed one of the front axles and it moved much more than I think it should. I checked both, and each one moved at the differential end. My first thought is that it might be bad bearings, but I don’t know enough to be sure about the issue. I’m going to look for a shop that can handle 4WD diffs and front ends, but I could use some guidance about how much (if any) slop, the front axles should have. TIA
  17. Jul 26, 2021 at 4:40 PM
    SSTACO404
    SSTACO404 New Member
    Clay
    ‘15 SSM DCSB TRDS
    OEM Pro Grille
    Added 21 TRD Pro 16” wheels and 265/75r16 KO2s
  18. Jul 26, 2021 at 4:59 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    90k service....oil change, spark plugs, rear diff, power steering fluid, tire rotation, check, clean and adjust rear brakes. Coolant, transmission and brake fluids, shocks/struts and serpentine belt were done at 85k.
    SR-71A, jkuniverse, Kuntrykid and 6 others like this.
  19. Jul 26, 2021 at 5:23 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Went home for lunch so I could grab my step stool and grease for the upper control arms.
    I was going to replace the valve cover gasket and lube the upper arms after work today.
    After stopping at my house, I went to my new job that I haven't started yet (had to sign some papers) to pick up a drug test form.
    Went to the drug test site today after work instead of doing my truck, but they stopped testing at 3:00 and I got there at 3:30.
    Now I have to go tomorrow and another day I won't be able to work on my truck.
    Maybe Wednesday?
    theolee likes this.
  20. Jul 26, 2021 at 5:33 PM
    Kuntrykid
    Kuntrykid Tacoholics R Us
    Jon
    Sharpsburg, MD
    2015 tacoma 5spd access cab 4x4 red
    https://www.tacomaworld.com/threads/kuntykid-builds-a-taco.406341/
    Fitted 1st gen mudflaps that I scored off Facebook marketplace locally @ auto shop for $15. Trimmed a lil bit off of front so they wouldn't hang down so low. I'm left w/ a slight rub up front only in reverse & full turn. Any body done this & remedy issue?
    Thinking I can just add a way to pull flap in more twds fender. There is space between too...
    Also wanted to add that a buddy of mine it getting me a paint marker that I can touch up the "4WD" on the flaps w/
