  1. Oct 23, 2012 at 10:39 AM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    stuff and more stuff
    Yes sir, and also prepping for 36's I'll eventually get after I redo my front end
  2. Oct 23, 2012 at 10:51 AM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
    Since my truck is half way around the world at home, I did some research... And figured out parts and locations for my OBA system and various other little tinkering I want to do when I get home in two weeks.... I sure miss my baby..
  3. Oct 23, 2012 at 12:33 PM
    SinghSingh
    SinghSingh Active Member
    San Diego
    2011 DC SB Prerunner
    I went down to Discount Tire in SoCal and had them put on a new set of MB TKO using my stock tires - no lift, no leveling kit. $550 OTD with a TPMS rebuild kit and new lugs.
    It's funny how a simple cosmetic change can so totally alter my perception of my Taco. I'm in love all over again :)
    What should I do with the stock rims? They only have 15K on 'em and nobody on CL has shown interest. DT said they'd recycle them for 10 bucks.
  4. Oct 23, 2012 at 12:37 PM
    Failure2Comply
    Failure2Comply Old HVACR Tech
    Virginia, USA
    05 Access Off Road TRD/SR5
    My Weatertech DigiFit floor mats came today. Now I just need some Wet Okole seat covers.
  5. Oct 23, 2012 at 1:15 PM
    Oury
    Oury Texas Taco
    Oury
    Austin, Tx
    07 TRD Offroad
    Sell them on here, lots of ppl looking for exact spares...... $70 a wheel is a good deal
  6. Oct 23, 2012 at 1:35 PM
    bfogelma
    bfogelma Well-Known Member
    Brandon
    Bend, OR
    2011 DCSB
    Headlights look awesome! Do you have any pics of the retrofit process on these new headlights?
  7. Oct 23, 2012 at 1:40 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    Thanks! I didn't really take any during the process. Just a couple of the projectors mounted without the shrouds on. They are in the round 10 group buy thread. The process is really the same as the other threads on here, which is what I went by when doing the retrofit.
  8. Oct 23, 2012 at 1:47 PM
    REDTRD
    REDTRD Woods & Water Edition
    Anthony
    Western NC
    07 DCSB SR5 4x4
    Click my build thread!
    Retro's lookin good Brian! :cool: I'm still loving mine!
  9. Oct 23, 2012 at 1:50 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    Some new Shoes! Bronze TRD Beadlocks on new BF Rugged Terrains
  10. Oct 23, 2012 at 3:21 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Thanks Anthony! I'm still tweaking it a bit, but it's pretty close. Heading out there now to fix my rotating bulb and figure out how I want to seal around the bulb base where the cut rubber boot doesn't quite cover.
  11. Oct 23, 2012 at 3:34 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    So was it easy on the 2012/2013 headlights? I hear there is some modding that needs to be done to the projector on the newer lights.
  12. Oct 23, 2012 at 4:17 PM
    theocean
    theocean Well-Known Member
    San Diego
    13 DCSB TRD OR 4X4
    Eibach 1.6", 5100s at 0, Ride Rites, Daystar Cradles, Koing Contersteer Offroads, 265/75/16 Wrangler Duratracs
    Installed my Wet Okole seat covers this afternoon. Black & Charcoal with half piping + TRD Offroad logo.
  13. Oct 23, 2012 at 4:44 PM
    Dan44
    Dan44 Well-Known Member
    012 Tacoma 4X4
    Ordered a bed mat from Camelback Toyota Parts.
  14. Oct 23, 2012 at 4:52 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Washed it this morning then drove it to meet my wife for lunch.
  15. Oct 23, 2012 at 5:19 PM
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    The only real issue is with the alignment ring. There is a 3 notch ring that keeps the projector level in the housing. For some reason, toyota decided to change the location of the notches with the newer housings, so the ring included with the kit does not work correctly out of the box. So with that said, you will need to modify that ring in order to have the projector sit level. It's a matter of using something like a grinding stone on a dremel to file down the 3 notches so they can rotate counterclockwise in order to level the lights. By grinding this down, you will have some play in the space the ring fits into. What I did was use jb weld steel putty (great stuff) to secure the ring in place. I will say that mine aren't perfect, but pretty close. I am off by a couple degree's, but that is my fault for not testing them before securing them in place. I just eyeballed it and got close, but not quite perfect. I'll probably tear them back apart at some point and adjust. Now that I've done it once, I can have the grill off and the lights out in under 10 minutes.
  16. Oct 23, 2012 at 6:51 PM
    bulhas
    bulhas the habs fan
    Joe
    Edmonton, Alberta
    1997 Rexus
    LS Swap 500 hp......
    ordered a shackle flip today :D MOAR rear flex :D
  17. Oct 23, 2012 at 7:04 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    Looks good.
  18. Oct 23, 2012 at 9:50 PM
    Shaggs
    Shaggs Well-Known Member
    NorCal
    2012 DoubleCab Long Bed 4x4 TRD Magnetic Gray
    Headlights look awesome... I REALLY need to do that mod
  19. Oct 23, 2012 at 9:50 PM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I was leaving a bookstore and started the truck, and noticed that it lurched forward while still in park. Thought that was strange, but not enough for me to get out. When I put it in reverse, I checked my side mirror and noticed that a very old woman had just backed into me.
  20. Oct 23, 2012 at 9:55 PM
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    Just picked up the truck from getting OME lift, dakars, light racing uca's and custom tube front bumper installed. Pics will be up tomorrow, it's looking beastly now. Ready to roll up to work tomorrow morning like a boss. :cool:
