  1. Feb 23, 2022 at 9:53 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    That makes sense! I think I have that same thing going on but then the brake light is in the tail light.
    kgarrett11 likes this.
  2. Feb 23, 2022 at 10:06 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    Yeah I think it was for a dome too. I couldnt tell if it was a dome light or just the backing to the 3rd brake light. I didnt see anything else so it must be it
  3. Feb 23, 2022 at 10:15 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    Some pics would be great!
  4. Feb 23, 2022 at 3:00 PM
    Taconest
    Taconest Well-Known Member
    Boise, ID
    06 Tacoma DCLB 4X4 V6 4.0L
    Bilstein 5100/ Dirt King UCA/ OME 886 Fronts, Fox 2.5 DSC/ HD Dakkars, 4.88 Gears, Eaton Rear Locker, 33" Ridge Grapplers, ARB Front Bumper, Fab Fours Rear Bumper, DIY Roof Rack, Wildernest Topper, Wood Stove, Snorkel
    What is the black plastic tubing called you use to contain your wires? I always see it on factory stuff but have never seen it on a shelf to know what it is called haha. I always just end up using a ton of split loom but it looks bulky and junky.
  5. Feb 23, 2022 at 3:07 PM
    ayshiri
    ayshiri Well-Known Member
    2011 Toyota Tacoma TRD Sport 4x4
    Finally got around to installing my Scosche wireless phone charger. Works great! Purchased from Amazon.
  6. Feb 23, 2022 at 3:21 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    After painting st whl ornament bezels and putting back together and programming radio and turning off seat belt beeper, went to drive it to work next morning and the dang horn was going off by itself after a coupla blocks so took it back home and drove the xB......turns out the freakin spring loaded bolts holding the airbag to the mounting frame that works horn when you push on it and bolts into st whl were loose and it was touching on it's own when turning the wheel. new one for sure. tightened them up, put wheel back together and went for test spin and all is good. just glad it was that simple because I was at a loss for a minute trying to figure it out.
    spencermarkd likes this.
  7. Feb 23, 2022 at 3:59 PM
    Big Q-Dog
    Big Q-Dog Member
    Bryan
    2009 Green Double Cab
    Pretty much stock, but making it my own
    Drove home from work in an ice storm and pulled a Colorado out of the ditch! Dumb kids.
    Charlie Bravo, lynyrd3, EMR and 3 others like this.
  8. Feb 23, 2022 at 5:32 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Hope it works better than the stock one my 3rd gen Sport had. If the phone slid 1/4 inch the charger stopped charging. Was the biggest pain finding a sweet spot for charging. Ended up just using the usb cord in that one.
  9. Feb 23, 2022 at 5:35 PM
    JerWayne'sTaco
    JerWayne'sTaco New Member
    Jerry
    2014 MGM Crew Cab Long Bed
    I replace the burned out bulb in my shifter. $6 from the dealer. Easier fix than I thought...
  10. Feb 23, 2022 at 6:27 PM
    ayshiri
    Bummer man. This one has three tabs that hold the phone in place. Its just big enough to hold my iPhone 12 Pro Max with a fairly slim case, but anything bigger would not fit within the tabs. So far so good. I drove around, the combo of the magnet and the tabs hold it in place pretty well.
  11. Feb 23, 2022 at 6:30 PM
    ayshiri
    I have a pop and lock on my tailgate and it works great - Its been on there for quite some time and I've never had issues with it. One of the best add ons on my truck actually.
  12. Feb 23, 2022 at 8:12 PM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    remember which one you have specifically?
  13. Feb 23, 2022 at 8:34 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Heat shrink tubing :notsure:
  14. Feb 23, 2022 at 8:38 PM
    Jimmy92870
    Jimmy92870 Well-Known Member
    Texas (DFW)
    07 DCSB PreRunner
    Possibly loom?
  15. Feb 23, 2022 at 8:56 PM
    gotblika
    gotblika Well-Known Member
    Maui
    2015 DCLB Sport 4X4
    5100'S 887 SPC B110 EL096R
    super_white[QUOTED] likes this.
  16. Feb 23, 2022 at 9:08 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  17. Feb 23, 2022 at 11:35 PM
    DG92071
    DG92071 Well-Known Member
    That is vynl tubing.
  18. Feb 24, 2022 at 3:14 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    This stuff I found on Amazon: https://www.amazon.com/dp/B091B37LRR?ref=ppx_yo2_dt_b_product_details
    It's flexible like shown in the picture where it is rolled up. I had some other stuff from Amazon that was too stiff and threw it away.
    So far I found three different ID's that should cover most jobs.
    la0d0g likes this.
  19. Feb 24, 2022 at 3:49 AM
    Tromezze
    Tromezze Active Member
    Antonio
    Arizona
    2011 Toyota Tacoma TX-PRO 6MT
    Went ahead and installed Alpharexx LUXX headlights and Morimoto fog lights on her. Way better visibility
  20. Feb 24, 2022 at 4:10 AM
    ayshiri
