  1. Dec 21, 2021 at 2:57 PM
    DG92071
    DG92071 Well-Known Member
    The Tacoma acquired a new squeak yesterday and last night I found this.
    So today I'm welding it up. It's the frame crossmember in front of the rear axle very close to where the traction bar bolts on.
    I made some money this morning and it's finally time to throw the stock leaf springs and the lift blocks in the trash. I wish I could remember which leaf spring manufacturer I wanted to avoid, it was either Deaver or Dakar... need a 3" lift and recommendations would be appreciated.
    Musubi3 and theolee like this.
  2. Dec 21, 2021 at 3:10 PM
    essjay
    essjay Part-Time Lurker
    Concord, CA
    2011 Tacoma SR5 (V6/AC/4WD)
    Installed @Diode Dynamics SS3 Pro fog lights, Philips RacingVision GT200 H4 headlight bulbs, and a Mountain Hatch tailgate cover.
  3. Dec 21, 2021 at 3:24 PM
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    so I’m on 17x9 -12 with 1.25” spacers. 7” front lift. No CMC, pinch weld smashed, fender lowers cut. The SPCs helped a ton to center the wheels
    kgarrett11[QUOTED] likes this.
  4. Dec 21, 2021 at 3:31 PM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    Probably wanted to avoid Dakars. I run them and I love them besides the fact the squeak like crazy. All pro and Deaver I have head really good things about. Dakars are really solid option and probably a little cheaper. You tow a lot so id get the HD Dakar if you do it and get some leaf isolators and you wont have any issue.
    theolee and DG92071[QUOTED] like this.
  5. Dec 21, 2021 at 3:32 PM
    Northbound_Taco
    09 Off road build
    Who makes this front bumper? I like the headlight loops design. Looks different then most.
  6. Dec 21, 2021 at 3:36 PM
    essjay
    Concord, CA
    Bay Area Metal Fab
  7. Dec 21, 2021 at 4:47 PM
    YotaProject
    YotaProject Well-Known Member
    Adrian
    Charleston SC
    Fox Lifted 2007 Taco With Mods Here & There
    Can confirm I have the truck Christmas week ready.
  8. Dec 21, 2021 at 5:09 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You think something like this will work?
  9. Dec 21, 2021 at 5:12 PM
    Squirt
    Squirt #SoBadGotBannedFromOwnThread
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
  10. Dec 21, 2021 at 7:07 PM
    Xmplry808
    Xmplry808 Well-Known Member
    2015 BRM Tacoma xrunner
    Engine: -Doug thorely long tube headers -URD dual O2 simulator -Dual 2.5” QTP cut outs -RADS true dual piping -TRD supercharger MP90 -Custom air duct -K&N cold air intake -AFE tb adapter -AFE 76mm throttle body -URD 2.7 supercharger pulley -URD fuel pump/Aeromotive 340 upgrade -URD extension harness -URD maf calibrator w/map sensor -URD 170 thermostat -URD speed unlimiter -Cusco oil catch can -URD fuel rail tap -FPR mod -COUPE oil pan spacer w/baffle -NX wet nitrous kit 50 shot -NX 10 lb bottle -NX purge kit -ZEX rapid fire module -Greddy oil filter relocation adapter -Mishimoto oil cooler -HKS big 3 wire upgrade -Pulley wrap mod Electrical -130amp alternator -Voltage Booster Pro SPARK -Optima yellow top group 27 -1/0 wire upgrade Drivetrain: -B&M short shifter -Detroit tru trac LSD -Competition Clutch stage 4/6 puck clutch kit -Competition Clutch lighten flywheel -URD throw out bearing/sleeve kit -Sprint booster V3 -Remove clutch accumulator Suspension: -Djm front A arms -Djm welded in frame notch -DJM offset bushings -XII Performance front coilovers -XII Performance sway bars Fronts 1 3/8” Rear 1 1/16” -4" Custom Taco drop blocks -QA1 rear shocks -Air Lift air bags -Air compressor -Alignment Cam Gussets -UMI billet front sway bar mounts 1 3/8 Wheels/tires: -HRE wheels 540 step lip Front 20x10 255/35/20 Rear 20x11 305/30/20 Brakes: -Performance Brake Unlimited BBK -4 piston Tundra calipers -360mm ISF drilled brembo rotors -Stop tech stainless steel brake hoses -Brembo brake pads Exterior: -35% ceramic front window tint -Hood spacers 