  1. Sep 4, 2021 at 7:01 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    That sounds fair. My hood is losing clearcoat and paint has started to pepper off in small spots. Body is good except for some scratches I need to polish and touch up. Just haven't got any estimates. Roof is starting to feel like rough sandpaper in spots too. I figure a rough price of $1200 for both so i appreciate the reply.
  2. Sep 4, 2021 at 7:21 PM
    eric6679
    eric6679 Member
    eric
    C4CD02BB-EF32-4A3B-8247-8771D1D83BF2.jpg New N Fab side steps
  3. Sep 4, 2021 at 8:22 PM
    Gr8rSherman8r
    Gr8rSherman8r OKLA•YOTA
    Owasso
    2015 MGM TRD Sport Longbed
    Done by me: decals, plastidip, and vinyl. More to come. Not done by me: Icon front/rear suspension; Total Chaos UCA’s; Method wheels/34” Falken tires; Prinsu cab rack/LED light bar; V1Air compressor piped to a 2.5 gallon underbed tank; Pelfreybilt front/rear bumpers; Smittybilt front winch.
    Checked to see if the shifter knob I’m about to start milling was to my liking by using a 3D printed prototype. I’m happy, so I’ll start milling and drilling a chunk of brass soon.
    MSN88longbed and DG92071 like this.
  4. Sep 4, 2021 at 10:07 PM
    tilly87
    tilly87 Active Member
    chris
    california
    05 trd offroad dblcb sb
    Bilstein 5100 front with OME springs Bilstein 5100 rears KSP upper control arms Alpha rexx pro headlights Alpha rexx luxx taillights toyo open country at3 295/75/16 dx4 rebel wheel 16x8 Cali raised amber fog lights Cali raised amber ditch lights TRD pro style grille AEM brute force intake MBRP cat back turn down exhaust
    on the back roads
    GRNT4R, BMOW71, K-DubTaco and 5 others like this.
  5. Sep 5, 2021 at 5:34 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Oem painted surround with a eBay pro insert
    BMOW71, K-DubTaco, Blake4x4 and 7 others like this.
  6. Sep 5, 2021 at 6:57 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Buddies I wheel with decided GMRS was going to be the best radio set up for the group since they didn't want to take the ham tech exam. So I added some UV5X's to my radios arsenal. I unplugged my CB since I never use it. Drilled out my Rago cb antenna mount to fit an NMO adapter and bought a stubby antenna to get the antenna out from inside the metal cab. Already had some UV5R parts from when I first passed tech exam so now i have a radio mount, a mic, and easy access to the coax.
    I realize I need a better ground plane than the rear of the truck but I don't plan on using the GMRS for more than wheeling trips (<1 mile distance to the next guy) My ham settup has the reach and would be what I would use if I needed to reach out.
  7. Sep 5, 2021 at 7:35 AM
    jneutron
    jneutron Well-Known Member
    Colorado
    2022 ORDCSB Cemint RIP-15 DCSB TRD MGM
    Installed Spiker hood struts - sooooo much better (completes the 3 things Toyota forgot on a '15 - hood struts, ext temp, trailer wire harness location)
    Front / rear diff oil change
    Transfer case oil change
    Oil and filter change
    Engine air filter
    Cabin air filter - K&N
    Driveshaft lube
    Now I just need to wash it
    SpikerEng, dpf88101, T.Barn and 6 others like this.
  8. Sep 5, 2021 at 8:01 AM
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    Solid check list. You might be the first person I’ve seen replace the steering rack at 50k for maintenance purposes. haha
  9. Sep 5, 2021 at 8:59 AM
    2013XSPX
    2013XSPX Well-Known Member
    GA/FL Border
    2013 XSP-X
    Pelfreybilt front/rear, RCI underneath, Morimoto Headlights, Prinsu racks, SCS Brushed Copper Ray 10's, EO Sliders, Baja Designs and Rigid lights, Inca 4x4 Camper
    Finally cleaned it and put some wax on.
    dpele, BMOW71, BassAckwards and 5 others like this.
  10. Sep 5, 2021 at 9:03 AM
    jon_elc
    jon_elc Well-Known Member
    NorCal
    2011 SR5 4x4 Timberland Mica Snugtop Rebel
    245-70R-17 Revo3 Cut mudflaps 4.5" F / 1.5" R
    what's the height of the opened hood to the floor? i like the spiker strut idea but i'm not that tall. maybe i need to run my own struts custom.
