  1. Mar 21, 2022 at 4:55 AM
    AStinkyBumb
    AStinkyBumb Well-Known Member
    Indiana
    2013 DCLB SR5 4x4
    Since I started wheeling my truck I began to gather quite a few things behind the rear seat and on the floorboards in the rear. Straps, tools, recovery gear, spare parts. My double cab was essentially an access cab and I wanted to use my rear seat like it was designed to be use. To haul people. So I initially bought a plastic tub to put my gear in and strapped it to the bed with a ratchet strap which worked for what I needed but gave me worries that someone would remove the strap and walk off with a very expensive yet heavy box of all my stuff. So I started researching toolboxes. I didn't initially want a toolbox but figured if I was going to have a tub in the bed full time might as well bite the bullet and make it a little more secure. I wanted something that sat down inside the bed and not on the bed rails so I could continue to use my softopper and bed rack. So I picked up this cheap Trinity 36" job box and painfully drilled a few holes in my bed and secured it using some stainless steel hardware. Its offset to the passenger side to 1) offset the weight of taco lean and 2) so I can mount a jerry can to the extra space next to it to utilize space as much as possible. Looks a little funny but function > form. While I was drilling holes I also put in a center D ring so I can move my spare into the bed when I wheel so its easier to access and I dont have to deal with being under the truck in the mud. End goal is to eventually mount the traction boards to the front of the box as well.
    signal-2022-03-20-15-45-11-184 - Copy.jpg 20220320_125119 - Copy.jpg 20220320_174921 - Copy.jpg 20220320_172314 - Copy.jpg
  2. Mar 21, 2022 at 5:15 AM
    guyfromky
    guyfromky Well-Known Member
    I really like your tail lights
  3. Mar 21, 2022 at 5:21 AM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    Those were from Amazon and have done really well. No leaks or fogging. First set came with a corner chipped off. Amazon return and replacement set came quickly. This set has been on for over a year living outside in Florida heat and humidity, soaked in water and mud without a problem.
    ACANII - For Black Smoked 2005-2015 Toyota Tacoma LED Tube Tail Lights Lamps Left+Right $176
    DG92071 likes this.
  4. Mar 21, 2022 at 5:50 AM
    BoostedNerd
    BoostedNerd Well-Known Member
    Nicholas
    2007 Red Tacoma
    Finally installed my radio unit and my backup camera. It's been nice to use over the stock unit. Still debating if I want to keep the lines on the backup camera.
    DG92071, irayfz6 and loyaltothetaco like this.
  5. Mar 21, 2022 at 5:52 AM
    RedWings89
    RedWings89 Well-Known Member
    Luke
    SE Virginia
    2014 SR5 DCLB
    I will be. I don’t have a Lexus dealer anywhere close so unless they carry it at the local Toyota dealer I’ll have to get it online.
    10thMTNgrunt[QUOTED] likes this.
  6. Mar 21, 2022 at 6:04 AM
    flatt-taco15
    flatt-taco15 Well-Known Member
    2015 DCSB TRDOR
    RCI full set steel skid plates 4x Innovations Sliders Rough Country 2" front spacer 1" rear steel block spacer Bird Dawg TechDeck
    Nice! Do you think this is more secure than a standard truck bed box that site on the frame rails? What do the locking tabs looks like?
  7. Mar 21, 2022 at 6:15 AM
    AStinkyBumb
    Indiana
    2013 DCLB SR5 4x4
    I don't know if its more secure than the classic truck bed tool boxes that sit on the frame rails, I have never had one. Most of those that I looked at were aluminum and used J hooks to tie into the bed rails. This box is all steel so its about double the weight 60lbs (aluminum tool boxes were around 35lbs from the ones I looked at) The aluminum tool boxes were double the price of what I got this one for about the same size. The truck bed boxes use those locking handles with the lock built in. This box is just 2 tabs that slide into those square holes then up under I can slide in a padlock. I put a low profile padlock on both of them so one end cant be pried open with a crow bar on one side.
    deanosaurus likes this.
  8. Mar 21, 2022 at 6:31 AM
    guyfromky
    Thank you!! Any hyperflash issues?
  9. Mar 21, 2022 at 6:55 AM
    Northbound_Taco
    Northbound_Taco Well-Known Member
    Nowhere Fast, Everywhere Eventually
    09 Off road build
    RCI skids/armor, SPC UCA, Fox 2.5 front 2.0 rear 16" TRD PRO rims/ 285/75/16, SS3 Pro fogs, Sherpa Roof Rack
    When I bought my topper rack Sherpa was still a little cheaper but the main reason I went with them is they have better, thicker side rails with built in tie downs and handles that you don't have to pay extra for. They are both great racks, I like the look of a Sherpa rack better. To me Prinsu racks look a little thin and weak, Especially the topper racks. Plus the crew over there are really great and helpful. You can get the wind faring with a cut out from Sherpa also.
