  1. Nov 16, 2021 at 6:44 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    They are toyo at3 in load range c. They measure about 34.5 @ 32psi on an 8.5 inch rim
  2. Nov 16, 2021 at 7:00 PM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    That's a full inch bigger. Nice. I like the 11.5" width. Much less stuff to cut
    IvanhoeTaco[QUOTED] likes this.
  3. Nov 16, 2021 at 7:04 PM
    IvanhoeTaco
    Eastern NC
    I wouldve gotten them of i knew it was a real size before my 285/75s. Basically the same weight as well.
  4. Nov 16, 2021 at 8:24 PM
    Steelhead Bum
    Steelhead Bum Well-Known Member
    Mitchell
    Eastern WA
    13 DCLB Sport 4x4, 92 AC MT 4x4
    Im assuming you took the entire rail down to bare metal, primed and applied the bed liner? Or did you only sand, prime and paint the areas affected by rust?
    How did you apply the bed liner? Roll on/brush or sprayed?
    Was trying to think of what to do to my door sills. Driver side door sill underneath the trim piece is starting to wear and i noticed a small pencil eraser size spot starting to develop. Might have to do this and the rails come spring.
  5. Nov 16, 2021 at 8:34 PM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
  6. Nov 16, 2021 at 9:22 PM
    Evergreen_Offroad
    Evergreen_Offroad Well-Known Member
    Andrew
    2009 Tacoma TRD Offroad Access Cab
    35s, armor, mid travel etc.
    Well with a bobbed bed, toolbox, and 39in spare it becomes difficult to figure out where to store camping gear for long trips like the Rubicon. After a buddy of mine stared at the bed with beer in hand we came up with this. Basic small Thule roof rack, to keep it low it will be ratcheted down for now until I figure out how I want to build a super low pro mount for it.
  7. Nov 16, 2021 at 9:36 PM
    MasonSTL
    MasonSTL Well-Known Member
    Green Bay, WI
    06 TRDOR AC MT
    I didn't take the entire bed rail down to metal, only the parts where the rust was. Then I sanded and primed the whole thing and then hit it with 2 coats of some rattle can bed liner.
    Steelhead Bum[QUOTED] likes this.
  8. Nov 16, 2021 at 9:44 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Nice! Some Thule square bars with rt angle brackets slipped inside could hang it from the bed rails.
  9. Nov 16, 2021 at 9:50 PM
    Evergreen_Offroad
    Andrew
    Would it be able to remain below bed height?
  10. Nov 16, 2021 at 10:56 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Sure, just use a large enough angle bracket that the bolt hole at the end lines up with the bed rail before the rack sticks up too much. How tall is the rack? It looks around 3-4” on the sides and 4-5” front and back. Does the tire need to slide under it?
  11. Nov 16, 2021 at 11:13 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    Another way that keeps the bars out of the space below the rack would be to slide them under the top bar of the side rails on the rack. Then the Thule bars would just about line up with the bed rails so the angle brackets would lay sideways rather than vertical.
  12. Nov 17, 2021 at 12:50 AM
    4x4cajun
    4x4cajun Well-Known Member
    Fredericksburg, VA
    2014 Limited 4x4
    CHEVERLY my service dog! Lol
    GOD-like!!
  13. Nov 17, 2021 at 6:53 AM
    guyfromky
    guyfromky Well-Known Member
    Any update on the light output from those headlights? I am in the market to replace mine and love the sport look but can't shell out the OEM price tag.
  14. Nov 17, 2021 at 9:22 AM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Took a few days to tweak my headlight alignments as I swapped headlights and didn't mark a wall for alignment. Same output as stock using the same stock bulbs. I need to read and take notes from the "ultimate headlight mod" thread and get brighter bulbs. I had very nice Hikari LED headlight bulbs in my 2016. Super bright with perfect cutoff. Bulbs alone were $180 for all 4. Not spending that much on this truck. Just need a brighter halogen and possibly a harness to produce more wattage. Like I said these headlights produce the same stock output as oem headlights.
  15. Nov 17, 2021 at 10:13 AM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Use some T nuts and utilize the bed rails
  16. Nov 17, 2021 at 10:17 AM
    IvanhoeTaco
    Eastern NC
    So far mcneil racing has lied to me. Not looking foward to quality of fenders at this point. Called last friday and was told they were packaging some things up and if they couldnt get it out that day then monday at the latest. Monday comes and goes, tuesday comes and goes, I call today and they say some other stuff came up and they havent shipped it yet.
    Im cool with a custom product that takes 5 weeks to make and fulfill but I cant handle the lies. Apparently they arent even done making rhe rears at this point.
    Id rather you say its going to be 2 weeks before we ship than your order is being shipped today and it wasnt the truth.
  17. Nov 17, 2021 at 10:40 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    That sucks man, I agree I'd at least respect the honesty if somebody was running behind on something.
    Biscuits and IvanhoeTaco[QUOTED] like this.
  18. Nov 17, 2021 at 10:47 AM
    IvanhoeTaco
    Eastern NC
    Thats all I require! I have given them grace by not calling every day and bugging them but now there is no way im gettinf these before next week.
  19. Nov 17, 2021 at 10:57 AM
    NavyDiver72
    NavyDiver72 I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    How many miles you have on her?
    IvanhoeTaco likes this.
  20. Nov 17, 2021 at 3:04 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Spot mirrors are in. Had to break the tabs off my old mirrors because they wouldn't come out lol48DD853F-1B42-416C-B952-A77AD0BFD795.jpg
