  1. Jan 15, 2022 at 6:48 PM
    DG92071
    DG92071 Well-Known Member
    I can't stand this cold weather. Absolutely miserable. It's 6:50 PM in January by the way. 20220115_184541.jpg
    Oh and 619!!!
    theolee likes this.
  2. Jan 15, 2022 at 7:27 PM
    Audi403
    Audi403 Well-Known Member
    2015 Tacoma TRD Sport
    Made a bit of a push today on the retrofit job. I didn't realized I'd have to cut the Panamera shrouds to fit the Mini D2S 5.0 projectors. A dremel and palm sander came in handy. Just took bit by bit off...lots of test fitting. Now that I know the dimensions the other side should be easy. I got the fitment pretty dialed in now!
    Next I'll drill the shrouds and reflector bowls to run the halo wires. At that point the parts will be ready for paint. I'm dropping them off for a professional paint job. Then half assemble, test fit on the truck to check the cutoff is level, tighten everything down, remove from truck, full assembly, then final install.
    Anyone thinking about taking on a retrofit job, unless you have a ton of free time I definitely wouldn't recommend it. It's a ton of work. I would have rather paid someone lol. The end product is going to be very rewarding.
    DRMetz, lo2hi, T.Barn and 2 others like this.
  3. Jan 15, 2022 at 8:15 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Shorts and a t-shirt! Long sleeves are for the fifties.
    DG92071[QUOTED] likes this.
  4. Jan 15, 2022 at 9:54 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Finally finished installing my 4x Innovations bolt on sliders and applied the annual Woolwax treatment to fight road salt corrosion.
  5. Jan 15, 2022 at 10:38 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    I did my mini h1s in about a week in spare time. Granted, they don't require as much work as the d2s, but I still think people can tackle it. I want to do d2s next
  6. Jan 15, 2022 at 10:46 PM
    Cleatus
    Cleatus Well-Known Member
    SoCal
    2015 DCSB OR 6spd
    2” or so lift
    Well, the 805 is pretty chilly also! I actually put shoes on today, still had shorts and t-shirt on though. If it gets any colder I might have to wear a long sleeve t-shirt, damn this weather
  7. Jan 16, 2022 at 5:06 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    I built a retrofit using the 5.0’s a couple of years ago and definitely agree. Very time consuming, tedious, detailed work BUT.. when it’s done it’s very rewarding.
  8. Jan 16, 2022 at 7:09 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    Headlight restore. Been on the list for a couple years now. The $12 Turtle Wax kit does a good job but the "ceramic" wipes always leave streaks.
    Charlie Bravo likes this.
  9. Jan 16, 2022 at 7:12 AM
    flatt-taco15
    flatt-taco15 Well-Known Member
    2015 DCSB TRDOR
    RCI full set steel skid plates 4x Innovations Sliders Rough Country 2" front spacer 1" rear steel block spacer Bird Dawg TechDeck
    A little bit of dryrot repair lumber for the upcoming re-roof.
  10. Jan 16, 2022 at 7:15 AM
    GorgeRunner
    2005 PreRunner
    Tightening the gas cap to get rid of a CEL also ranks high for maximum effeciency repair and modification.
  11. Jan 16, 2022 at 7:50 AM
    Audi403
    It all depends how much free time you have and whether you want to spend it working on headlights. I have gone all out on these. I bought a scuffing paste for plastic and some fine grit scotch pads (grey). I sanded everything down to a matte finish to prep it for the body shop to paint. I did my BHLM with spray cans and it just doesn't matter how good you are with a can, the end result just can't match a professional paint job. With all the hours I'm spending on this I figured I better not take any shortcuts. Can't wait until they're done! How long have you had the mini H1's? No issues since the install?
    The only part I'm not looking forward to is test fitting them on the truck to check the horizontal level (rotational alignment). I had a hell of a time getting my headlights on and off the truck for the BHLM. When you test fit your lights, did you leave the front cover/lens off the housing? I'm wondering if that would make it easier to get in and out. I'm thinking of maybe just taping some bubble wrap over the front of the housing to protect the inside of the shroud/reflector bowl/projector from scratching when I test fit it. Curious what others have done.
    I can't wait to get them all wrapped up. How have yours been holding up? Did you test mount your lights on your truck to set the rotational alignment on the projector to get a level cutoff? What was your method for this?
  12. Jan 16, 2022 at 9:01 AM
    2013TacoDCLB
    2013TacoDCLB Well-Known Member
    Mark
    2013DCLB4x4
    Military hitch, CB install, cargo rail brackets
    I ordered some sun visor organizers.
  13. Jan 16, 2022 at 9:08 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Did some browsing on the internet trying to find a part number for the "wiring harness clamp" that I removed prior to adding wires for accessories.
    Ordering them tomorrow along with some other small parts.
  14. Jan 16, 2022 at 11:12 AM
    GorgeRunner
    2005 PreRunner
    My visors need to hit the gym. They're weak.
  15. Jan 16, 2022 at 12:49 PM
    ty.s07
    Alabama
    Absolutely, honestly that’s probably the most time consuming part. I left the lens off each headlight, had the 5.0’s relatively tight, would throw both headlights in the truck and set the rotational alignment. After I got it close I put the torque to the mounting nut on the 5.0’s and double checked / adjusted the rotational alignment again. Edit - I only installed the top two mounting bolts for each headlight (I didn’t touch the bottom two) for this process. I had the grill out of the truck at the time too. I was only concerned with the rotational alignment. After everything was buttoned up I set the height and all that.
    Mine have been solid so far, light output was night and day (no pun intended) the 5.0’s beam is super wide and the cut off is crispy!
    I worked on mine a few hours a day until all the paint dried then basically worked for a solid 8-10 hours getting everything mounted, the halos mounted, everything wired, adjusted and lens back on. Basically the final push. Well worth it but definitely time consuming.
    Audi403[QUOTED] likes this.
  16. Jan 16, 2022 at 2:58 PM
    rtilton12
    rtilton12 Get gas and GO!
    Robert
    Texas
    2012 Toyota Tacoma TRD Off Road 4x4
    Trail gear front and rear bumper, RTT, hitch grill, 12k lb winch, drilled and slotted front brakes
    went mudding today and had a blast. battery light popped on after going through semi deep area. washed the battery, cables and alternator off pretty good with a hose and light is still on. drove her home 30 miles with all accessories off. gonna take her to toyota in the am
  17. Jan 16, 2022 at 4:14 PM
    bprout
    bprout Well-Known Member
    Brian
    SoCal
    2014 SR5 4x4
    Runs off Hopes and Dreams
    What reloacation did you use? I think we have the same rear bumper and have been looking to do this for a while...
  18. Jan 16, 2022 at 6:37 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    All of the fluid is going to leak out of your fog lights, they are in upside down!!:facepalm:
    theolee likes this.
  19. Jan 16, 2022 at 9:45 PM
    Evergreen_Offroad
    Evergreen_Offroad Well-Known Member
    Andrew
    2009 Tacoma TRD Offroad Access Cab
    35s, armor, mid travel etc.
    Got my inner tie rod heims in finally, now just to figure outa boot situation...
    Also strapped me spare down.
  20. Jan 16, 2022 at 9:49 PM
    Cleatus
    SoCal
    2015 DCSB OR 6spd
    2” or so lift
    Looks good! What rack are you running and how close is the tie rod to the coil?
