  1. Jan 13, 2022 at 9:09 AM
    elricfate
    elricfate Well-Known Member
    2009 Tacoma AC Silver Mica
    It's a limitation in the flasher design that it doesn't support DTRL + Partial tap for lane change blinking. I think it's the same problem that keeps you from being able to use switchback blinkers, but don't quote me on that.
    Same difference as going from incandescent turn signals to LED turn signals - if you don't want to install the resistors in-line with the bulb connectors, then you need to swap the flasher out because a thermal flasher relay gives you hyperflash with the relatively low draw of LEDs, but a timed flasher relay doesn't care.
    JimIowa likes this.
  2. Jan 13, 2022 at 10:58 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Mines from Florida...
    It creates lots of confusion for me lol
  3. Jan 13, 2022 at 11:26 AM
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Looks pretty close to the GM one that I've been running for a while. Haven't had any issues and am consistently charging ~14.3- 14.6v
  4. Jan 13, 2022 at 1:03 PM
    outdoorgb
    outdoorgb (.)(.)
    Burbs of Oregon
    2014 DCSB TRD Sport Silver Sky...
    Same here but add 10 years... love the results
    LB9[QUOTED], 10thMTNgrunt and irayfz6 like this.
  5. Jan 13, 2022 at 1:13 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    So if y’all are following me here, don’t expect you too, lol, after I had my truck rust proofed by Krown I went ahead and purchased all the components Toyota uses to plug the frame after they do their rust proof treatment (couldn’t afford Toyota’s treatment $1000.00 price) and will have a Toyota technician install the many frame plugs in the near future. My frame is still oozing with the fluid film that Krown uses so it’s the perfect time to entomb my frame so to speak.
    see parts numbers and prices down below, the plugging job (that’s what she said:eek:) is running me $200.00.
    I missed the service deadline so I’ll bite the bullet on this one as long as my lil Darlin benifits:thumbsup:3E14CCC0-3A7B-4350-97FE-2801CF3643B1.jpg
    srspicer and DG92071 like this.
  6. Jan 13, 2022 at 1:38 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    155K mile service:
    Engine Oil & Filter
    Engine & Cabin Air Filters
    Lubed Drive Shafts (5) - Mobil 1 Red Grease
    Sprayed/Treated a few other areas...like the steering shaft joint.
    Filling up later and adding the Techron - have a highway drive in the morning.
    Still need to get the tires rotated - I don't have the tools for that.
  7. Jan 13, 2022 at 2:08 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
  8. Jan 13, 2022 at 2:55 PM
    Gruber1922
    Gruber1922 Well-Known Member
    Tacoma, WA
    2015 Tacoma Sport
    Finally installed my plug and play back up camera relocation. It's a little low but worksF94B8E19-ABAA-4757-B612-05B3B3D3AC79.jpg DBF1625E-AECA-4BFE-BBAD-64E8F8B63DAC.jpg 63316B2A-D467-4344-A883-92951D1E7957.jpg
  9. Jan 13, 2022 at 2:59 PM
    Kyle14Taco
    Kyle14Taco Winter Soldier
    Kyle
    2014 Tacoma SR5 4X4
    3 inch lift
    I ordered the Black Rhino Glamis wheels for my Taco today….. and got my haircut. So overall a great day today!
    DG92071 likes this.
  10. Jan 13, 2022 at 3:25 PM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
  11. Jan 13, 2022 at 3:39 PM
    Flo_TRD07
    Flo_TRD07 Well-Known Member
    Ben
    2007 Tacoma TRD Sport Prerunner
    Truck things
    Installed new head lights and drained/ changed my rear diff fluid. I used Castro 80w-90 Limited Slip oil. Should I go back and add the LSD oil (I guess it’s a friction modifier)? Or will the oil I bought suffice? Couldn’t find much on that…image.jpg
    irayfz6 likes this.
  12. Jan 13, 2022 at 4:01 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I'm tired, I had to read that three times before I realized you didn't say "I installed new headlights and filled them with 80w-90 diff fluid."
  13. Jan 13, 2022 at 4:02 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    20220113_172725.jpgexcuse the mess but finally did the black interior conversion however I have to redo the dash because some dummy forgot to plug in the 4x4 switch :annoyed:
  14. Jan 13, 2022 at 4:13 PM
    Kyle14Taco
    Kyle
    2014 Tacoma SR5 4X4
    3 inch lift
    Where did you get the black conversion from?
  15. Jan 13, 2022 at 4:37 PM
    brian.gonz
    Brian
    Manor, Texas
    They're all oem parts there's a post out there with the part numbers, I'll link it when I find it. It's a bit pricy but we'll worth the look and not having to worry about scratching off black paint.
  16. Jan 13, 2022 at 4:40 PM
    brian.gonz
    Brian
    Manor, Texas
    DG92071 and Kyle14Taco[QUOTED] like this.
  17. Jan 13, 2022 at 4:41 PM
    Kyle14Taco
    Kyle
    2014 Tacoma SR5 4X4
    3 inch lift
    Yeah your photo looks great, I'll search around for the thread as well. Definitely be alot better in black and worth the price.
  18. Jan 13, 2022 at 4:56 PM
    super_white
    Harry
    Connecticut
    2012 Tacoma 4X4
  19. Jan 13, 2022 at 4:56 PM
    Flo_TRD07
    Ben
    Truck things
    It helps the lights shine further:D
    DG92071 likes this.
  20. Jan 13, 2022 at 5:53 PM
    DG92071
    DG92071 Well-Known Member
    I'm not familiar with the oil you mentioned but it sounds like the LSD additive is already in that oil.
    Flo_TRD07[QUOTED] likes this.
