  1. Jan 28, 2022 at 7:02 AM
    dpele
    dpele Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    Well I'm sure there are way more options on Amazon .com than .ca!
    The weight rating of the struts are per strut (from what I understand). So I had a capability to lift 200lbs and now it will be 80lbs. The hood is pretty heavy but not 80lbs heavy. Even with wet snow on it lol
    I'm sure the 60lbs struts will be fine!
    I will see how the new ones perform in the winter.
  2. Jan 28, 2022 at 7:10 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    What kind of mirror did you get? OEM?
    My passenger mirror glass has been cracking more and more for the last 2 years.
    I bought a replacement lens and went to replace it and the mirror assembly is aftermarket. The lenses are not replaceable on aftermarket ones I guess.
    I should have checked before buying the new lens... I always noticed that the mirror looked different than the other one. Damn!
  3. Jan 28, 2022 at 7:11 AM
    Taconest
    Taconest Well-Known Member
    Boise, ID
    06 Tacoma DCLB 4X4 V6 4.0L
    Bilstein 5100/ Dirt King UCA/ OME 886 Fronts, Fox 2.5 DSC/ HD Dakkars, 4.88 Gears, Eaton Rear Locker, 33" Ridge Grapplers, ARB Front Bumper, Fab Fours Rear Bumper, DIY Roof Rack, Wildernest Topper, Wood Stove, Snorkel
    Haha yep, didn't catch the .ca part. No wonder they didn't want to ship them to me!
    dpele[QUOTED] likes this.
  4. Jan 28, 2022 at 7:33 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    @dpele
    This post deserves a dedicated thread so the information and responses can be targeted to this topic. Responses will get lost in this thread. Nice work!
  5. Jan 28, 2022 at 7:41 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    ACEkraut[QUOTED] likes this.
  6. Jan 28, 2022 at 8:01 AM
    Sonofliberty92
    Sonofliberty92 T O Y O T A
    Mark
    Maryland 4 South
    2014 DCSB TRD OR, 2005 Tundra V8 4WD
    Ok, I appreciate the info. I still have some time before I get up the money for it so I have plenty of time to source help and buy those items.
    Thanks again
  7. Jan 28, 2022 at 8:08 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    definitely do your research on your lift too cause it will probably change 8 times. Cant go wrong with a 5100/OME pairing up front I think it rides better than stock.
  8. Jan 28, 2022 at 8:14 AM
    DG92071
    DG92071 Well-Known Member
    That's going to rub... really badly.
    Taconest and Jsmoore679[QUOTED] like this.
  9. Jan 28, 2022 at 8:57 AM
    shaun08taco
    shaun08taco Active Member
    Shaun
    2012 TRD Baja TX 4x4
    It’s just a cheap light strip I got off Amazon and hooked up to a switch that goes to my auxiliary battery. Here is the link: https://amzn.to/3HeWqeQ
  10. Jan 28, 2022 at 9:04 AM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Not sure if this info helps in this situation, but I had a mirror lense break one time and I broke the rest of the pieces out and made a template out of cardboard that I took to a local glass and mirror shop and they cut a new lense for me the exact shape I needed. I just put it in with some 3M double-sided tape and was good to go. It was fairly cheap. If your new lense needs to be re-shaped to fit, that might be an option to consider.
    Taconest and dpele[QUOTED] like this.
  11. Jan 28, 2022 at 9:12 AM
    ACEkraut
    Aaron
    Durham, Maine
  12. Jan 28, 2022 at 9:18 AM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    Just a heads up 5100's set on 0" with OME 883's will net you a 1" lift in the front. Pair that with a Wheelers Offroad AAL (remove your overload leaf) will net you 1.5" in the rear. This is the route I went because I wanted a small lift. No vibrations that I can tell of and still retains the perfect OEM rake look.
    Edited: I also have the OME carrier bearing spacer kit as someone mentioned above.
    tacomamma and GRNT4R like this.
  13. Jan 28, 2022 at 9:41 AM
    JimIowa
    JimIowa Well-Known Member
    Jim
    Des Moines, Iowa
    2015 TRD OR DCSB
    "Park Avenue" ACDF horns
    I would have pulled over to let my heart rate come down. Boy that was close. Kudos to you for actually paying attention to the task at hand (ie. driving).
    Northbound_Taco likes this.
  14. Jan 28, 2022 at 10:32 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Thanks, and pulled over for that reason too, heart was on the windshield.
    JimIowa[QUOTED] likes this.
  15. Jan 28, 2022 at 10:36 AM
    dpele
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    The OEM mirror lenses can be replaced very easily. Just tilt the mirror all the way up, slide a flat head screw driver in the back, twist the screw driver to pop the lens out. Done.
    The aftermarket assembly seem to have the mirror screwed in from the back somehow. It's a totally different style and manufactured differently.
    I don't think your method would help me.
    A new replacement lens is only $30 aftermarket ($70 OEM), and a new aftermarket assembly is $60-$100 ($185 OEM). All CAD$.
  16. Jan 28, 2022 at 10:38 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I wish someone made 305 75 17 tires.
    theolee likes this.
  17. Jan 28, 2022 at 10:47 AM
    ExcitedRaccoon74
    ExcitedRaccoon74 Member
    Hunter
    2015 TRD Sport DCLB
    Recently put 3rd gen suspension on and just yesterday upgraded to a set of the TRD Pro Wheels.
  18. Jan 28, 2022 at 10:49 AM
    andyzx6r
    andyzx6r Well-Known Member
    Atlanta
    Super White TRD Sport
    What type of headlights are those? They look great.
  19. Jan 28, 2022 at 11:51 AM
    milescf
    milescf Well-Known Member
    Oklahoma City
    ‘08 DCLB Sport; Sold ‘17 TRDOR MT ; sold ‘02 Black Prerunner
    3rd Gen OR suspension, wheels and tires all 4 corners.
    Nice! Mine is sitting the same, 3rd gen springs and shocks all around, and OR wheels. That’s a sharp truck!
  20. Jan 28, 2022 at 11:53 AM
    milescf
    Oklahoma City
    Oil change, other routine maintenance, new pads and shoes with resurfaced discs/drums, and a much-needed bath!!!!
