  1. Aug 27, 2021 at 8:48 PM
    powder1134
    powder1134 Well-Known Member
    2014 Tacoma TRD Off Road
    I've got one, and the damage didn't not come from rubbing on the tailgate skin. It was damaged from being pinched between the truck and the newly installed piston. I may remove one cable, or just keep replacing them. Cheap replacement part
  2. Aug 27, 2021 at 8:53 PM
    powder1134
    I kept losing the stick on weights, and felt like I had to rebalance my tires each time I did a rotation, so today i had the stick on weights removed from my wheels, and added the dynabead balancing beads. So far smooth as butter at all speeds.
    Jimmy92870 likes this.
  3. Aug 27, 2021 at 9:14 PM
    raymond32j
    raymond32j Well-Known Member
    Raymond
    Seattle, WA
    2013 Tacoma Regular Cab 4x4 Base
    Not yet.
  4. Aug 28, 2021 at 8:14 AM
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
  5. Aug 28, 2021 at 11:04 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Just made a nice light removable side table for my rear cap side door. I made it out of some leftover aluminum I had. It is braced and the wires run right to my homemade cap rack. This thing will hold about 70 lbs (not that I will be putting that much on there.) It comes on and off in about 10 seconds.
  6. Aug 28, 2021 at 11:13 AM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    My 2013 with 155k has been running a little hot recently. This was going 75 on the interstate, it stayed here maybe a minute or two before going back to the halfway mark.
    A couple years ago the gauge also hit about 3/4 while moving slowly on a high mountain pass in 4wd too.
    I had a radiator flush around 100k. Should I consider replacing the thermostat?
    Philrab and Schmidt6 like this.
  7. Aug 28, 2021 at 1:07 PM
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    Finally got the RCI sliders on. Would’ve finished faster, but I forgot about the front cross member plates until I finished everything else….
    Also painted by yours truly. I went with flat black rattle can.
    4x4cajun, PacTac, Z7Xtreme and 3 others like this.
  8. Aug 28, 2021 at 2:29 PM
    TacoTuesday1
    SD CA
    Why not?
    I will be replacing my Tstat, WP, and coolant because it is quick, cheap, and easy.
    Replacing them will rule them out as potential causes.
    BraskaTaco[QUOTED] likes this.
  9. Aug 28, 2021 at 5:42 PM
    Waasheem
    Waasheem
    2007 xrunner
    Replaced the pvc valve. Found I didn’t have a 19mm deep in 6 point, only 12 point which kept slipping trying to remove it. So this is what I used. My long 1/2 ratchet, a reducer, 2 long extensions, and a 19mm crowns foot. It wasn’t what I would call tight, it was stuck. As soon as it started to turn, it came out easy. In with the new one with a tiny bit of anti seize.
    Also replaced the serpentine belt. The old one was cracking on the ribs. Once it was out I could see it’s dried out and the seam is beginning to separate. I also gave everything the belt touches a spin. I’ve had a cold start squeaking so I’m guessing belt issue or one of the pulleys. The only one questionable is the tensioner. Water pump, ac, alternator, ps pump, idlers all felt good. No wobble, notchiness, no squeak.
    Gr8rSherman8r and DG92071 like this.
  10. Aug 28, 2021 at 5:50 PM
    Schmidt6
    Schmidt6 Well-Known Member
    L
    2005 Black Tacoma Sr5 - Long Bed
    AAL Icon Billies 5100 ARB 2884 Diamond Back & Prinsu
    mine was doing the same thing,
    i replaced the radiator fan clutch and thermostat
    all good now
  11. Aug 28, 2021 at 6:41 PM
    Rusted Alloy
    Rusted Alloy Well-Known Member
    Dayton, OH
    2010 Toyota Tacoma SR5 Double Cab 4x4
    I've been noticing a few tensioner related problems coming up with people here lately. Maybe it's because I had to replace mine and it's on my radar.
  12. Aug 28, 2021 at 8:00 PM
    Big Foot
    Big Foot Well-Known Member
    Washington
    2014 DCLB
    Installed a Blue Sea 12 ckt power tray & accessories I got from @Mr.PowerTrays . Very straight forward & easy install other than a few awkward wrench angles bolting the tray to the frame. Gona add another small fuse block & blue sea below deck panel in the bed for power & lighting once I decide on a good route to get the wire back there. DA0105A4-D1A7-4CCE-AA93-EE68B109D3A4.jpg
    BMOW71, TacoEspecial and Gruber1922 like this.
  13. Aug 28, 2021 at 10:59 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    theolee[QUOTED] likes this.
  14. Aug 28, 2021 at 11:15 PM
    theolee
    theolee www.nickleecreations.com
    Theo
    SAN DIEGO
    Black 09 Tacoma SR5 Pre-Runner AC 4.0
    Ya I saw that. Im running without the cable though.
  15. Aug 29, 2021 at 6:49 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Took it to the park and it became the PJ Mask Headquarters.
  16. Aug 29, 2021 at 6:56 AM
    Hyland33
    Hyland33 Well-Known Member
    Andrew
    Leicester, MA
    2015 Tacoma TRD Offroad
    Put in some Morimoto headlights today. They totally change the look of the truck coming from the stock lights.
    DA8672D5-F6D4-435F-84A2-1CAF354B05A6.jpg B06B6951-C694-4F1B-9651-84B510240DF5.jpg 84607337-40BA-49BA-83E3-2C9615A2D986.jpg
  17. Aug 29, 2021 at 7:09 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    How’s the output? What do they use for a bulb?
  18. Aug 29, 2021 at 7:30 AM
    powder1134
    Looks great!
  19. Aug 29, 2021 at 8:06 AM
    Hyland33
    Andrew
    Leicester, MA
    No bulb. They use led projectors.
    I just need to play with the alignment a tiny bit more and it’ll be perfect.
  20. Aug 29, 2021 at 8:48 AM
    TRnCO
    TRnCO Well-Known Member
    Tim
    Elizabeth, CO
    07 and 14 DCSB 4x4 Tacoma
    just a little past due for the first time at 238,478 miles, I flushed out and filled the brake fluid on my '07. Also sucked out the power steering reservoir and refilled.
