  1. Apr 17, 2022 at 6:02 PM
    GlennHaggis
    GlennHaggis Doesn’t play well with others
    Glenn
    Ormond Beach, FL
    2013 Tacoma Double Cab
    A Bunch
    I was religious about getting the aimed just right to be nice to oncoming traffic. Never get flashed for blinding other vehicles.
  2. Apr 17, 2022 at 6:15 PM
    RegularCab4x4Lover
    RegularCab4x4Lover Member
    JD
    2012 Regular Cab 4x4 Automatic
    4 Trips to the moon, and only that much maintenance? No wonder they got rid of space shuttles….
    CodFather, 3Riverz88, theolee and 5 others like this.
  3. Apr 17, 2022 at 7:18 PM
    96 ToyRunner
    96 ToyRunner Member
    Cole
    Alabama
    2012 Tacoma TX Pro
    TX Pro package , tow bags
    Changed rear differential oil, engine air filter, cabin air filter, and engine oil at 128,541
  4. Apr 17, 2022 at 7:19 PM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    I gust keep hearing The Fall Guy theme music!
    https://youtu.be/yAIDqyi2XsM
  5. Apr 17, 2022 at 7:38 PM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Today I gave the truck a toe alignment. I also mounted the in cab winch rocker switch with a sturdier version that I found off Amazon. My original cut wasn’t the best so this holds the switch better.
    My macs spare tire strap came in so I mounted the spare in the bed with that. Still some adjusting to do to get it even but happy with how sturdy it holds it. The quality of these straps are beyond what I expected.
  6. Apr 17, 2022 at 8:40 PM
    TacoTuesday1
    SD CA
    Dang that looks good gonna check them out
    Why not a regular ratchet strap? I’m using a husky one right now
    Looks like the right hook is connected to a bed stiffener
    what is the top and left hook connected to?
    I tried mounting mine behind the cab with two bed cleats but somehow they loosened…
    edit: I see now right part is hooked to a d ring by the stiffener
    I also have a bunch of d rings, maybe 6; sprinter van d ring mod and OEM bad mat with hole cutouts
    T.Barn[QUOTED] likes this.
  7. Apr 17, 2022 at 9:22 PM
    T.Barn
    Todd
    2010 AC 4x4 6MT
    I appreciate it. I added some tie down points for the other sides to attach to. I used a regular strap and the wheel moved around too much for my liking. With it set up like this there is 0 movement.
  8. Apr 17, 2022 at 10:50 PM
    gfxguy
    gfxguy Well-Known Member
    WA
    2015 Tacoma DCSB OR
    Another busy day. Started by reinstalling the mudflaps after giving them another coat of paint yesterday. Then I installed a power tailgate pop & lock.
    That reminds me, gotta get an exhaust tip at some point.
  9. Apr 17, 2022 at 11:00 PM
    gfxguy
    WA
    2015 Tacoma DCSB OR
    Next I rebadged the bed sides and tailgate since I didn’t like the naked look the truck came with (I guess they debadged when repainting it and left them off). Was gonna use OEM decals and even ordered a pair (or so I thought), but was surprised when I discovered there was only one in the package. Decided to cut my losses and picked up a matte black TRD OR decal pair on eBay for a quarter of what I paid for one OEM decal. They go well with the matte black emblem overlays I also installed today.
  10. Apr 17, 2022 at 11:11 PM
    gfxguy
    WA
    2015 Tacoma DCSB OR
    Finally I did a test fitting of my RPT1s before my install appointment tomorrow. I noticed on Saturday that the wheels have a 110.5 bore instead of the advertised 108.5 so the hub centric rings I bought wouldn’t work. I was able to find a set of 106/110 rings on Amazon with next day delivery, and got them just after lunch today. However, when I tested them in the wheels they hit a lip on the bore (it steps down in diameter to 109-ish at a depth of 8.7 mm and the rings are 10 mm thick), so they didn’t sit flush. I ended up filing down the outer edge of the rings until they fit.
  11. Apr 17, 2022 at 11:47 PM
    srspicer
    srspicer Paint it black
    Lower Bucks PA.
    05' Black DBLC short bed
    Painting things black
    This is exactly what I want to do to mine. It is just lazy on the part of Toyota to do pop-rivets. Plus, I also plan to remove the bed and clean & paint the frame. Riv-nuts will make it easy to do so.
    3Riverz88 likes this.
  12. Apr 17, 2022 at 11:49 PM
    TacoTuesday1
    SD CA
    how come you went with their twisted hook option vs. flat?
  13. Apr 17, 2022 at 11:50 PM
    Kyle14Taco
    Kyle14Taco Winter Soldier
    Kyle
    2014 Tacoma SR5 4X4
    3 inch lift
    Looks great! I gotta check those out, been looking for some good seat covers.
    3Riverz88 and Voltron4x4[QUOTED] like this.
  14. Apr 18, 2022 at 12:25 AM
    TacoTuesday1
    SD CA
  15. Apr 18, 2022 at 5:08 AM
    T.Barn
    Todd
    2010 AC 4x4 6MT
    I went with these cause I felt it best for my situation.
  16. Apr 18, 2022 at 5:56 AM
    hxp05560
    hxp05560 Well-Known Member
    2009 TRD Off-Road
    TRD Pro Wheels - Duratracs Black Softopper
    How do you like the pop & lock so far? I’ve been thinking of adding this to my truck.
  17. Apr 18, 2022 at 6:07 AM
    3Riverz88
    3Riverz88 Well-Known Member
    Massachusetts
    2014 Gray Tacoma SR5
    Front leveling kit, side steps, tonneau cover, decked bed system
    been wanting some hood struts myself!
    will.i.was[QUOTED] likes this.
  18. Apr 18, 2022 at 6:13 AM
    3Riverz88
    Massachusetts
    Installed the scosche wireless charger. Plug and play kit. Goes in the same cubby where the 3rd gens have this feature from the factory
  19. Apr 18, 2022 at 6:23 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Do they sell just the 4 digit comb thingy?
    My eyes are going to
    reallifedog likes this.
  20. Apr 18, 2022 at 6:40 AM
    GlennHaggis
    Glenn
    Ormond Beach, FL
    A Bunch
    Gonna be a long day cleaning after muffin’ this rig!!
