  1. Jan 27, 2022 at 3:30 PM
    the_black_tacoma
    the_black_tacoma Well-Known Member
    Griffin
    IN
    2008 Black Tacoma SR5 AC
    A couple
    This was yesterday, but got the truck back from having my powdercoated 600lb coils installed, gained 3/4” of height and a much better ride over my too-stiff 700lb coils.
  2. Jan 27, 2022 at 3:46 PM
    Diabl0
    Diabl0 2005 TRD Off Road DC SR5
    Tim
    Massachusetts
    2005 TRD off Road DC SR5
    AUCar Android Stereo Bluetooth Katskin Leather Soft Bed Cover Dual kicker comp s10’s Bull bar Euro headlights Black grill Clutch bypass switch Alpine 6.5 and 6x9 speakers Kicker Subaru Tweeters Diamond floor mats Dick Cepek DC2 Wheels Toyo Open Country ATII Tires Black Aftermarket Grill Rhino lined Tube Side Steps Back up Camera
    Shit that’s close! Thank god for the dash cam.
    Atomic47 and YotaProject like this.
  3. Jan 27, 2022 at 3:47 PM
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    What springs did you go with?
  4. Jan 27, 2022 at 3:49 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    My heart rate was jacked! I thought I was going to T-Bone this halfwit for sure.
  5. Jan 27, 2022 at 4:01 PM
    Diabl0
    Tim
    Massachusetts
    I bet at least you have the video to show this crazy person
    Atomic47 likes this.
  6. Jan 27, 2022 at 4:05 PM
    10thMTNgrunt
    2013 TRD Sport
    They left the scene. I pulled over because I was certain I clipped him. Turns out I didn’t. They sped off before I even got out of the vehicle to check. A witness sped after them to grab their plates for me ( they’re are still good people in this world!), fortunately there was no collision. Just a cool video and one more reason all of you should get a dash cam.
  7. Jan 27, 2022 at 4:05 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I painted and installed a skewp hood.
  8. Jan 27, 2022 at 4:06 PM
    Diabl0
    Tim
    Massachusetts
    Which cam do you have?
  9. Jan 27, 2022 at 4:09 PM
    10thMTNgrunt
    2013 TRD Sport
    Blackvue, front and rear.
    theolee likes this.
  10. Jan 27, 2022 at 4:17 PM
    Bowjumper
    Bowjumper Well-Known Member
    2023 TRD Sport
    1. Weather Techs of course
    2. Replaced the passenger mirror that was FUBAR
    3. Brought it home from the Dent Doctor! Now it just needs a good buffing
    4. Painted under the front so I don’t have to see rust 75349F0B-BCC6-4608-AE41-50D3A3F465FD.jpgA1F17853-7915-4B95-917C-654CDC9AC43E.jpgF074415C-A67E-4C97-9290-C6B1AFE647B8.jpg
    dpele, AStinkyBumb and loyaltothetaco like this.
  11. Jan 27, 2022 at 7:03 PM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    I did about a 2.5" lift which created a takeoff vibration. I shimmed the rear axle and added a hanger spacer. No change. I finally got rid of my entire two-piece prop shaft and replaced it with a Tom Wood's (https://4xshaft.com) driveshaft and it's been silky smooth ever since!!
  12. Jan 27, 2022 at 7:17 PM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    I was wanting to do the 5100 and OME route for a max a 2" lift perhaps 1.5". I have looked up those items but recently stumbled on the possibility of vibration with the drive shaft being off. My ability for the DIY stuff is limited by my space and not level gravel driveway. If I paid a shop to upgrade the suspension would they make sure all that stuff is square?
  13. Jan 27, 2022 at 8:05 PM
    donpapadaupolis
    donpapadaupolis Well-Known Member
    2015 DCSB 4x4
    Lights look great. My next purchase will be a set of these for my 2015.
    dpele[QUOTED] likes this.
  14. Jan 27, 2022 at 8:16 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Most shops will install what you ask them to and send you on your way. They’ll do a test drive to make sure everything works as it should but they’re not gonna scrutinize it for minor vibes.
    case in point this dumpster fire:
    https://www.tacomaworld.com/threads/cause-of-vibration-after-6-lift-install.752996/
  15. Jan 27, 2022 at 9:00 PM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    Did you not want to use a diode like this and get a similar result for 1/10 the price?
    See below:
    theolee and T.Barn like this.
  16. Jan 28, 2022 at 12:28 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    No I did not.
    I was well aware of the ford diode method but still chose the HKB for a few reasons.
    This was purpose built vs a diode that may or may not handle the load and could fail and leave you stranded and this still can act like a fuse.
    I wanted the adjustability in case I ever have to use a different battery.
    Tinkering with my truck is a hobby and being able to dial in tighter voltages and have more control is something I liked.
    I'm just extra.
    :p
  17. Jan 28, 2022 at 3:31 AM
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    Nothing exciting just some routine maintenance on tap for today.
    Oil and filter change /Castrol synthetic and OEM Filter
    OEM Brake Pads
    Denso Spark Plugs
  18. Jan 28, 2022 at 4:02 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    If you plan to lift I would buy the carrier bearing drop kit (its like $20), ECGS bearing replacement (also locate the tools), and a digital angle gauge. There are a few threads on tacomaworld on how to measure drive line angle before and after lift. Best approach is to measure drive line angles and write everything down then do the ECGS bearing no matter what and install the lift. THEN after the lift is installed drive it around, get it aligned and let the new suspension settle a bit. If during that time you notice driveline vibration at take off, which is where most people feel it, then get under the truck and measure drive line angles again and go from there. Some trucks show the vibration at take off but not all. I measured mine before and after then installed the carrier bearing drop and my angles were fairly close to pre lift angles so I didn't do shims. Also post up in any Maryland threads there might be some TW members around you willing to lend a hand who might have done this before as well.
    Angle Gauge
    https://www.amazon.com/gp/product/B07ZWW3BW5?ie=UTF8
  19. Jan 28, 2022 at 6:49 AM
    Taconest
    Taconest Well-Known Member
    Boise, ID
    06 Tacoma DCLB 4X4 V6 4.0L
    Bilstein 5100/ Dirt King UCA/ OME 886 Fronts, Fox 2.5 DSC/ HD Dakkars, 4.88 Gears, Eaton Rear Locker, 33" Ridge Grapplers, ARB Front Bumper, Fab Fours Rear Bumper, DIY Roof Rack, Wildernest Topper, Wood Stove, Snorkel
    I have been wanting to do this, but have put it off due to not knowing exactly what lb rating to get as I couldn't seem to find what the Redline Kits were. When I looked at the link you provided I found they cant be shipped to Idaho, but then found these that appear to be the same, are cheaper, and have a few other lb ratings. I might try the 60lb's just so in the winter they don't get weak and overtime drop the hood on my nogin.
    https://www.amazon.com/C16-08316-Su...box+lid,+set+of+2+vepagoo,aps,111&sr=8-3&th=1
  20. Jan 28, 2022 at 6:55 AM
    plurpimpin
    PDX
    I looked into those but didn’t love the fact that you’re removing the fuse from the system with the ford diode.
    I’m running the fixed voltage mini blade version which is much cheaper than the adjustable version. The peace of mind from maintaining the fuse was worth $50 to me.
    GARSHA91[QUOTED] and DG92071 like this.