  11. Sep 5, 2021 at 9:39 AM
    Hemlock76
    Hemlock76 Member
    I put this on mine. Worked great for a while. But the cable for the tailgate was always being jammed in a weird way and it wasn't too long before it broke. After replacing the cable for the second time. I took off the tailgate assist. I don't recommend this mod for anyone! Save you money for something else.
    stbear likes this.
  12. Sep 5, 2021 at 1:42 PM
    Buglump
    Buglump Member
    2012 RWD Prerunner
    None
    Finished with front end, Rancho RS9000XL quick lifts, new upper control arms, new sway bar links, new lower ball joints, new tie rod ends, new drilled and slotted rotors with new pads. Have put 274,xxxx miles on this thing since 2012 and now it feels and drives like a new truck. Had to lift the rear 1.5 inches as well just to get rid of that gangster lean or donk mobile look. In all that, it does not appear I need an alignment, going to run it by for a check and alignment to be sure but rolling between traffic lights at 30 mph hands off of wheel and braking the thing tracks straight and true. Now, have a set of Set of 4 Herko Ignition Coil B087HE Red inbound, have had a noticeable drop in MPG over the past year or so, no codes, no CEL, changed out plugs a few months ago but no improvement, have cleaned Mass Air Flow Sensor, cleaned air filter, changed air fuel ratio pre cat sensor to DENSO so hoping this makes a difference. I was getting almost 25MPG on the highway before and that dropped to around 19.5-21 MPG on long trips. I had replaced OEM Ignition coils with some off brand eBay crap at around 190K miles and they worked good for a while. Hoping this restores MPG.
    DG92071 likes this.
  13. Sep 5, 2021 at 2:11 PM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Looking to mount my Ripp superchargers oil catch can but can’t mount it in the required location due to the compressor. Any ideas?
    please excuse my dirty bay
  14. Sep 5, 2021 at 2:21 PM
    jneutron
    Colorado
    I am only 5'10" and I set it 4" higher than the stock height and I can still reach it easily. You can set it at stock height.
    SpikerEng likes this.
  15. Sep 5, 2021 at 3:25 PM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
    And NOW the passenger side light bulb again...Well at least it only took me about 3 minutes this time because I'm experienced...Got another two pack...I watching you drivers side! 202,431
    Island Cruiser likes this.
  16. Sep 5, 2021 at 3:31 PM
    will.i.was
    will.i.was Well-Known Member
    Will
    Houston, Texas
    SC 2.5
    Did alot of rewiring, ripped apart the 3rd crossmember due to some leaks. Took a picture at the park.
  17. Sep 5, 2021 at 3:41 PM
    crux
    crux Well-Known Member
    New Mexico
    OR
    Honeycomb composite sleeper platform.
    Great setup!
    Our group went GMRS and paid the $70FCC fee to use the repeaters. For a while this worked great, but the repeater we used might be down.
    For full disclosure our use would be infrequent and mostly when off road. Overall experience I'd rate at a beginner level given the frequency we are able to get out. If we switched over to HAM I would want to do it right and take the HAM tech exam. Curious what the investment would be in terms of time and cost. Plus any recommendations for a HAM vehicle set up? I would want one on the trailer (Base camp) and vehicle.
  18. Sep 5, 2021 at 3:57 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    It comes with directions on how to mount it to get different amounts of lift. Pretty straightforward
  19. Sep 5, 2021 at 4:37 PM
    will.i.was
    Will
    Houston, Texas
    SC 2.5
    Cost wise it is minimal. About the same as GMRS. I run an anytone 778uv with powerwerx SAR antenna. I can hit 10-15 miles simplex and repeater wise 50-100 miles. With more advanced repeaters that utilize winlink I regularly have conversations with other operators as far as Alaska. Ham is more versatile in many ways but does have testing restrictions, which aren't bad at all if you enjoy electrical work.
    Excuse the dirty interior.. just a quick shot of the cabin setup. I rarely use the cb anymore tbh.
  20. Sep 5, 2021 at 4:53 PM
    Georgeth1022
    Georgeth1022 Well-Known Member
    Shaun
    West Hills CA
    2013 BAJA w/ too many mods
    Too many to list
    Just another lighting upgrade
    gregzz, TOYTONKA, BMOW71 and 7 others like this.