1" -Cut front grill -Cut hood scoop -Strictly Street RACE spec spoiler -Race front and rear tow hooks -Diode Dynamic SS3 yellow pro fogs -Race Louvers Front RSF fender trim Rear FL fender trim Interior: -Lotek dual gauge pillar pods -Ultra gauge Mx 1.3 -TRD shift knob -JunctionProduce pillow cushions (4) -Bellezza leather neck pads (2) -Innovation gauge dual wide band -Innovation boost gauge w/shift light -Air lift dual air pressure gauge -TRD racing pedals -LED lighting Sounds: -Sony XAV-AX8000 -JLaudio (2)13w6v2 subwoofer in isobaric ported box 33hz -JLaudio 1000/1 mono amp -JLaudio Evo C3 6.5 (4)co-axles -JLaudio 300/4 4 ch. amp
    I had a weird feeling clutch pedal. Like there was air in the lines. Mind you that I have bleed my lines years ago and haven’t open the lines ever since, and that my reservoir tank had clean fliuds. So I tried to bleed the system, with filthy, burned oil coming out. So I thought easy fix. My wife was pumping for me while I was opening the bleed screw. Even after the fluid was flushed and cleaned… the master wouldn’t return fully up not even half way. Then later I seen my slave leaking a bit since there was no funk in the lines, it probably remove the funk that kept things from leaking lol. So I had to replace clutch master and slave. Since I was doing it, I always wanted to removed the accumulator, which I by passed now. Clutch is back to normal and I actually can row through the gears now! I still want to adjust my clutch pedal but I’m happy that it’s back on the roads
  11. Dec 22, 2021 at 2:49 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Yesterday I stopped by my local dealer to order the lower shock bolt/nut and get a price on sway bar end links.
    The lower shock bushing isn't available separately like on 1st Gen's.
    The bolt part number is 90105-A0113 and the nut part number is 90178-A0058
    Cativelense likes this.
  12. Dec 22, 2021 at 3:18 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    No.....it will not.
  13. Dec 22, 2021 at 3:30 AM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
    Thank you. That's what I bought so I'll return it and get the 6 Ton press.
    crashngiggles[QUOTED] likes this.
  14. Dec 22, 2021 at 4:31 AM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Clutch accumulator for sale: lol
    C4F78E09-6120-40F5-8AE2-A058D4E318E4.jpg F0D6610D-08AB-4135-8D8F-CFEBC53DE778.jpg
    Replaced the accumulator with a hard line and put the updated slave cylinder in. Quite the difference in drive ability for sure. Happy with the change.
    I also got my third brake light on the soft topper so hopefully it’s one less thing to be harassed about during inspection which is due now.
  15. Dec 22, 2021 at 4:38 AM
    flightmech08
    flightmech08 Well-Known Member
    Hillsburgh, ontario
    2007 trd double cab 4x4 6 speed
    old man emu lift kit with full dakkars. ARB front locker, rear dif vent mod 1.5" spacers
    Which part numbers did you order for the line and the cylinder
    20somethingwidataco likes this.
  16. Dec 22, 2021 at 5:03 AM
    crashngiggles
    Jared
    You found a 6 ton Harbor Freight press? I was looking for a while and couldn't find one. We had to pick up a 12 ton one. Please let me know if you do find one and I will buy it off of you afterwards if you want to get rid of it.
    super_white[QUOTED] likes this.
  17. Dec 22, 2021 at 5:20 AM
    T.Barn
    Todd
    2010 AC 4x4 6MT
  18. Dec 22, 2021 at 5:26 AM
    Aworkinprogress
    Aworkinprogress Well-Known Member
    Scott
    '10 ACOR Taco
  19. Dec 22, 2021 at 5:28 AM
    T.Barn
    Todd
    2010 AC 4x4 6MT
    Yeah I am not sure why the picture looks like that but it’s exactly what I ordered. The pic looked the same when I ordered it as well but it comes with the banjo.
  20. Dec 22, 2021 at 5:33 AM
    Aworkinprogress
    Scott
    '10 ACOR Taco
    Cool, Thanks! Good find!! Ordering one today
    T.Barn[QUOTED] likes this.
