  1. Aug 17, 2021 at 3:18 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Sux ass....bout par for @55holes nowadays.....hope kharma phux whoever did it.
    DG92071, Fluffymonkey and tacomakid96 like this.
  2. Aug 17, 2021 at 3:22 PM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    I just wrapped my tailgate to cover the rubbing from my Trasharoo, this might be the best option for you or file a insurance claim but it might not be worth the deductible.
    Its nice when you try to be responsible and someone fucks with your shit. sorry to see this man
    MSN88longbed and lynyrd3 like this.
  3. Aug 17, 2021 at 4:26 PM
    BustinJass17
    BustinJass17 Well-Known Member
    Justin
    Maryland
    2010 Tacoma TRD off road, DCSB, silver streak mica.
    Work in progress.
    I will check again. I went over it when I got my frame replaced and they were fine. It just looks like it wobbles a little differently from the cab... well obviously because they are not attached, lol.
  4. Aug 17, 2021 at 4:53 PM
    Schmidt6
    Schmidt6 Well-Known Member
    L
    2005 Black Tacoma Sr5 - Long Bed
    AAL Icon Billies 5100 ARB 2884 Diamond Back & Prinsu
    Not too bad, i thought it would be easy, for some reason the original bracket screws didn't align with the head unit, i mean the holes would align but it would stick out of the dash almost an inch, had to add self tapping screws to recess it.
    connection wise pretty easy, i got all the adapters for toyota and everything was just plug-n-play.
    TacoTues4x4[QUOTED] likes this.
  5. Aug 17, 2021 at 5:51 PM
    Gallowbraid
    Gallowbraid Known Problem
    Tightening the bed bolts may not fix the problem. There's a metal sleeve the bolt goes through on its way to the frame. If the composite bed has worn away at all from rubbing on the frame (does this with off road use or under heavy loads) the bed will be loose. You need to shim between the frame and the bed to solve the problem.
    Easy test is to grab the bottom of the bed just behind the cab and try to lift it. If it wiggles that's your problem bolt. Repeat near the wheel well and end of the bed to test those connections. Usually gets loose near the cab first.
    Fixed mine with a bit of rubber:
    http://americanadventurist.com/forum/threads/uno-the-2015-tacoma.7520/
  6. Aug 17, 2021 at 5:59 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    The Speedway Blue one. Easy. But I may be biased….
    mrproduxn[QUOTED] and stmpjmpr like this.
  7. Aug 17, 2021 at 7:07 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Big one for me. My RCI order shipped today and should be here by Friday! Supposedly….
  8. Aug 17, 2021 at 8:07 PM
    WestCoastBestCoast
    Wyn
    Portland, OR
    Also follow up, anybody know a good thread that details prepping, priming, and painting sliders?
  9. Aug 17, 2021 at 8:17 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I just wiped mine down, self etching primer (two coats), then black rustoleum (three coats).
    theolee likes this.
  10. Aug 17, 2021 at 8:27 PM
    MSN88longbed
    MSN88longbed Sporty Shorty
    Goleta, CA
    2014 Single Cab 4x4, Auto, Blinding White
    Kings all around, Method 306, Cooper STT Pro 265 75/R16, JBL amp, Morel Speakers, Undercover tonneau, Alcan leafs, SOS sliders, RCI skids, SSO Slimline, Engo winch.
    1) Clean them with any cleaner that removes grime. It will take several rags.
    2) Go over them with sand paper. 320-400 grit. Even scotchbrite would probably be okay.
    3) Clean with denatured alcohol if you can get it. Multiple times until rags seem decently clean.
    4) Spray with primer. Thin coats. Apply multiple coats until it looks uniform. Let dry between coats.
    5) Start applying paint. Some people would have you sand and clean before painting. I wouldn't. They're just sliders and you can repaint when necessary.
    6) Enjoy the fruits of your labor.
  11. Aug 17, 2021 at 8:33 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No. :luvya:
    Kidding of course. :thumbsup:
    I put the zip tie on there just to keep them together and controlled, without the zip tie they want to spread really far apart, be floppy, and hang down lower where I'm afraid they could grab a stick or rock off-road or some garbage or something on road.
    They're really long; +7" over stock and I'm only lifted 3".
    I ordered them this way as eventually I want to go 4" lift in the rear with 12-14" ish shocks (I think stock is 8-10"?) with the Archive Garage towers and 63" Chevy springs for some *DROOOOOOOP* and don't want my brake lines to become limit straps but in the mean time they really are too long and don't want them to become arresting cables off road.
    "The low hanging brake line grabs the rock." -Crawlithians 5:29
  12. Aug 18, 2021 at 5:03 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Ok i wasnt sure. I have extended with 63s and they didnt seem that long thats why i was confused
    Key-Rei[QUOTED] likes this.
  13. Aug 18, 2021 at 6:02 AM
    N0M4D72
    N0M4D72 Active Member
    2013 Super White Taco DBL Cab TRD SPORT 4x4, 6spd MT
    Just bought it, but it's been lifted and who knows what else has been crappily done before I got it. It's going to be a project for sure... but it's my daily driver too.
    Finally catching up on this thread and then I see your control knobs... Now, I gotta find some. Any help? I really like the 4x4 knob. Does the white part illuminate on the AC controls?
  14. Aug 18, 2021 at 6:04 AM
    GARSHA91
    Chicago
    https://www.ajtdesign-llc.com/
    alfredofausto likes this.
  15. Aug 18, 2021 at 6:34 AM
    N0M4D72
    AWESOME! Thank you!
  16. Aug 18, 2021 at 7:46 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    I took off the MGM decals from the TRD center caps. Man I love it!!
    IMG_20210818_102945107.jpg IMG_20210816_124901424_HDR.jpg signal-2021-08-18-103029.jpg
  17. Aug 18, 2021 at 7:56 AM
    pearing
    pearing Well-Known Member
    Wisconsin
    2015 SR5 quadcab
    Added a nose ring... 4x Innovations front receiver with the receiver put on the bottom of the cross bar....
  18. Aug 18, 2021 at 7:57 AM
    Rusted Alloy
    Rusted Alloy Well-Known Member
    Dayton, OH
    2010 Toyota Tacoma SR5 Double Cab 4x4
    They do but not so great with the stock bulbs. I switched the bulbs out to brighter LEDs. I posted a comparison pic on a few pages back.
  19. Aug 18, 2021 at 8:01 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Did the 3K greasing for the Icons UCAs.
  20. Aug 18, 2021 at 8:02 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Hmmm I should check mine...
    I find there's a clunk when going over speed bumps when mall crawling with an empty box (RTT still on). The noise goes away when the truck is loaded with camping gear.
    boogie3478[QUOTED] likes this.