  10. Mar 21, 2022 at 7:18 AM
    Bat Trd
    Bat Trd Friendly Neighborhood Batman
    Layne
    Hot Springs, Arkansas
    2014 Tacoma TRDOR DCSB 1D6
    Bruce Wayne taste on an Alfred budget.
    Went on a trail ride this weekend through the Ozarks and hit 100k while in the dirt.
    deanosaurus, MoTacoX, TomTwo and 13 others like this.
  11. Mar 21, 2022 at 7:19 AM
    Northbound_Taco
    09 Off road build
    Made some progress this weekend. I got my interior ripped completely out and got a most of the floor done with the 80 mil before I had to work last night.
    I got work today and the weather is suppose to be nice so as soon as I get home I got to get the rest done and back walls. Then lay the 150 on top of it. It is suppose to be in the 40s for the next week and I don't have a garage to work in so I gotta get it done today or I'm going to be working with a heat gun and in the rain.
    deanosaurus, TomTwo, GRNT4R and 11 others like this.
  12. Mar 21, 2022 at 7:31 AM
    The Wolves
    The Wolves Well-Known Member
    Los Angeles
    2010 DCLB TRD Sport 4x4
    Man I really like that cap. Seems much sturdier than the fiberglass shells.
    TomTwo likes this.
  13. Mar 21, 2022 at 7:46 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    They have done really well for me. Got fairly deep on a steep grade off trail going up, made it out with a camper on the back. Also had this lovely 10hr drive in all conditions including ice. Did not break traction but obviously drove cautiously, also with a camper. Weight helped during the 10h drive, but probably not for the steep drive out in the deeper snow. No pictures of that one. Video was from dash cam on the Million Dollar Highway. Can see the ice reflecting the light from the snowplow. Think only a dedicated winter tire would do better. Just get your air pressures right. Hope that helps.
    Super slick snot snow:
    0EBED167-BDE3-4A4B-909B-8333FFFCDC35.jpg ECC3D147-76AD-4A8B-BB9B-4F49C83E20AE.jpg
  14. Mar 21, 2022 at 8:18 AM
    Hyperbarics
    Hyperbarics Commercial Diver & Taco Driver
    Savannah, GA
    2013 DCSB - Nautical Blue Supremacist
    Well boys- we did it. Id like to thank my fans out there, Japan, my dogs, that dude at the gas station, and God. I couldn't have done it without you.
  15. Mar 21, 2022 at 8:55 AM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Good on you, I’ll be doin the same as well. My front diff bolt stripped as well and the little bastard was a mother to get out. I have a new Toyota bolt in there now but on the next fluid replacement a Lexus one is going in.
    Bu the way, I dig your avatar, it reminds of the self titled Alice In Chains album:headbang:
  16. Mar 21, 2022 at 11:15 AM
    loyaltothetaco
    loyaltothetaco It's part ATV, part SUV, and certified by the DMV
    Adam
    Bay Area
    Radiant Red 2006 DCSB SR5
    2.5" OME lift, Fox 2.5 coil overs, all pro expo leafs, ubolt flip kit w/ upgraded bump stops, 1.25" wheel spacers, 16" Bronze KMC Impact OL wheels, 295/75/r16 Nitto grapplers, beige Softopper, Brute force front bumper w/smittybilt winch, RCI rear bumper, caliraised rock sliders, TRD IFS skid plate custom swingout tailgate w/spare tire mount, TC bed stiffeners, Magnum force CAI, KC spotlights, tacomabeast headlights, rear seat molle panel odds and ends, hi lift, MESO interior lights, and a fuck load of patches… more planned for later.
    Nice setup! Just curious what head unit and backup cam you’re running. Been wanting to buy a new bezel and throw in a touch screen with front and rear dash cams.
  17. Mar 21, 2022 at 12:52 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Has anyone noticed their auto insurance go up lately? Mine is going up $10/mo in April because:
    "inflation factors in used vehicle values, car parts and medical claims and injury lawsuits. Used vehicle values in some areas are up 50% since pre covid."
    I have Farmers and am looking to shop around at this point.
  18. Mar 21, 2022 at 1:14 PM
    TacoTuesday1
    SD CA
    Yeah everything. Unregulated price gouging
    Big Foot likes this.
  19. Mar 21, 2022 at 2:22 PM
    BVita
    BVita Mall Cruiser
    Ended up towing the truck to alignment to prevent scrubbing in the tires after doing some new suspension with @greenEFSI
    A little sorcery with the hardware, cut out the UCA bolt and installing a new OEM bolt/nut after drilling for safety wire backwards to prevent bending the firewall. 12 point hardware with anodized beauty washers for extra bling.
    King 25001-119a
    ARP Hardware With Beauty Washers
    Total Chaos Uniball UCA's
    Custom Dimple Died @TOTAL CHAOS Gusseted Spindles
  20. Mar 21, 2022 at 2:35 PM
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    None. Has been a solid set. One thing I did add were LED reverse light bulbs that made them much brighter. Not that the ones in there were too dim. I just wanted all the lights to LED, and these use your stock reverse bulbs.
