  1. Dec 2, 2021 at 11:41 AM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    only 6 bucks an hour for a lift and tools included???
    that is the deal of a lifetime!!!
    Aworkinprogress likes this.
  2. Dec 2, 2021 at 11:46 AM
    dpf88101
    dpf88101 Well-Known Member
    Fully agree - they have full alignment rack, paint stall, 9 full bays with drive on lifts, ASE certified mechanics onsite to assist if needed etc.
    Thankful for the benefits of 22 years active duty, been retired 20 years, and working as a contractor for the past 10 years
    TomTwo, theolee and uurx[QUOTED] like this.
  3. Dec 2, 2021 at 12:42 PM
    idriveabox
    idriveabox Well-Known Member
    Calgary, AB
    2015 BRM SR5
    Put a set of DD sports in. Going from the non fog sr5 to this is an upgrade. Have to figure out the aiming when it gets dark enough. 13C0D6E2-25C0-4704-B21B-99FB8B0AB898.jpg
    PacTac, Squirt, TomTwo and 8 others like this.
  4. Dec 2, 2021 at 1:33 PM
    Aworkinprogress
    Aworkinprogress Well-Known Member
    Scott
    '10 ACOR Taco
    I put on a used set of 255 75r 17"s that I picked up yesterday
    pahaf, Squirt, 4x4cajun and 2 others like this.
  5. Dec 2, 2021 at 1:36 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Sounds to me like he paid for 32 years and counting so I’d hope they give him a deal. He earned it!
    killer perk tho
  6. Dec 2, 2021 at 1:54 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Diode dynamics ssc2 pods reverse lights and wired the red backlight into the brakes
    PacTac, Squirt, Icarus II and 13 others like this.
  7. Dec 2, 2021 at 1:59 PM
    Joeyourbro
    Joeyourbro Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    Bought a 29” ARE DCU cap in hopes of hitting the road for a month or two with my girlfriend and dog when our apartment lease is up at the end of March or beginning of April. Needs quite a bit of work before then to be able to live out of it for that long. Gonna attempt to make some bed stiffeners this weekend. The research begins
    PacTac, Squirt, Damie Street and 12 others like this.
  8. Dec 2, 2021 at 2:00 PM
    billnye1999
    billnye1999 Well-Known Member
    2013 Magnetic Gray Metallic Tacoma TRD Off-Road
    How did you wire them up?
    HPMaster likes this.
  9. Dec 2, 2021 at 2:15 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    I tapped into the tail light harness, seems to be fine. Didn’t want to run a separate relay
    billnye1999[QUOTED] likes this.
  10. Dec 2, 2021 at 3:08 PM
    killerkeener
    killerkeener Well-Known Member
    2011 trd 4x4 manual
    None yet
  11. Dec 2, 2021 at 3:09 PM
    killerkeener
    2011 trd 4x4 manual
    None yet
    What model #smitty...what thread size
  12. Dec 2, 2021 at 3:56 PM
    dpf88101
    New Spectre fuel and water cans arrived today. Fit perfectly in the frame/mount Travis of SOB Fabrication (Ruidoso NM) built me for my swing outs
    08A1986C-D27F-42AF-9DF6-20A0F31E51A5.jpg 01E7A776-F41E-43DD-AB64-7C95B16A6EE1.jpg
    PacTac, srspicer, dpele and 9 others like this.
  13. Dec 2, 2021 at 3:57 PM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    Man - I would kill (figuratively) for a auto hobby shop near me. Sounds like a great place for some DIY projects.
    dpf88101[QUOTED] likes this.
  14. Dec 2, 2021 at 5:05 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    I doubt they are cheaper but they are better than oem. I'll post a link from Amazon. You can probably find them cheaper somewhere else Power Slot 126.44129CSR Slotted Brake Rotor https://www.amazon.com/dp/B001O97JXC?_encoding=UTF8
    asuchemist[QUOTED] likes this.
  15. Dec 2, 2021 at 5:27 PM
    Jsmoore679
    Jsmoore679 Well-Known Member
    2015 TRD AC 4x4
    A few money and time consuming things
    Looks sick man
  16. Dec 2, 2021 at 5:31 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Best kind of trip. Do as much as you can before kids. I know I did.
    Joeyourbro[QUOTED] and 4x4cajun like this.
  17. Dec 2, 2021 at 9:22 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    A quick afternoon project, applied thermo tech on my heat shield56B99D2F-F3FB-44E9-AFA0-7D9266E54BDB.jpg 07C92ECD-3489-4A20-A3C7-69234273C463.jpg D6BCA968-15CD-4056-B03E-61118AC49419.jpg
    Longtech, DG92071, dpele and 2 others like this.
  18. Dec 2, 2021 at 9:29 PM
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    I did the full tube and the scan gauge said it’s 13 degrees cooler on my ait, this was coming from a K&n I take without wrap and going to the afe with the rad support I take scoop as well so that would be taken into consideration
    srspicer, 4x4cajun and loyaltothetaco like this.
  19. Dec 2, 2021 at 9:30 PM
    Xmplry808
    What temp difference is it from ambient temperature?
  20. Dec 2, 2021 at 9:44 PM
    Xmplry808
    With my current intake set up before the thermo Tec, I would get 3* hotter than ambient temp if I’m constantly moving. It’s not a standard k&n set up :thumbsup:
    4x4cajun likes this.
